BIG Brake Kit
Old Dec 12, 2006 | 07:28 PM
MCSMiami's Avatar
MCSMiami
BIG Brake Kit
What is the baddest, biggest, most bling-bling brake system offered for a MINI? I don't track the car...just want something that looks radical...kind of like what I have on my S4.
Old Dec 12, 2006 | 08:23 PM
txwerks's Avatar
txwerks
Biggest? Nope... Baddest? Among the best, yes... Most bling and VERY unique? Definitely!
Old Dec 13, 2006 | 12:45 AM
jerjer's Avatar
jerjer
biggest? go for the 14" wilwood BBK, it's crazy! i wish i can afford it, it's pure sex right there!
Old Dec 13, 2006 | 03:28 AM
kyriian's Avatar
kyriian
bling-est has to be this:
http://www.gtt.uk.com/brakes.asp
Porsche calipers, 341mm discs
Old Dec 13, 2006 | 04:50 AM
Larry Clemens's Avatar
Larry Clemens
IMO the best bang (and bling) for buck is the Detroit Tuned BBK.
Old Dec 13, 2006 | 05:29 AM
Newdl's Avatar
Newdl
Detroit Tuned BBK.....I agree
Old Dec 13, 2006 | 05:45 AM
rubyred3's Avatar
rubyred3
wtf is up with that txwerks kit, its very strange looking, why the odd shape for the rotors?
Old Dec 13, 2006 | 05:55 AM
toddtce's Avatar
toddtce
I'd be more than happy to get you into the special "one off" 14" kit I have on the shelf. The kit has been idle while I've been out of the shop a bit but when I'm back on Sat it's wide open. You'll need 18's or larger to clear the rotor however...
Old Dec 13, 2006 | 06:42 AM
txwerks's Avatar
txwerks
It's all about light weight and cooling...
The Brake Man developed that shape, and many have tried to copy it...
Old Dec 13, 2006 | 06:53 AM
pberry51mini's Avatar
pberry51mini
No Fear Gear
Flower shape rotors?
That honestly looks like something my wife would put on her VW Bug with the white flower Mille-Miglia wheels.
Maybe it's useable bling but I'd leave that to those VW/Audi people or something.
Paul
Old Dec 13, 2006 | 10:00 AM
txwerks's Avatar
txwerks
The same "flower shaped" rotors you'll find on American Iron, dirt trackers, modifieds, sprints, midgets, late models, and NASCAR (rears on some Busch and Cup cars) race cars, yup.
All I can say is that they work... And, your wife's Bug would stop on a dime...
Old Dec 13, 2006 | 12:42 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I like those txwerks brakes--very high on the bling, and way different (of course, every mountain biker has them nowdays!)
Here's the TCE 13" kit with thousands of miles of smiles on them: they sure do fill the wheels, look very serious, and work like no other brake I've ever used (+++):
Not the most bling, not the biggest (damn, do I have to buy 18" rims now, Todd?), but still a whole lot more than stock.
Old Dec 13, 2006 | 05:07 PM
MCSMiami's Avatar
MCSMiami
Yes...I'm interested, call me 305.798.5058 Danny, thanks.
Old Dec 13, 2006 | 05:11 PM
MCSMiami's Avatar
MCSMiami
Looks awesome...that's the look I want...I'd prefer cross-drilled rotors though.
Old Dec 13, 2006 | 05:27 PM
newbs49's Avatar
newbs49
Cross-drilled are OK for the street but if your going to track the car at all not a very good idea.
Old Dec 13, 2006 | 05:41 PM
jonnieoh's Avatar
jonnieoh
Yeah, here's another vote for the Porsche BBK. They're by far the biggest, most blingy, and baddest *** set of calipers available for the MINI.
No contest. Those things are ginormous!
Old Dec 13, 2006 | 07:14 PM
toddtce's Avatar
toddtce
I suppose I'll start a war here of sort...but if you really feel that a MINI needs 17lb rotor rings to be effective; buy them. On the other hand, the fit of 1.25" wide rotors and the added .200" of radius is going to have near zero effect on brake effectiveness. The bias shift alone from 13 to 13.4" is less than 2% by radius only. That 2% may or may not be effected by how other elements of kit design is taken into consideration.
I have no problem making a 13.4 x 1.25" kit if someone wants one. I just feel that such mass is both more costly (add $100 to a 1.10" kit) and more weight that is of no use and perhaps a handicap to this application. Not to mention the loss of wheel fit room required by the shear size.
The 14" kit is one I've work hard to keep under control at a modest 1.10" width just to be able to offer the widest selection of wheel choices.
*when you guys figure out how to fit 19s on this car with ease let me know...we'll go to 14.8" rotors....http://www.tceperformanceproducts.co...MG1745_001.JPG
Old Dec 13, 2006 | 07:21 PM
txwerks's Avatar
txwerks
Agreed... IMHO, the increase in mass would negate some of the goodness that comes with a BBK! I mean, you're adding some 5.5 pounds more per front rotor versus stock. That's like slogging around an additional 44 pounds...
Old Dec 13, 2006 | 09:31 PM
GoodFinder's Avatar
GoodFinder
This is definitely a case for "bigger is not always better" for maximum performance!
Old Dec 13, 2006 | 10:20 PM
kyriian's Avatar
kyriian
very true, a similar sized rear brake kit is likely needed.. that said... tarox has a 10 piston setup for the mini as well for those who are into piston amount instead of big discs....
i think its all ridiculous... we have a 2600lb car! this is not a 4000 lb BMW!
Old Dec 13, 2006 | 11:30 PM
UKSUV's Avatar
UKSUV
When I talked to Stoptech a while back they said the Mini's rear caliper is well suited to a BBK. They would never produce one for the rear. Now, on my BMW, they do make a rear kit. They said it is more bling than functional on a daily street car but if you track it...can show improved benefits....But, then, they still said it's more bling than anything. I'm gettin it! P.S. - and my BMW weighs out at 3200lbs not 4K. Not much behind our FATTY Mini's.
Old Dec 14, 2006 | 05:54 AM
toddtce's Avatar
toddtce
The main reason I offer a "matching rear kit" is appearance. The main reason people buy it is that it compliments their front kit. Personally, I feel that's an important part of what you offer your customer. As for function the rear when paired with the 13" front kit produces a very well matched setup and does not require any pad changes or the like that you may want on a smaller rear rotor and large front mix.
Old Dec 14, 2006 | 06:33 AM
fj0's Avatar
fj0
Any pics of 14" kit installed?
This is 15" :drool:
Old Dec 14, 2006 | 08:59 AM
JDR's Avatar
JDR
Paul
they look like brass knuckles to me....
Old Dec 14, 2006 | 09:07 AM
SDMike's Avatar
SDMike
Endless makes a real nice kit for the MINI... 6pot, equal pressure, etc.... but 5800.00 for the kit... oh yeah... fronts only.
