TDR Pr1s and lug bolts.
Old Feb 7, 2006 | 08:01 PM
sprp85's Avatar
sprp85
hello nam.
i have a quick question concerning stock lug bolt length vs. aftermarket wheels.
I have a set of tdr pro1 17x7 et35 that i will be putting on my car in a day or two.. and I'm kinda worried about stock bolt's capability..
would anyone like to share their knowledge in this?
thank you..
-sp
Old Feb 8, 2006 | 12:27 PM
sprp85's Avatar
sprp85
nobody??
Old Feb 8, 2006 | 02:57 PM
gr8britwjh's Avatar
gr8britwjh
I'd hazard a guess and say that the stock bolts might not be long enough. Send an e-mail to Alex at Tire Rack.
Old Feb 8, 2006 | 02:59 PM
Passat774's Avatar
Passat774
try them and see, I think that they may work. Just stick a OEM bolt thru the new rims once you get them and make sure there is just as much stud sticking thru them as they had one the factory wheels were on..
Old Feb 8, 2006 | 09:39 PM
sprp85's Avatar
sprp85
oky doky! I will try tomorrow and see!
Old Feb 8, 2006 | 09:51 PM
W3IWI
I found the stock bolts worked fine on Rota Slipstream wheels. Remember you may need a "hub centric" spacer if the center hole is bigger than the stock 56.1 mm hole. I needed 67 => 56.1 mm adapters.
I later replaced the stock lug bolts with studs and nuts. Makes it a LOT! easier to swap wheels.
Old Feb 8, 2006 | 10:04 PM
sprp85's Avatar
sprp85
yup! got the centric rings.. oh by the way aren't the slipstreams et40?
Old Apr 29, 2006 | 06:55 PM
irlracefan's Avatar
irlracefan
sprp85 do the factory bolts work with the Team Dynamic Rims?
Old Apr 30, 2006 | 12:19 AM
sprp85's Avatar
sprp85
Mine was an ET35 rims and yes, stock lugs worked well
freckles81
Jan 15, 2017 06:33 AM
theblackfalcon
Oct 19, 2015 05:22 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
StrongIslandMini
Sep 16, 2015 12:58 AM
papawhiskey
Sep 14, 2015 05:47 PM
