Need advice on run flats
Old Jan 25, 2005 | 02:24 PM
fuv's Avatar
fuv
Went to my local tire company (Town Fair Tire in Natick, MA) and told them I wanted to purchase a new set of wheels and tires. I have MCS with stock 16" and run flats. I want new set to be 17" with normal tires (non run flats) and the sales guy said he wouldn't do it because of vibration issues. He said I have to use run flats. He said he had a customer with a MCS and that he switch him to non run flat tires and because of the suspension there was vibration problem and he had to switch him back to run flats. Is this possible?
Old Jan 25, 2005 | 02:33 PM
tontobird's Avatar
tontobird
Nonsense, hundreds, if not thousands of us have switched to non run-flats, 15", 16", 17", in fact I regularly switch between all three sizes and both types of tires with ABSOLUTELY NO PROBLEM!
Old Jan 25, 2005 | 02:37 PM
fuv's Avatar
fuv
thanks... I didn't think there would be an issue with this... just wanted to check in with the rest of you to be sure no one was having this problem
MarkS's Avatar
MarkS
That makes no sense. Plenty of people are using non-runflats on MCSs and there's nothing inherent in the suspension that requires runflats. Maybe his customer had a vibration problem because they didn't balance the tires properly.
Mark
Old Jan 25, 2005 | 02:51 PM
MSFITOY's Avatar
MSFITOY
They want you to cough up extra bucks for the runflats. Don't fall for it. I have two seperate sets of 17" (Parada's/Kumos) and both are miles ahead in comfort and performance
Old Jan 27, 2005 | 07:59 AM
bergens's Avatar
bergens
If the guy with the vibration problem switiched to an aftermarket wheel (as you plan to) while mounting non-run flats and didn't use a centering ring (the Mini wheel is hub-centric) with the new wheels then you will have vibration problems.
Old Jan 28, 2005 | 07:18 AM
fuv's Avatar
fuv
What is Hub Centric?
Old Jan 28, 2005 | 07:55 AM
Alex@tirerack's Avatar
Alex@tirerack
Read up on centerbore here!
Alex
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
