Changing from RunFlats to Regular, do you have to replace all 4?
Old Sep 3, 2013 | 11:56 AM
davidall99's Avatar
davidall99
Hey all, Newbie here and need some advice. I've had my clubman S for about 4 months. 2008 with only 24k miles. Got a flat yesterday (memorial day) and didn't realize I had run flats. The tire has a huge gash and won't hold much air. So, after reading a bunch of these forums, I realized I should just replace the tires with non-runflats (my front two tires were in need of replacing anyway), but my back tires are still ok.
Should I replace all four since the they are different type of tires?
Any new 195/55 - 16's that are hot right now? (commuter / non-track / good in rain)
Can I "really" drive on the run flat for 10 - 20 miles?
Thanks all!
Old Sep 3, 2013 | 12:00 PM
Braminator's Avatar
Braminator
It is always a good idea to change all for to avoid possible handling issues with different makes, models and tread patterns. You will love nonrunflats.
Old Sep 3, 2013 | 12:01 PM
Braminator's Avatar
Braminator
Yes you can run on runflats for actually about 50 miles, but the tire is no good after you used them that way.
Old Sep 3, 2013 | 12:04 PM
MINILLA's Avatar
MINILLA
Originally Posted by davidall99
should i replace all four since the they are different type of tires?
Thanks all!
yes!
Old Sep 3, 2013 | 06:47 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You really should, if you don't the car will handle odd when you hit bumps especially when turning. I know cause I had a MINI like this for awhile and it def didn't feel right.
Old Sep 3, 2013 | 08:52 PM
hsautocrosser's Avatar
hsautocrosser
Consider 205/50-16 for more choice. TireRack.com has extraordinary information.
Old Sep 12, 2013 | 07:53 AM
t-c-b's Avatar
t-c-b
yes
Old Sep 13, 2013 | 02:11 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Depends on your budget-
In 205/55-16 which will fit stock wheels and suspension-
see
http://www.tirerack.com/tires/survey...wws=N&showcm=N
The top 5+ are all good but with various prices, best compromise commuter tire is Continental ExtremeContact DWS (good comfort and good in nearly all weather including cold) while Bridgestone RE970AS is good all round tire with value, emphasis on good handling in any weather.
Michelin Pilot Sport A/S 3 (Ultra High Perf All Season tire), W or Y speed rated
and
Michelin Pilot Sport A/S 3 (High Perf All Season tire) V or H speed rated
Are both new tires that will perform well for street use. The V or H speed rated versions are cheaper and come in OEM sizes, they still work fine and are a good value.
Alkaidovich
Jan 30, 2021 01:35 AM
eliseo1981
Jan 28, 2021 02:45 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
