Serious confusion with new Wheels
Old Jun 28, 2006 | 06:55 AM
qwertmonkey's Avatar
qwertmonkey
I am watching a set of new wheels on eBay and have a few questions
The page says that I need to buy the lug BOLT package. It has new locking lugs, a key, and valve stems.
Do I need to buy this package? I am seriously confised. Thanks for the help.
They are 17'' if that even matters.
ADR WHEELS
Model:Sokudo
Bolt Pattern: 4x100/4x114.3
Off Set: +40mm
Old Jun 28, 2006 | 06:59 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Are they locking lug BOLTS? or just nuts?
If they are nuts, you won't be able to use them unless you converted lug studs.
Old Jun 28, 2006 | 07:16 AM
qwertmonkey
Sorry, they are locking lug BOLTS. I wasnt thinking while I was typing
Old Jun 28, 2006 | 07:24 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Will you be able to use your factory lug bolts on these wheels? If you can, then I would use the factory MINI wheel locks.
Old Jun 28, 2006 | 07:37 AM
qwertmonkey
That what I was asking. Can I use the stock bolts? I dont care about the locks. Also, do I need the new stems?
Old Jun 28, 2006 | 07:39 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Can you post a pic of the wheel?
Old Jun 28, 2006 | 07:47 AM
qwertmonkey
Old Jun 28, 2006 | 07:49 AM
qwertmonkey
ADR WHEELS
Model:Sokudo
Off Set: +40mm
Old Jun 28, 2006 | 08:06 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Nice wheels! Not a big fan of the dual fitment, but that's just me.
Anyway, from the angle it's hard to see the seat where the lug bolt will bottom. The lug holes look like they might accomodate the factory lugs bolts, otherwise you might need "tuner" lugs.
Old Jun 28, 2006 | 08:10 AM
qwertmonkey
What exactly are turner lugs? Here is another pic.
Old Jun 28, 2006 | 08:21 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Basically smaller diameter lug nut/bolt.
http://www.piloracing.com/proddetail.php?prod=17100SD20
Old Jun 28, 2006 | 08:46 AM
qwertmonkey
Hmm. Ok.
Thanks for the help!
Old Jun 28, 2006 | 09:02 AM
gr8britwjh's Avatar
gr8britwjh
As pictured, the wheels don't have valve stems fitted, so yes you will need them (though these are usually fitted when the tires are mounted. Are you buying just wheels or wheels + tires?).
The OEM lug bolts may not physically fit those holes and, even if they do, they could end up being a little on the short side because of the offset difference between these and OEM wheels.
Old Jun 28, 2006 | 12:05 PM
qwertmonkey
I am getting just the wheels.
Old Jun 28, 2006 | 08:17 PM
2perCooper's Avatar
2perCooper
you may need the tuner lug bolts to fit the holes...if you don't need them and want to use your stock lug bolts, be sure that the wheel accepts cone seat lug bolts, which the OEM lug bolts are. The wheel may only accept ball seat lug bolts, so that needs to be taken into consideration.
Old Jul 3, 2006 | 07:05 PM
Hyper!!!Blue!!!'s Avatar
Hyper!!!Blue!!!
You'll probably need them as I bet the factory bolts will be too short.
Old Jul 3, 2006 | 07:45 PM
kenchan's Avatar
kenchan
i think the factory lug bolts will work.
i use to have the Sokudo's by ADR for my Pro5 i had back in the days...
paint chipped like hell though...
sevin
May 2, 2026 06:11 AM
woodstudio
Mar 15, 2020 08:28 AM
eatsleepautox
Oct 30, 2015 06:46 AM
theblackfalcon
Oct 11, 2015 09:49 AM
StuRat
Aug 24, 2015 06:24 PM
