Tire sizes
Old Mar 20, 2006 | 05:46 AM
Pebblecrusher's Avatar
Pebblecrusher
Tire sizes
205/45 R17 is the stock size. Not a whole lot available. What size can I safely put on my stock wheels? No suspension mods have been done.
I am currently looking at getting 4 Avon Tech M550 A/S tires in the stock size, but wanted to see if there were more tires to consider in other sizes.
Old Mar 20, 2006 | 06:26 AM
coopercrazy's Avatar
coopercrazy
you should be able to go to 215/45.
Old Mar 20, 2006 | 06:33 AM
Pebblecrusher
So a little wider. Any worries about rubbing with stock suspension?
Old Mar 20, 2006 | 07:15 AM
blalor's Avatar
blalor
I don't think you'll have any problems with 215. I'm running 225/50/15 on +40 offset 15x7" wheels and have slight rubbing on the fender flare, but not on any of the suspension components. I think offset plays a big part in the equation, but with stock wheels, 215 should be fine.
Old Mar 20, 2006 | 07:46 AM
Pebblecrusher
I just ordered some Yokohama AVID H4S tires. 215/45R17. In my price range and the treadwear seemed good, though I was hesitant to go away from the runflats.
Old Mar 20, 2006 | 07:48 AM
draggonmann's Avatar
draggonmann
I am running 215/40/17's on stock suspension and wheels and have no rubbing problems. I even ran a tight AUTOX event with no rubbing problems.
Old Mar 20, 2006 | 11:08 AM
Mini Works's Avatar
Mini Works
I am running 215/40/17 with a Koni Sport Suspension, there is no rubbing
Old Mar 20, 2006 | 11:17 AM
Pebblecrusher
Now the way I understand it, 215 is wider but 40 is lower profile. So the two soft of offset themselves to prevent rubbing. I've read on another thread about 215/45 not rubbing either with stock suspension.
Old Mar 20, 2006 | 11:46 AM
blalor's Avatar
blalor
Depends on why the tire's rubbing, Pebblecrusher. It could rub because it's too wide or because it's too tall. Going shorter's not going to make a tire that's too wide not rub.
Old Mar 20, 2006 | 12:05 PM
coopercrazy
offset could have alot to do w/ it.
215/45 is less than 1/2" wider, and 1/5" taller, than 205/45.
Old Mar 20, 2006 | 12:32 PM
Pebblecrusher
I agree blalor. My understanding is far from perfect, though it did seem logical, at least in this case.
I'll update the thread with my opinions once I get the tires installed.
Old Mar 23, 2006 | 06:28 AM
Pebblecrusher
How small of a wheel can I go down to safely without ruining the readings on the speedometer and odometer or dragging the bottom? I'm seriously considering moving down to 16 or even 15 in wheels. Is smaller possible?
Old Mar 23, 2006 | 06:34 AM
blalor's Avatar
blalor
15's fine with the stock brakes. I'm running 225/50/15 on 15x7 Konig Rewind wheels. Smaller wheels doesn't have to equate to less ground clearance or inaccurate speedo readings; just make sure you get the appropriate sidewall height.
Old Mar 23, 2006 | 09:17 AM
gowest's Avatar
gowest
16" wheels seem to offer the best compromise of wheel weight and sidewall height while maintaining a close to OE tire diameter and there are many good 205/50/16 tires out there. If for some reason you wanted to go to a 15" wheel and not want to worry about rubbing while maintaining apx. OE dia. then there are a few good 205/55/15's available but with the 16's shorter sidewall height and better tire selection, the 16's are a better choice. With 17's I would go for the 215/40/17 but if you drive long distances with a heavily loaded car you would want to check the load ratings on these before buying because many of them have a lower rating than the OE tires.
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
Waszak
Oct 21, 2017 05:55 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
