Opinions and Will It Fit
Old Jul 14, 2005 | 05:28 AM
Ozbone's Avatar
Ozbone
I've spent a ridiculous amount of time looking for wheels for my '05 MCS (CR/W) but haven't really come across many that meet the budget and look good. I widened my search recently and came across a Honda (gasp!) HFP wheel that I like. Its a 6.5 X 16 with 45 offset Weight is 19 lbs. It is, of course, a 4X100. So everything looks OK but I'm wondering about the center bore. What does Honda use?
Old Jul 14, 2005 | 06:00 AM
JustGo4It_'s Avatar
JustGo4It_
Honda uses a 56 mm hub. There are very few 16x6.5 rims on the market, SSR's, Monza, and Rota are the few that come to mind. The newest to the party is the Rota Slipstream. Are you trying to stay with factory sizes for autocross? If not wheels that are 16x7 are much easier to find.
http://www.rotawheels.com/wheels.php
Old Jul 14, 2005 | 06:40 AM
Ozbone's Avatar
Ozbone
"Are you trying to stay with factory sizes for autocross? If not wheels that are 16x7 are much easier to find."
While I do want to stay with a 16, its mostly for ride/comfort issues - not auto-x. I've looked at Rotas (and lots of others) but just never saw anything I really liked the look of that fit the budget. These HFP wheels just happen to be 6.5 wide but with the 56 center bore it looks like these would be plug 'n play for the MINI ?
Old Jul 14, 2005 | 08:43 AM
sandtoast500's Avatar
sandtoast500
Please, please...
Are you telling me you've looked at EVERY wheel on the market and THAT is your favorite?!?!?! Don't do that... Plus the hub of the mini is 56.1mm... could be a problem...
Look here:
www.tirerack.com (of course)
www.wheelsdirectonline.com (lowest prices, my favorite)
www.wheelmax.com
www.wheelsnext.com
www.wheelguyz.com
www.e-wheelz.com
www.group5motorsport.com
www.customwheelsdirect.com
www.wheelsboutique.com
www.gotwheelsandtires.com
www.intakeone.com
www.machiii.net
www.streetdreams.org
www.importhookup.com (click on the online store button)
www.seriousauto.com
www.buywheelstoday.com
www.hubcap-tire-wheel.com
www.whalentire.com
www.gruppe-s.com
If you still want the Honda wheels after looking thru all those, then you should get them...
Good luck!:smile:
-Steve
Old Jul 14, 2005 | 08:54 AM
meanboy's Avatar
meanboy
One more
www.tires.com
Old Jul 14, 2005 | 09:55 AM
D_Nyholm's Avatar
D_Nyholm
Originally Posted by sandtoast500
Please, please...
Look here:
www.wheelmax.com
www.wheelsnext.com
www.wheelguyz.com
www.e-wheelz.com
www.intakeone.com
www.machiii.net
www.seriousauto.com
www.whalentire.com
www.gruppe-s.com
Good luck!:smile:
-Steve
Sick list, time to bookmark this thread!!
Old Jul 14, 2005 | 10:02 AM
meanboy's Avatar
meanboy
left out
www.edgeracing.com
www.onlinetires.com
www.victoriatires.com
there are more but I can't think of them.
www.1010tires.com
Old Jul 14, 2005 | 10:29 AM
kenchan's Avatar
kenchan
holly crap! look at that list!
Are you a cousins with minihune?
back to the fitment, most civics and teg's use 4x100 56.1mm center
bore which is the same as our MINI's.
Please, please...
Look here:
www.wheelmax.com
www.wheelsnext.com
www.wheelguyz.com
www.e-wheelz.com
www.intakeone.com
www.machiii.net
www.seriousauto.com
www.whalentire.com
www.gruppe-s.com
Good luck!:smile:
-Steve
Old Jul 14, 2005 | 10:49 AM
Ozbone's Avatar
Ozbone
Man, now I really feel much better .... and I thought I spent alot of time looking at wheels!
And thanks kenchan for the fitment answer.
Please, please...
Look here:
www.wheelmax.com
www.wheelsnext.com
www.wheelguyz.com
www.e-wheelz.com
www.intakeone.com
www.machiii.net
www.seriousauto.com
www.whalentire.com
www.gruppe-s.com
Old Jul 14, 2005 | 12:18 PM
sandtoast500
Originally Posted by meanboy
left out
www.edgeracing.com
www.onlinetires.com
www.1010tires.com
well, I left those out because most of the sites I listed sell the same wheels as those but way cheaper.:smile:
Old Jul 14, 2005 | 01:07 PM
apexer's Avatar
apexer
I like the look of those wheels although a little heavy @ 19lbs but, should be plenty strong.
Mini hub is 56.1mm which means you'll have to bore out the center hole. I'm sure it wouldn't cost much but, I'd have it done by a machine shop.. don't think I'd tackle it with a dremmel.
You should also check the taper of the lug hole as compaired to the taper of the Mini's lug bolt. They may be the same... I just don't know.
Old Jul 14, 2005 | 01:12 PM
not-so-rednwhitecooper
you could get rid of .1 MM with a file!
to take it to a machine shop like where i work and use a mill ( I use a Thompson) it would cost about 25 bucks a wheel to mill .1 MM off because of the size of the wheel, needs a special magnetic chuck to hold it down.
Old Jul 14, 2005 | 03:59 PM
kenchan's Avatar
kenchan
Just hammer it on with a 5lbs mallet and you don't even have to use lugs! 1lb weight savings. j/k
Old Jul 14, 2005 | 04:48 PM
rkw's Avatar
rkw
We are discussing cast automobile wheels, not fine machinery parts. Maybe I don't know what I'm talking about, but I doubt that the bore is even manufactured to a 0.1 mm tolerance. I would guess that the bores in the 4 wheels already vary by than 0.1 mm just between each other. Chances are that the wheels will fit perfectly.
Old Jul 14, 2005 | 05:14 PM
meanboy's Avatar
meanboy
Oh, I didn't list them so the OP could buy them. I listed them so he could look at styles.
BTW, edge racing is pretty cheap, but 1010 isn't.
Old Jul 14, 2005 | 07:14 PM
gstockmini's Avatar
gstockmini
The stock Honda wheels WILL fit the MINIs hub. I can say from firsthand Honda-to-MINI wheel-swapping experience, and having owned 9 Civics of various years and models.
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
boostedhaze
Jan 2, 2018 07:26 PM
xpunisherx
Aug 10, 2015 10:50 PM
rphox2003
Aug 5, 2015 11:34 AM
