Official F56 Wheel Fitment Thread
Old Aug 27, 2015 | 12:27 PM
  #376
honderpilot's Avatar
honderpilot
Ok cool that's exactly what i was thinking. Thanks, Greg.
Old Aug 28, 2015 | 11:07 AM
  #377
VicSkimmr's Avatar
VicSkimmr
Originally Posted by honderpilot
Total noob question. If you change wheel size then then you match it with a tire with either thicker or thinner sidewall. I thought this should keep the overall diameter the same. If it's the same overall diameter then how does it make the car ride higher or lower? What am I missing? Thanks
It would, absolutely. But my intention was to make the car lower, so I went with the smaller wheel and then matched it with a tire that kept the same aspect ratio as the 18's did (to help it look aesthetically right to my eyes) which let me then lower the car to get rid of the new excess wheel gap.
Original - 18x8 - 205/40/18
New - 17x8 - 205/40/17
I'm not sure exactly how much I was able to lower the car, I didn't measure. Low enough that I wouldn't want to go any lower. I can easily make it over speedbumps but have to watch out for debris in the road if it's taller than a couple of inches. I straddled a dead snapping turtle last week, my car smelled like a corpse for days :(.
Old Aug 28, 2015 | 07:27 PM
  #378
#pepper#'s Avatar
#pepper#
New wheels and tires
Well, after much thought, discussion, number crunching (love spreadsheets) and soul searching, I've finally decided on a set of wheels and tires. Whew, didn't know it would be so difficult. They are Enkei RPF1 with Bridgestones RE-71R. I stayed with the 17" setup. Can't wait to get them mounted to the MINI.
Old Aug 28, 2015 | 08:58 PM
  #379
honderpilot
Can't wait to see some pics!!!
Old Aug 31, 2015 | 02:38 AM
  #380
jamesdean's Avatar
jamesdean
I found going slightly larger on the tire size helped a tad on the gap. 225/45/17 on 17x7.5 et45 rim
Old Aug 31, 2015 | 04:14 AM
  #381
honderpilot
Do you just live with speedo error or do you get it recalibrated?
Old Aug 31, 2015 | 06:03 AM
  #382
VicSkimmr's Avatar
VicSkimmr
Just live with it, it's such a minor difference. They're already naturally off by about 5 mph from the factory, so I just measure it with my GPS for a few days and then account for the difference on my own.
Old Aug 31, 2015 | 06:47 AM
  #383
Ryephile's Avatar
Ryephile
I found with a 205/45-17 that the speedo is about 3% off at an indicated 74 MPH, and the OBDII output perfectly matches GPS [72 actual]. This is much more accurate than older gen MINIs and definitely more accurate than old school Bimmers.
Old Aug 31, 2015 | 10:16 AM
  #384
#pepper#'s Avatar
#pepper#
Finally got the RPF1/RE-71s mounted. Here's a before and after shot. And for those interested I included a backside clearance shot to the front strut. Sorry about the after shot, it's sunny today.
Before - 205/45R17 500TW on factory wheels 17 X 7 et:54
After - 215/45R17 200TW on Enkei RPF1 17 X 7.5 et:48
Oh, and I'm coming clean. I did something I haven't done in 36 years, bought another tire brand other than Michelins.
Old Aug 31, 2015 | 01:36 PM
  #385
honderpilot
Looks awesome! Nice wheels. Are you lowered?
Old Aug 31, 2015 | 04:01 PM
  #386
VicSkimmr's Avatar
VicSkimmr
Fantastic!
Old Aug 31, 2015 | 04:51 PM
  #387
DiGiPiMP's Avatar
DiGiPiMP
That angle doesn't do the car nor the wheels justice. Looks awesome. Just get some center caps to match.
Old Sep 1, 2015 | 05:01 AM
  #388
DiGiPiMP's Avatar
DiGiPiMP
I have a question about the TPMS. did you move the sensors from the old set? I want to buy a winter set with TPMS from Tirerack.com, there's a comment on there that they can be adapted to the car by following cars manual. I always though that only dealers can program/reset TPMs, or programming and resetting TPMS are different things? Thanks
Old Sep 1, 2015 | 05:17 AM
  #389
honderpilot
+1
Old Sep 1, 2015 | 06:55 AM
  #390
#pepper#'s Avatar
#pepper#
I bought new TPMS sensors and had them delivered installed on the wheels with the tires. After mounting the new assemblies just go into the MINI connected system to vehicle info / vehicle status / reset (tire pressure system). While you drive the system will read the new sensors and reset the system. I started to do just that, take the existing sensors and move them to the new wheels but plan on exchanging them more than once a season.
Old Sep 1, 2015 | 05:02 PM
  #391
jamesdean's Avatar
jamesdean
As long as they are the correct sensor just go into the car menu in the stereo and reset them
Old Sep 1, 2015 | 11:24 PM
  #392
blue al's Avatar
blue al
Is mixing tyre sizes an option with tps
I assume so ?
I ask as I have a pair of new 225/45/17 I would like to use with 215/45/17
These will be fitted to 7.5 x 17 et 43 which I hope will clear the jcw calipers
Old Sep 2, 2015 | 05:18 AM
  #393
jamesdean's Avatar
jamesdean
I assume so ?
Size does not matter. Brake clearance will depend on wheel shape.
Old Sep 2, 2015 | 08:50 AM
  #394
blue al's Avatar
blue al
I keep telling my wife that
Looking at BBS Wheels
Old Sep 2, 2015 | 09:16 AM
  #395
F55MidnightBlackCooperS's Avatar
If going 18x8 a 45 et only, 50et and 40et will restrict you to a 205/40/18 tire.
Loving the look that the Bbs wheels have on the F5x models.
Old Sep 2, 2015 | 11:41 AM
  #396
honderpilot
Will a 40 sidewall on an 18 keep the diameter? Is that what's recommended?
Old Sep 2, 2015 | 12:09 PM
  #397
205/40/18 or 215/40/18 any more will rub and less will stretch on the rim.
Old Sep 2, 2015 | 12:51 PM
  #398
honderpilot
Cool, thank you.
Old Sep 3, 2015 | 07:35 AM
  #399
ChrispyMINI's Avatar
ChrispyMINI
Hi All,
As a wheel fitment noob, I have learned a lot from reading this thread on a regular basis. The only thing, is I may have not learned enough and I am not confident in my recent purchase. Some reassurance would be great! In hindsight, I probably should have verified my setup before actually buying it.
Vehicle: 2014 MCS
Wheels: Niche Citrine M155 18x8 et42
Tires: Continental ExtremeContact DWs 215/40/18
Suspension: BC BR Coilovers
Will This work without spacers? Any comments/suggestions?
Old Sep 3, 2015 | 09:33 AM
  #400
VicSkimmr's Avatar
VicSkimmr
That should be just about perfect. You'll be cutting it close with your tire on the strut in the front depending on how low you go, but I don't think you could get a better sized wheel than that. I think the BC coils come with a small spacer (5mm maybe?) you can use in the front if it rubs.
Oh **** those wheels look awesome! I've never heard of that company before. The center bore on the wheels might be a slight issue, I can't remember what the F56 hub bore is.
