New Bargain R56
Old Oct 7, 2019 | 07:00 AM
robj's Avatar
robj
New Bargain R56
Another new guy. 2005 R53 S. Bought it from a neighbor for cheap. It had a bad idler pulley, threw the belt and sat for a year. Put a new battery in and even after sitting it started right up. Currently apart for supercharger service, 15% pulley, water pump, T-Stat and housing, along with new hoses. Alternator was stuck so new one of those along with a belt tensioner, belt and colder plugs. While everything is apart a knock sensor and a crank position sensor. Oh, also rotors and pads along with parking brake cables.
So cheap isn't quite so cheap anymore with taking care of all the P.O.'s deferred maintenance. Waiting on a few hoses so a little cleaning up was on order. Foaming aluminum cleaner and a fine wire brush. Waiting on some Por-15 for the block. Some re-assembly required!
Anything else I should be looking at while it's all apart?
Thanks,
rob
Old Oct 7, 2019 | 07:03 AM
robj's Avatar
robj
Cleaned up SC with a new water pump waiting on some hoses. And I forgot the new axles...
rob
Old Oct 7, 2019 | 07:09 AM
robj's Avatar
robj
Guess I should add a "before surgery" shot. Not bad for $500. After $2500 in parts it's not really a $500 Mini more like a $3000 Mini. But, nice wheels, almost new tires and the interior is very nice. And it should be pretty squared away.
Having some mini fun!
Old Oct 7, 2019 | 07:31 AM
squawSkiBum's Avatar
squawSkiBum
Moderator
Welcome to NAM, well bought and nicely done taking care of everything!
Old Oct 7, 2019 | 07:42 AM
Welcome! Nice find!
Old Oct 7, 2019 | 04:32 PM
robj's Avatar
robj
Ha! As an old guy of 68, "Welcome to Nam" had a funny ring to it....
robj
Old Oct 7, 2019 | 06:19 PM
Tygurscoop's Avatar
Tygurscoop
Other items... Maybe ball joints and LCA's, you're most of the way there already. Give the crank pulley a good look/thought.
Old Oct 8, 2019 | 09:30 AM
robj's Avatar
robj
Tygurscoop,
Thanks!
It had a torn CV boot and with 155K on the clock I bought 2 new axles. When that's apart I think it will be a good chance to examine the joints and the control arms. It was pretty gently driven, [owner was my next door neighbor] but time does take it's toll.
I looked pretty close at the crank seal as there was some greasy deposit towards the rear of there on the block. Nothing in the front though. I thought that might be as it was blowing towards the rear, then I found the torn CV joint boot and the same greasy deposits on the frame, etc.. in a circle around that so I think it was from that, not the crank seal but I'll take a closer look.
Good suggestions!
robj
Old Oct 8, 2019 | 07:27 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I'd do the crank sensor oring while in there.
Also save your original axles as they are the best and rebuildable as that is what we do in our shop.
Old Oct 9, 2019 | 03:39 AM
robj's Avatar
robj
I got a new CPS, but thanks for the tip on saving the old axles. I probably would not have saved them.
Thanks,
rob
Old Oct 12, 2019 | 10:06 AM
ItsmeWayne's Avatar
ItsmeWayne
Hi and welcome to NAM! A bit late!
Congrats on your great find!
05 and 06 R53's are the best years, of the gen 1's!
Nice work too!
Old Oct 13, 2019 | 01:06 PM
robj's Avatar
robj
To demonstrate how new I was to Mini's, I mis labeled the subject as R56.... Duh, R53.
See, I'm learning.
robj
ColonelAngus
Jan 29, 2021 01:34 PM
apt77
Oct 20, 2019 09:45 AM
dsaber
Dec 19, 2018 03:02 PM
j.designer.105
Oct 21, 2018 06:20 PM
moeman
Jul 20, 2007 03:49 AM
