TPMS options?
TPMS options?
Just want to get updated with this.... Among the many Mini parts suppliers, these sensors for my 2013 JCW can be found for around $100.00 each. Most replacement sensors for American cars can be purchased in the range of $20-40.00 each. Are the Mini sensors that different to warrant 2-5 times the cost of the American car sensors, especially when all these TPMS are manufactured by only a limited number of companies? I found a set of HUF RDEO12V21, 433MHz, IntelliSens, preprogrammed, OE sensors for $55.00 ea, shipped. The ad states that these TPMS are OE sensors for my car. Has anyone else used these? And, do they work properly once installed? If not, are there any other options for TPMS rather than the units for $100.00 each? Thanks
Well....the "Sticky" from TireRack, dated 11/08/06, about TPMS states, "All BMW valve sensors are currently being produced by BERU and are sold by us in two parts: the sensor component and the metal valve." is out of date.
The less expensive TPMS I located is manufactured by HUF. After reading Minnie.the.Moocher's post I Googled BERU to discover that BERU was the tire pressure monitoring system sector of Borg Warner bought out by HUF in early 2012.
I realize now that I was looking at the exact same TPMS priced at $51.00ea w/free shipping, on TireRack.com and $100.00ea on other vendors websites. Way to go TireRack! Hum.....I wonder if I can get this kind of deal on the NM Engineering wheel and tire pkg I'm thinking about buying? Hint...hint.
I'm glad I asked...and glad Minnie.the.Moocher responded. Thank you!
Rich
Rich
dunno how much you've 'searched' here on NAM for threads on this
but I can think of two discussions in the last few months started by folks who bought TPMS sensors "at good price" and "guaranteed to work" and came here looking for relief when they didn't ....
for example, the frequency used by MINI in the sensors has changed several times so if your seller is not asking details about when built I'd get suspicious.
I recommend looking up the listing for TPMS sensors at OUTMOTORING and reading their notes if nothing else ....
https://www.outmotoring.com/mini-coo...nitor_set.html
"Please note, as of the Sept 2009 build date MINI has a different frequency for the TPMS sensors. Please note the option on the drop down menu for build date and slight price change for the newer TPMS kit. Also, the Gen3 MINI ("F" series models) use a different kit as well. Please select accordingly."
For those looking for TPMS replacements, if you have a Costco in your area you can call and ask what their price is for your model. They will do the install and reset.
If you go to some shops they may charge for the reset or relearning for TPMS sensors.
So consider the total cost, parts, labor and reset.
Some shops don't handle or aren't familiar with all brands of TPMS and some can reset only certain brands. Also if you buy your own parts and it fails the shop won't warranty the part.
Amazon is impersonal Amazon. I believe you can get great products at great prices thru Amazon, and I also believe that if you are not knowledgeable about what you are wanting to purchase you can wind up with a product that will not perform and disappoint. Know what you are buying before you shop Amazon.
The ones I got from Tire rack with my new wheels and tires were much less than $100 each (installed) and work fine.
got mine from here and was cheaper than $100 each
http://www.tpmsdirect.com/
vetsvette: $50 each is best price ive heard of!
EDIT: this is the price for the newer ones. The older ones (I forget when the change was, something like 2010?) are a bit more at $71ea
Singha
Aug 25, 2011 11:44 PM
R50/53 Good options/bad options
MedicMan55
Aug 20, 2006 03:19 PM
