how many of you have this: 42 mm offset wheels with 215x45x17 tires
Old Sep 22, 2005 | 12:36 PM
rrdusek's Avatar
rrdusek
42 mm offset wheels with 215x45x17 tires and stock suspension? i'm buying new tires and want to go wider, but don't want any problems. thanks in advance.
Old Sep 22, 2005 | 01:38 PM
Central Coast Coopers's Avatar
I HAVE THAT COMBO WITH H&R SPRINGS-rears rub slightly on big dips, i doubt it would be a problem with stock springs, rub is not enough to ever leave a mark on the tires
Old Sep 22, 2005 | 01:59 PM
danielg's Avatar
danielg
I have the Flik Wasp wheels 17" offset 42 with 215/45/17 tires, no rubbing.
Old Sep 22, 2005 | 02:05 PM
AnnJones's Avatar
AnnJones
215's
I have Volk 17 X7.5, 42mm offset, Goodyear F1 GS D3, stock springs - no issues.
Ann
Old Sep 22, 2005 | 02:11 PM
rrdusek's Avatar
rrdusek
annjones, i've ordered the same tires you're running. do you recommend them?
Old Sep 22, 2005 | 06:06 PM
kyriian's Avatar
kyriian
i run that combo with eibach springs... minor rubbing when the car's loaded but otherwise runs perfectly fine...
Old Sep 22, 2005 | 06:11 PM
MSFITOY's Avatar
MSFITOY
37 ET, 215/40-17, H-Sport springs...no problems:smile:
Old Sep 22, 2005 | 06:27 PM
red rage's Avatar
red rage
40 offset.. PSS9, 215-45-17 Pirelli, no problems
Old Sep 22, 2005 | 09:56 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
rrdusek,
17" rims with +42mm offset and 215/45-17 tires will work with stock suspension and NOT rub.
Once you lower your MINI then you are at risk of rubbing but it depends on which tire you have, it's size/side wall height, your camber and how much drop you have.
PSS9 and other coilovers allow for some adjustment of ride height so you can make it not rub.
Don't go wider if the 215/45-17 will suit your needs. 225/45-17 sounds nice but the outer tire diameter is a larger than stock 25" which when combined with lowering springs will result in rubbing not to mention the tire itself is wider than stock.
Old Sep 23, 2005 | 01:28 AM
kurvhugr's Avatar
kurvhugr
I had 17 x 7.5 SSR Comps w/ 42mm offset and 215-45-17 S-03s on stock suspension. I had some rubbing in the rear even without passengers (only at large dips in the road) but eliminated it with adjustable control arms and a little neg camber.
Old Sep 23, 2005 | 06:21 AM
haulin_oats's Avatar
haulin_oats
offset only matters depending on the width of the wheels.
Old Sep 27, 2005 | 12:16 AM
zrwon's Avatar
zrwon
I have 17"x7" ARE Chrome Coils 42 mm and 215/45-17 F1 GS-D3 with stock suspension and no rubbing in 2 weeks.
Tonight I installed my front PSS9's, will do the back tomorrow night but I'll have to set the height as it is way too low
Old Sep 28, 2005 | 11:28 AM
MINIAACK's Avatar
MINIAACK
No Rubbing, I also have eibach springs
pre shrunk
Aug 18, 2015 11:09 AM
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
nomar116
Aug 9, 2015 09:42 AM
