i need to change plugs and wires
Old Jan 27, 2014 | 11:47 AM
cozyp828's Avatar
cozyp828
what brands of plugs and wires should i use in my 2010 hardtop?
engine light went on, and mechanic said one plug misfiring; needs to be changed.
thanks.
Old Jan 27, 2014 | 12:00 PM
Whats model 2010 MINI Hardtop do you have, Cooper, Cooper S, JCW ? R56?
I know you are a gen 2 MINI and it will be plugs and coils. 4 plugs and 4 coils. One coil per plug.
Then I can help you.
Old Jan 27, 2014 | 12:01 PM
cozyp828's Avatar
cozyp828
2010 mini cooper hardtop manual base
Old Jan 27, 2014 | 12:04 PM
cozyp828's Avatar
cozyp828
i need to study my abbreviations. i don't know what r56, etc. mean. lmao!
Old Jan 27, 2014 | 12:11 PM
cozyp828's Avatar
cozyp828
61,000 miles, and how much longer before the clutch goes?
Old Jan 27, 2014 | 12:17 PM
patchelect's Avatar
patchelect
Clutches last an extremely variable amount of time. The same car in the hands of one driver can go 100K and in the hands of another, 30K. I actually don't know that "typical" clutch life for a Mini, but I can tell you that in a Miata, 150K++ was not unheard of, and that isn't generally an easy going crowd.
Old Jan 27, 2014 | 12:25 PM
cozyp828's Avatar
cozyp828
wow! that's good to know. thanks.
Old Jan 27, 2014 | 01:05 PM
R56 is the 2007+ Hardtop ( Three door ). Most popular MINI.
R56 MINI Cooper ( Non S ) is another way to say it. For MINIs without the turbo engine.
Most likely that's what you have. I have linked the part number.
Ignition Coils ( one per cylinder ). MINI OEM Part # 12137594937
http://www.ecstuning.com/Search/SiteSearch/ES1304983__ES2550226/
Look for your production Month / Year it will be in the door jam on the driver side.
For vehicles up to 09/2009 Part # 12120035933
http://www.ecstuning.com/Search/SiteSearch/12120035933KT/
For vehicles from 09/2009 Part # 12122158165
http://www.ecstuning.com/Search/SiteSearch/12122158165KT/
Takes a special deep well 14mm 12 point , thin wall socket to get the plugs out:
Deep Well Spark Plug Socket - 3/8" Drive
http://www.ecstuning.com/Search/SiteSearch/ES2561145/
Thanks , hope that helps.
Old Jan 27, 2014 | 04:11 PM
xsmini's Avatar
xsmini
Depends, I'm still on my original at over 323,000.
Nik
Old Jan 27, 2014 | 04:46 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
MINI says the plugs are 100k plugs, but we find it's better to replace them on your MINI at 50k as they wear and fuel mileage suffers or fail like yours.
http://www.waymotorworks.com/spark-p...per-non-s.html
but you will need the special socket to remove them, we have this long one which makes it really easy.
http://www.waymotorworks.com/long-sp...-r61-mini.html
Old Jan 29, 2014 | 06:53 PM
cozyp828's Avatar
cozyp828
Thanks again to all!
Greatly appreciated!
tr3y003
Oct 22, 2015 10:48 AM
sprp85
Aug 22, 2015 06:16 AM
Super Coop
Aug 17, 2015 05:09 PM
FLYM1N1
Aug 16, 2015 01:17 PM
Getrieben
Aug 15, 2015 09:09 PM
