FSD available for immidiate shipment!
Old Sep 14, 2005 | 06:31 AM
Alex@tirerack's Avatar
Alex@tirerack
NEW Koni FSD @ TireRack.com
In standard shock absorbers the main damping characteristic is defined by the oil flow going through the piston assembly (1).
Combining it with the FSD feature (2), KONI added a special valve that controls an oil flow parallel to the one going through the piston rod (3). This parallel oil flow is closed by the FSD feature, giving a rise in damping force almost linear to the time that the piston is moving in one direction
Put simply: the FSD feature is a hydraulic amplifier that delays the build up of pressure. In some ways an extra tuning option has been created in order to get the best possible combination of handling and comfort.
Since it is an integrated part of the hydraulic valve system inside the damper, no additional cables, sensors or any other electronic devices are needed to operate an FSD damper.
Call me to place your orders!
Alex
Old Sep 14, 2005 | 11:41 AM
JeffS's Avatar
JeffS
I'd have already snapped these up if the price were closer to that of the yellows. Oh well... I suppose I'll break down and try a set anyway eventually.
Old Sep 14, 2005 | 04:49 PM
xtremepsionic's Avatar
xtremepsionic
I've heard that they're comfy, but what about performance wise? Do they give better control when you're driving hard or they're mostly just for comfort?
Old Sep 14, 2005 | 06:10 PM
mdreuben's Avatar
mdreuben
Just ordered a set from the Rack...will be at my installers on Friday.
Should I have ordered springs as well, or will I be OK?
Wheels are the standard 17" runflats on my '05 MCS. I plan on a set of Prada's come spring.
Old Sep 14, 2005 | 06:12 PM
not-so-rednwhitecooper
i counlt ever bring my self to pay 750 bucks for shocks.....it just doesnt seem right
Old Sep 14, 2005 | 07:12 PM
kenchan's Avatar
kenchan
is it adjustable? does the rear top mount need to be drilled to fit?
Old Sep 14, 2005 | 08:59 PM
rkw's Avatar
rkw
I believe that they are a direct replacement for stock shocks, and cannot be used with lowered springs.
Old Sep 15, 2005 | 11:56 AM
Alex@tirerack
they are self adjusting - thats the whole hook, once you ender into a set the valving gets firmer, and when you return back to a more sedate orintation, so does the valving.
Alex
Old Sep 15, 2005 | 06:02 PM
kenchan's Avatar
kenchan
alex stop typing with your toe fingers.
Old Sep 16, 2005 | 08:35 AM
Alex@tirerack
Ok, if I have to!
Alex
Old Sep 16, 2005 | 03:04 PM
tom64taylor's Avatar
tom64taylor
Hi Alex - Just had H-Sport Springs from TireRack.com installed on my 2003 MC, would these help the tightness of the suspension now without losing the crisp cornering I am getting - I certainly don't want to go back to the learch and dive I was getting with OEM springs. I have 42K miles, how long should I wait to change the struts - or is that a "when you feel it feeling crappy" thing? Thanks for the help!
Old Sep 16, 2005 | 06:58 PM
kenchan's Avatar
kenchan
what's missing from your collection is a rear swaybar.
Old Sep 17, 2005 | 10:49 AM
kenchan's Avatar
kenchan
Alex? any input on the mounting? Do you need to drill out the top mounts on the rear?
Old Oct 3, 2005 | 08:13 AM
JeffS's Avatar
JeffS
I just spoke with my "contact" at Koni and while i don't want to quote him directly (since I didn't ask permission), I will paraphrase.
He states that the Mini is very well suited to the FSD, and that it will increase performance while reducing the characteristic mini harshness.
He did say, however, that he wouldn't recommend running them with the car lowered more than 1". I mentioned that I'm running H&R springs and his suggestion was that the yellows would be a better choice, given my current car height. There isn't much shock travel, and hitting the bump-stops would disrupt the FSD system.
Again, this is a person I trust not to BS me and his enthusiasm for the product is making me consider changing my springs so I can run these shocks - maybe the hsports...
RobbyD
Jan 29, 2019 01:22 PM
Manny_cooper
Oct 7, 2015 02:38 PM
rt808
Sep 29, 2015 03:15 PM
Emnotek
Sep 29, 2015 07:37 AM
IQRaceworks
Sep 22, 2015 12:20 PM
