Installing steel braided lines
Old Dec 1, 2013 | 12:40 PM
BC_Rob's Avatar
BC_Rob
Going to install steel braided brake lines for the first time on my 2007 MCS and was wondering if I should use Teflon tape on the threads when installing.
Thanks for you help.
Rob
Old Dec 1, 2013 | 12:59 PM
Mcameron's Avatar
Mcameron
unless for some reason the manufacturers directions indicate you not to, i definitely would.
you need some sort of seal between mating surfaces of the threads, otherwise you are just asking for leaks.
Old Dec 1, 2013 | 01:14 PM
BC_Rob's Avatar
BC_Rob
That's what I thought, but I haven't seen it mentioned in any of the threads I've read.
Old Dec 1, 2013 | 01:15 PM
jasonsmf's Avatar
jasonsmf
Your brake lines seal at the flare not on the threads. You do not want to use any sealant sealant on brake line fittings.
Jason
Old Dec 1, 2013 | 04:34 PM
danjreed's Avatar
danjreed
Never use thread sealants on brake lines.
As noted the flair fittings will seal just fine.
Old Dec 2, 2013 | 06:06 AM
v10climber's Avatar
v10climber
Old Dec 2, 2013 | 06:52 PM
DesertDog's Avatar
DesertDog
As stated no need for thread sealant. I would recommend using flare nut wrenches. You will be able to loosen and tighten the flare nut properly without rounding the nut.
Old Dec 2, 2013 | 06:54 PM
BC_Rob's Avatar
BC_Rob
Thanks everyone... I appreciate the responses.
Rob
Old Dec 11, 2013 | 02:54 PM
kacken's Avatar
kacken
Hey there, quick question. What brake lines are you using? I tried to do a little digging and wasn't able to find anything specific in my initial search. Any recommendations on top performing brands?
Old Dec 11, 2013 | 03:00 PM
ashchuckton's Avatar
ashchuckton
I bought mine from Detroit Tuned. Perfect fit no issues with them.
http://www.detroittuned.com/detroit-...l-brake-lines/
Old Dec 11, 2013 | 10:14 PM
BC_Rob's Avatar
BC_Rob
ECS Tuning
http://www.ecstuning.com/Mini-2007-C...nes/ES2593424/
Old Dec 12, 2013 | 12:28 PM
kacken's Avatar
kacken
http://www.nm-eng.com/262/4/0/1444/n...ake-lines.html
anyone had any experience with NM Engineering? It seems as if their stuff tends to be on the expensive side, but if its worth it, then I don't see why people wouldn't spend the money. Is there a huge difference between a $100 kit and a $200 kit, what would justify it being twice as much?
Old Dec 12, 2013 | 07:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
FYI we have our famous WMW Brake lines on sale this week. These are the same lines that are mandatory on ALL B spec MINI race cars.
http://waymotorworks.com/stainless-s...5-r56-r57.html
Old Dec 12, 2013 | 08:54 PM
BSTINS's Avatar
BSTINS
Hey Way do you sell just the lines for the rear?
Old Dec 12, 2013 | 10:51 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
for the WMW SS lines. Perfect fit and great price.
Old Dec 13, 2013 | 09:52 AM
cactusjk's Avatar
cactusjk
Just ordered a set!
Old Dec 13, 2013 | 10:36 AM
Originally Posted by BC_Rob
Those are our ECS Lines
We have Gen 2 R55, R56, R57, R58 & R59 MINI Brakes lines set ( Front & Rear). Also sell fronts and rears. All our ECS brake line are currently part of our Holiday Sale.
http://www.ecstuning.com/Search/SiteSearch/001959ECS/
For the Gen 1 R50 R53 MINIs : 2002 up to 4/2003 production:
http://www.ecstuning.com/Search/SiteSearch/ES2608944__ES2608379__ES2608943/
For the R50 R53 MINIs : 4/2003 on & R52 MINI Convertibles :
http://www.ecstuning.com/Search/SiteSearch/ES2608378__ES2608379__ES2608382/
For the Countryman & Paceman Models
http://www.ecstuning.com/Search/SiteSearch/002436ECS/
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
