Mini Cooper R53 auto Transmission Problem
Old May 24, 2023 | 04:18 AM
Tiagovito's Avatar
Tiagovito
Hi,
been reading through the forum but didn’t find similar issue. My transmission start acting up, 1 and 2 gear really rough, looks like car doesn’t know when it should shift. Sometimes stuck on 3rd gear.
I don’t think is common issue of solenoids or valve body, replace solenoids 20k ago and was shifting fine after.
what is very odd is when I connect INPA to the car I’m not able to communicate to transmission module anymore like I did before.
maybe I have a bad connection or a bad module?
where should I look for wiring?
Old May 24, 2023 | 04:52 AM
Tiagovito's Avatar
Tiagovito
Old May 24, 2023 | 04:58 AM
Tiagovito's Avatar
Tiagovito
Module plugs!
Found the module over foot pedals and for my surprise the plugs look like that. Is it normal? Wondering where that residue is coming from.
Old May 25, 2023 | 08:31 AM
Yes, looks like brake fluid or oil from above dripped on it. Check the lines under the dash and footwell.
Old May 25, 2023 | 09:54 AM
Tiagovito's Avatar
Tiagovito
clean everything and now the transmission module is connecting to INPA. I guess is working.
will drain the fluid and refill it and try to go over learning procedure again.
do you know how to properly check fluid level?
Old May 25, 2023 | 10:21 AM
Hello,
Its the fluid coming from somewhere else, did you find out where its coming from? You got a leak somewhere.
Its leaking on the unit near the harness.
Old May 25, 2023 | 10:40 AM
Tiagovito's Avatar
Tiagovito
Brake fluid
Looks like is brake fluid. Is right above where de reservoir stays
Old May 25, 2023 | 12:35 PM
Ok, yep my guess is the cap at the reservoir, connection point #5 or one of the lines? If its the lines it might not be tight on the master cylinder
Diagram:
https://www.realoem.com/bmw/enUS/sho...diagId=34_1219
https://www.ecstuning.com/Search/Sit...h/34336756237/
#5 https://www.ecstuning.com/b-genuine-...336873449~oem/
Old May 25, 2023 | 12:38 PM
Tiagovito's Avatar
Tiagovito
Diagram:
thank you!!
I’ll double check them over the weekend
Old May 25, 2023 | 12:45 PM
Welcome!
majikz666
Sep 27, 2022 05:24 AM
dcwang3
Aug 25, 2020 04:17 AM
racecar
Aug 10, 2013 10:35 AM
Jason987
Dec 16, 2009 06:26 PM
