pzero nero ALEX
Old Oct 17, 2004 | 03:30 PM
trplezero's Avatar
trplezero
pzero nero ALEX
Alex....
im wanting to get the Roja Formula 5's white if that matters... im have seen the 245-45-18 Pzero Nero Pirelli.. Im working at the Plant here in Rome ga... Im wondering if i will have any rubbing problem if i decide to run those tires.. Thanks
david
Old Oct 18, 2004 | 12:41 PM
Alex@tirerack's Avatar
Alex@tirerack
245/45 is VERY agressive (but not for a 740I - just kidding) on Mini's
215/35 is my 18 inch size recomendation
Nero is $133 ea!
Originally Posted by trplezero
Alex....
david
Old Oct 18, 2004 | 06:39 PM
trplezero's Avatar
trplezero
ok you say very aggressive... does that include rubbing issues?? So which Pirelli tire would you recommend to solve this for me.. thanks david
Old Oct 18, 2004 | 06:42 PM
kyriian's Avatar
kyriian
with or without trimming, you'd be literally rubbing against the wheel well, or worse the suspension
the widest i've ever seen is 235/40 on 17s i believe....
Old Oct 19, 2004 | 08:20 AM
Alex@tirerack
Run 215/35 for 18's
Rubbing would be the understatment.
Same tire Nero M+S 215/35/18 - minimal rub if any!
Alex
Old Oct 19, 2004 | 08:39 AM
Kyle's Avatar
Kyle
245/45 18 is HUGE. Chances are it will not fit a MINI no matter what you do. More than likely it'll rub on the shock body/strut housing on the inside AND the outer wheel well. Even if you do get it to fit somehow, the rolling diameter of that tire will be around 26.7 inches, which is more than 10% larger than the stock ~24 inch diameter. That tire is just a poor choice for a MINI, I'd seriously recommend against trying to fit it.
Old Oct 19, 2004 | 08:57 AM
Bisch's Avatar
Bisch
Originally Posted by Kyle
245/45 18 is HUGE. That tire is just a poor choice for a MINI, I'd seriously recommend against trying to fit it.
However...if you do decide to "Monster Garage" it and bust out the fenders, post pics!!
Old Oct 19, 2004 | 09:08 AM
kyriian's Avatar
kyriian
wide body kit! maybe a konigsder kit and it SHOULD fit 8.5 inch wide rims, would would translate to a 245 width tire... but everyone's right in saying the speedo is gonna be really off
DaKineMINI
Tires, Wheels, & Brakes
Jun 5, 2003 06:37 PM
Alex@tirerack
Dec 5, 2002 02:43 PM
Alex@tirerack
Dec 4, 2002 05:03 PM
