Official F56 Wheel Fitment Thread
Old Feb 25, 2016 | 11:05 PM
  #601
Ah gong's Avatar
Ah gong
Originally Posted by walkingdrunken
215/40/18 Continental DWS 06. Nm eng recommended the size.
i still doing some research will my 8" et45 wheel can fit on 225 40 18 PSS tires.hopefully can fit without issue
Originally Posted by ryanschram
All mounted up.
[/url]
nice looking wheels.what size of tire did u use?
Old Feb 25, 2016 | 11:53 PM
  #602
Val P's Avatar
Val P
Originally Posted by gohandbz8
Advanti B1 Lupo
17x7 +45 205/45/17
Beautiful.
What size are these (wheels and tires)?
Old Feb 26, 2016 | 07:48 AM
  #603
BillM's Avatar
BillM
Been reading this thread in the hopes of finding info on decent cheap 17" wheel and size for reasonably light, dedicated track setup for stock sprung MCS. Was thinking Nitto NT-01 probably in 215 width (cheap, wear like iron, decent grip, I have thousands of track miles on them in other car).
I'm guessing Enkei and other sub-$200 wheels are cast -- opinions on these for track? For example, if Kosei made the cheapo K1 in compatible version I'd do it since they're such a known quantity at the track, but they always end up cracking, and are considered throw-away after a few seasons of track use.
I'm guessing widest without risking some rubbing during track conditions would be a 7.5" with a 215 series tire, with stock camber and suspension?
Not looking to go down the rabbit hole with an extensive build, been there, done that.
Suggestions?
Old Feb 26, 2016 | 07:53 PM
  #604
ryanschram's Avatar
ryanschram
Originally Posted by ah gong
I still doing some research will my 8" et45 wheel can fit on 225 40 18 pss tires.hopefully can fit without issue
205/45/17
Old Feb 27, 2016 | 05:49 PM
  #605
vetsvette's Avatar
vetsvette
Moderator
"I'm looking at a set of 17X8 w/45mm offset running 215/45X17 tires. Anyone see a problem with this combo?"
Edit: Wheels came in a couple days ago. Having new summer tires and OEM TPMS fitted tomorrow.
Old Feb 27, 2016 | 06:40 PM
  #606
jobexo's Avatar
jobexo
That's MCT's set up on his Superman Mini. Looks perfect w/ the NM springs.
Old Feb 27, 2016 | 06:54 PM
  #607
mct's Avatar
mct
Yep - works great!!
Old Feb 27, 2016 | 07:10 PM
  #608
vetsvette's Avatar
vetsvette
Moderator
Great, thanks. I'm planning to run the NM springs too.
Old Feb 28, 2016 | 08:26 AM
  #609
randomquickness's Avatar
randomquickness
Suggestions?
You can run an 8" and 225 as long as your offsets are good. And yes, finding affordable track wheels is tough for this car. I've been bugging Apex for a while. Maybe y'all need to bug them too so they will hook us up!
Old Feb 28, 2016 | 05:15 PM
  #610
StnTwnDevil's Avatar
StnTwnDevil
Originally Posted by mct
Yep - works great!!
I'm looking at wheels that are 17x7.5 40et. I believe they poke almost exactly the same as your 17x8 45et setup, just slightly less. No rubbing issues at all after lowering?
Old Mar 3, 2016 | 01:09 AM
  #611
Clutch Wotan's Avatar
Clutch Wotan
Iam just adopting 8x17 to my Cooper S, i have chosen a 10 Spoke design used by Audi. The Wheel is OE and is accepted by TÜV. Milling an Wheel Stud adaptor to meet bore (TÜV again) is in progress.
The aim is to combine Clubsport Suspension & 225/235 with a classy retrolook, the tire size is helpful to handle power above to catapult the car into another league.
The respective tires available for track/Road Federal & DUNLOP
http://renn-reifen.de/images/preisli...ederal_rsr.pdf
Old Mar 3, 2016 | 06:30 AM
  #612
Yep - works great!!
Yea,, looks so good.
Old Mar 4, 2016 | 06:07 AM
  #613
vetsvette's Avatar
vetsvette
Moderator
Attached Thumbnails Official F56 Wheel Fitment Thread-img_1363.jpg   Official F56 Wheel Fitment Thread-img_1364.jpg
Old Mar 4, 2016 | 08:00 AM
  #614
Nice.
Old Mar 5, 2016 | 11:25 AM
  #615
vetsvette's Avatar
vetsvette
Moderator
Just got back from getting my wheels/tires mounted. Crappy cellphone pics, but I like the looks of the wheels. Konig Oversteer 17X8 et45 with Goodyear Eagle F1 summer tires 215/45X17
It'll look better when I get the red calipers.
Old Mar 5, 2016 | 11:59 AM
  #616
mct's Avatar
mct
No rubbing at all
Old Mar 5, 2016 | 03:16 PM
  #617
jobexo's Avatar
jobexo
Perfect! Now lower that bad boy
Old Mar 6, 2016 | 05:31 AM
  #618
jlb's Avatar
jlb
Looks great!
Old Mar 8, 2016 | 05:47 PM
  #619
ARMASPEEDUSA's Avatar
ARMASPEEDUSA
Test fit of the Enkei TS9 17x8 et45 5x112. They fit!! I will upload once the other 3 arrive and I mount tires.
WOW Thats a tight fit!!
Old Mar 9, 2016 | 08:33 AM
  #620
StnTwnDevil
For those of you who have the 18x8 45et setup, Is there enough space to go 1mm in towards the strut? I found an 18x8 wheel with 46et. I was looking at R99's pics showing the space between the strut and the wheel, and it looked very tight.
Also, anyone recommend coil overs that will maintain a safe distance from the 8" width wheel?
Old Mar 10, 2016 | 07:11 AM
  #621
randomquickness
ADMIN: I believe this thread needs to stay within the 3rd gen sub-forum. The F-chasis has wheel specs unique to it. Placing it under "minis in general" will just cause redundant wheel threads to start popping up in the 3rd gen sub-forum
Old Mar 10, 2016 | 09:41 AM
  #622
dlabout's Avatar
dlabout
Hello All,
First post on the forum. Have had my Mini since August of 2014.
2015 Mini Cooper S.
I am looking at summer tires and rims and, as you would expect, I'm here to get an opinion on fit. I've found a set of 18x8 et35. My concern is rubbing on the wheel well with factory suspension. Tire's I'm guessing will be a 205/40/18.
Thoughts?
Thanks,
-Doug
Old Mar 10, 2016 | 09:58 AM
  #623
Originally Posted by dlabout
Hello All,
2015 Mini Cooper S.
Thoughts?
Thanks,
-Doug
Welcome, What wheels ? Do you have them already to do a test fit.
Old Mar 10, 2016 | 10:59 AM
  #624
dlabout's Avatar
dlabout
The wheels I'm looking at are Advanti FS Fastoso. I found them close to where I live. The gentleman had them on a VW CC. I just want to make sure that they will fit. They will poke almost an inch beyond the stock 16 inch rims. The price is right, but wasting his time and mine doesn't seem right.
Stock Fastoso
Diameter 620.9mm 621.2mm
Circumference 1950.6mm 1951.6mm
Poke 40.9mm 66.6mm
Inset 136.9mm 136.6mm
Speedo error 0% -0.05%
Reading at 30mph 30mph 29.99mph
Reading at 60mph 60mph 59.97mph
Ride height gain 0mm 0.15mm
Arch gap loss 0mm 0.15mm
Old Mar 10, 2016 | 01:33 PM
  #625
ryanschram's Avatar
ryanschram
I agree!!!
