R56 front brake upgrade
Old Sep 24, 2016 | 02:39 PM
KevinR's Avatar
KevinR
Not sure where to pose this question...
I am working on an R56S front brake upgrade for my '05 R53. The used calipers I bought have torn caliper piston boots. It is my understanding that this is not an unusual occurrence.
I ordered the replacement parts, but I have not been able to find anything online that walks me through the process. Has anyone here done the rebuild process or can you point me to a site where I can learn more about it?
Old Sep 24, 2016 | 02:47 PM
Anakist's Avatar
Anakist
Try one of these.
James
Old Sep 24, 2016 | 02:59 PM
KevinR's Avatar
KevinR
Thanks, but I've already seen those. I was looking for one that specifically addresses the R56 calipers.
Old Sep 24, 2016 | 04:45 PM
disgruntledcow's Avatar
disgruntledcow
Calipers are all relatively the same as far as the rebuild process go. You're going to have to remove the piston, replace the shaft seal, install a new boot and reassembly. Theres not much more to that than that. I doubt the front caliper is a screw type. You'll more than likely need to use compressed air to remove the piston. Reference one of those videos, I'm sure they show this.
Old Sep 24, 2016 | 09:13 PM
808keith's Avatar
808keith
to remove the piston, i used a bike pump.. also replaced the rubber lines with steel braided ones. hard to explain but you'll have to use that cone type adapter for the bike pump to inflate like inflatable ***** in the rubber hose. but make sure you put like a piece of wood on the other side of the piston so when it flies out, it smacks the wood and doesn't damage anything.. hope that made some kind of sense.. putting everything back together, use some brake fluid so you don't damage the o-rings on the piston..
Old Sep 24, 2016 | 10:15 PM
KevinR's Avatar
KevinR
Yes, that does make sense. I think my major question is how the boot attaches to the caliper, which is why I was hoping to find an R56 specific tutorial. I guess it will be fairly self-evident when I take things apart.
Old Sep 25, 2016 | 02:08 AM
Anakist's Avatar
Anakist
The boot expands out into a machined slot and is held out by the piston. Don't try to remove the boot before the piston or you will wreck it. Unclip it from the piston, pump the piston out, pull the boot out.
This shows it pretty well. http://bmwe32.masscom.net/sean750/ca...alOnPiston.jpg
James
Old Sep 25, 2016 | 07:46 AM
KevinR's Avatar
KevinR
Thanks for that pic. It helps a lot to visualize what needs to be done.
Old Sep 25, 2016 | 09:45 PM
Anakist's Avatar
Anakist
I have a pair of calipers disassembled on my bench. LMK if you want pics of anything else.
James
Old Sep 26, 2016 | 11:07 AM
KevinR's Avatar
KevinR
Thanks! The final parts are scheduled to arrive this week and I hope to tackle it this coming weekend. Hopefully it goes smoothly, but if it doesn't I'll probably be back on here trying to pick your brain.
Old Sep 28, 2016 | 01:41 PM
Post up some pics of the rebuild if you can, i did mine on the front of my R52, still on Gen 1 brakes, but for a while i was running the JCW 4 pistons.
NevadaMini
Nov 18, 2024 07:17 AM
Classic Mini Talk
Sep 17, 2016 02:22 PM
nitroracing456
14
Aug 30, 2016 06:01 PM
DAVE!
Aug 27, 2016 10:45 AM
Aug 25, 2016 04:26 PM
