Help!!! Rusty T50 screw stuck in Rotor!
Old Jul 14, 2006 | 03:57 PM
DreamWeaver's Avatar
DreamWeaver
I bought a set of Bremo Cross-drilled rotors and Hawk brake pad (I'm soooo excited) but after getting the pads and caliper off, I couldn't get the rotor screw out! The screw seems to have rusted in and won't budge at all. Does anyone know a way to get this out?!?!?!?!
Thanks so much!
Old Jul 14, 2006 | 04:01 PM
Eric_Rowland's Avatar
Eric_Rowland
One of the first things I did was to loosen/lube/retighten those things. They just look like trouble waiting to happen.
I'd soak it liberally with PB Blaster, give it a little time, then use a cheater bar and hope...
Old Jul 14, 2006 | 04:25 PM
AZMCS's Avatar
AZMCS
I encountered a frozen rotor bolt recently on an .:R32
I used this:
http://www.harborfreight.com/cpi/cta...emnumber=37530
Worked perfectly. I bet you can get a Torx bit to fit it.
Well worth the investment.
Old Jul 14, 2006 | 04:33 PM
Uncle_John's Avatar
Uncle_John
Yep, an impact driver is the answer. Mine were stuck too, and a 3/8 drive T-50 bit on an impact driver did the trick. I think the bit cost about as much as the driver, and neither was over $10.
Let us know.
Old Jul 14, 2006 | 04:37 PM
DreamWeaver
A mechanic mentioned using a blow torch to heat up and loosen the screw. Is that a bad idea?
Old Jul 14, 2006 | 05:05 PM
Uncle_John's Avatar
Uncle_John
I knew guys that used to do that to nuts. Since metal expands when heated, using that on a bolt in a hole might not be the best idea. Try an impact driver.
Old Jul 14, 2006 | 05:19 PM
Grassroots Garage's Avatar
Grassroots Garage
You don't want to use heat near the bearing, the impact driver is the way to go. If the head strips and the bit won't bite, then you can work it loose with a hammer and small chisel (I have had to do that alot), but get new bolts and apply some anti-seize lubricant before re-installing.
--Dan
Old Jul 14, 2006 | 06:39 PM
DreamWeaver
Thanks for all the help everyone. I'm borrowing a Impact Driver tomorrow so i'll tell you all how it goes. Thanks again!
Old Jul 15, 2006 | 11:59 AM
DreamWeaver
The impact drill is $200 at Homedepot.
Are there any other suggestions?
Old Jul 15, 2006 | 01:04 PM
ekibobrut1's Avatar
ekibobrut1
motorcycle shops sell one that you whack with a hammer....s/b less tha $20
Old Jul 15, 2006 | 01:07 PM
cristo's Avatar
cristo
Alliance Member
$25 at sears
Old Jul 15, 2006 | 02:09 PM
DreamWeaver
the rotor screw was successfully drilled out but now the bolts on the back won't budge.
Old Jul 15, 2006 | 02:23 PM
Eric_Rowland
Drilled out? So when you get the rotor off you'll need to use vise grips on the rest?
Bolts on the back??
Oh - you mean those holding the brake caliper?
PB Blaster or equivalent - let it sit for a few hours, or overnight if you can. Sounds like you've got some serious corrosion issues.
How big a wrench are you using? Time for a breaker bar and cheater bar, but first liberally soak in penetrating oil to reduce the risk of just twisting parts off!
Old Jul 15, 2006 | 06:48 PM
AZMCS's Avatar
AZMCS
You need some organized, experienced help. Drilling out a bolt that could be removed with a $8 tool is not too cool. :impatient The caliper carrier bolts are gonan be way tighter and tougher to remove.
Get some PB blaster and get a buddy who has done brake work before to help you.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
rtk90
Aug 29, 2019 09:08 AM
minimofo
Sep 30, 2015 12:26 AM
Sep 14, 2015 12:48 PM
David.R53
Sep 13, 2015 03:44 PM
