Need help with Lug Adapter
Old Dec 5, 2014 | 07:02 AM
Bendz's Avatar
Bendz
I bought my 2009, MCS JCW about a year ago. It had aftermarket wheels on it and a special adapter to remove the lugs. A couple weeks ago I was working on changing them over to the EOM wheels and Blizzaks in preparation for winter. Well, I boogered up my adapter due to the space being so tight on the aftermarket wheels. So now I have 3 of the 4 wheels replaced with the OEM/Blizzak combo. I have searched the internet, went to the Mini & Volvo/VW Dealer (because it looks like a VW adapter), went to Big O Tires, and a couple local tire shops, and have ordered various adapters that do not work. Big O Tires says they can do it but it'll take a couple hours of labor to try and bust them out. Or they can use their remover tool that will completely trash the wheels.
It has 10-splines on the business end. On the opposite end it has "10.9" stamped on it. Hopefully the attached pictures will help describe it.
If anyone can help it would be greatly appreciated
Attached Thumbnails Need help with Lug Adapter-img_20141205_094809_352.jpg   Need help with Lug Adapter-img_20141205_094858_653.jpg   Need help with Lug Adapter-img_20141205_094906_400.jpg
Old Dec 5, 2014 | 07:59 AM
Capt_bj's Avatar
Capt_bj
I'm guessing the spline end kits OK but the 'lug' end is messed up .. rounded?
I'd weld a socket onto the messed up end . . . even if you need need to grind off some of the messed up end, it will work.
Old Dec 5, 2014 | 08:53 AM
Joeygonz's Avatar
Joeygonz
how about a bolt extractor. i had a rounded bolt before and it worked fine.
Old Dec 7, 2014 | 04:27 PM
Bendz's Avatar
Bendz
I'd weld a socket onto the messed up end . . . even if you need need to ground off some of the messed up end, it will work.
Welding a socket on it worked, thanks for the idea! Had to do a little dremel work on the spline end but it worked.
Thanks!
Old Dec 7, 2014 | 04:46 PM
Capt_bj's Avatar
Capt_bj
most folks don't have easy access to welding so the idea escapes them
glad I could help
Old Dec 7, 2014 | 04:51 PM
Bendz's Avatar
Bendz
I don't have a welder either so I had a friend do it.
Old Dec 7, 2014 | 08:56 PM
SC R60's Avatar
SC R60
Teamwork !!!!!!!
Old Dec 8, 2014 | 06:37 AM
Capt_bj's Avatar
Capt_bj
one must always remember to appreciate friends who have:
pickup truck
welder
lift
strong back
extension ladder
chain saw
and a willingness to help if you buy the beer!
Old Dec 8, 2014 | 06:47 AM
yetti96's Avatar
yetti96
Boats too
pickup truck
welder
lift
strong back
extension ladder
chain saw
freckles81
Jan 15, 2017 06:33 AM
gar56
Nov 15, 2016 06:41 AM
minimofo
Dec 26, 2015 12:03 PM
papawhiskey
Sep 30, 2015 02:50 PM
