17x8 et42 on 05 R53?
Old Mar 20, 2013 | 09:02 AM
Hochspannung's Avatar
Hochspannung
would a 17x8 et42 fit on my r53.
205/40/r17 tires..
I am on stock suspension but plan on getting CO's
Old Mar 20, 2013 | 09:04 AM
Hochspannung
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ398802592
these are the wheels
has anyone run something that looks like this?, i cant find pictures of what it would look like on my car
Old Mar 20, 2013 | 09:17 AM
Braminator's Avatar
Braminator
They will fit and you should be fine.
Old Mar 20, 2013 | 09:28 AM
Hochspannung
ok thanks, not relly sure if i like them though
Old Mar 20, 2013 | 10:35 AM
Creeve's Avatar
Creeve
You will almost certainly need a small spacer later on when you get coilovers.
Old Mar 20, 2013 | 11:45 AM
Hochspannung
Okay, The wheels will extend 13 mm further toward the strut. i checked on some offset calculator earlier.
the ad says it comes with small lugs to fit the small holes? Will the bolts from the mini be able to fit through there? does anyone know anything about that; I've never heard of that being a problem before.
Old Mar 20, 2013 | 03:24 PM
Hochspannung
Going to pick these up in about an hour. comes with tuner bolts and i just picked up some hub centric rings so they fit nice. going to look a lot bigger than my R84's lol
Old Mar 20, 2013 | 03:32 PM
Braminator's Avatar
Braminator
The wheels will extend 13 mmfurther toward the strut.
They will be further from the strut and closer to the fender. Post some pics when you have them on.
Old Mar 20, 2013 | 03:54 PM
maxmini's Avatar
maxmini
These are 17 / 8 et 42 Hamman with 215/45/17 BFG's . I am about 1.75 lower than stock you should have no issues
Randy
Old Mar 20, 2013 | 04:07 PM
Creeve's Avatar
Creeve
Incorrect, they will be closer to both the strut and the fender.
Old Mar 20, 2013 | 04:12 PM
Braminator's Avatar
Braminator
I just saw that. I thought I put both on there. oops
Old Mar 20, 2013 | 09:12 PM
Hochspannung
Just installed them in the dark lol. Took it for a test drive and all is good.
Also I have to add that the difference from the runflats to these new non runflats is AMAZING!!! soooo quiet and smooth over bumps. The runflats literally were starting to give me a back ache.
I'll post up pictures tomorrow after I give my car a wash.
I need to make some sort of center cap. I was thinking pop cans if I can make them stick in there somehow.
Old Mar 22, 2013 | 09:01 AM
Hochspannung
potterstein
Dec 30, 2024 05:18 PM
rtk90
Aug 29, 2019 09:08 AM
Gremothra
Sep 9, 2015 08:42 PM
Anakist
Australia
Sep 8, 2015 03:32 AM
potterstein
Sep 4, 2015 09:52 AM
