Harmon Kardon Amp Wiring Diagram?
I'm looking to replace the HK Amp in my 2003 MC "non S" is there a wiring Diagram or color code chart for the wires, so the process will be easier to hook up to another Amp? Also does only the back speakers go to this amp or are all 6 speakers hooked up to this amp? I would assume that all 6 are hooked to it because the front 4 sound very nice... my problem is that the back 2 6x9's are nothing but static, and the front 4 are great. with the fader adjusted to the front only works but I don't feel i'm getting the full HK experience. any help greatly appreciated... also Would there be a problem just splicing the rear speakers with the front speakers?
I have the HK connections online:
http://www.gbmini.net/HKconnections.pdf
The two door speakers are each wired separately to the amp, and the two rear speakers are dual voice coil so each have two feeds from the amp.
There is a single L/R speaker fixed level feed from HU to amp - the amp communicates digitally (iBus) to learn the volume/balance/fade/tone/etc settings.
The H/K speakers are 2 ohm loads - splicing together would not work. Also, the H/K amp filters and splits the sound to each speaker ... so the fronts don't get the signal that the rears do.
http://gbmini.net/downloads/PGEN/hk-plug-grey.htm
http://gbmini.net/downloads/PGEN/hk-plug-black.htm
http://www.gbmini.net/wp/category/stereo_stuff/
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
paul7878
Sep 14, 2015 07:44 AM
