Newb in need of wheel/ suspension help
Old Apr 5, 2012 | 04:58 PM
Dperez87's Avatar
Dperez87
Hey folks new here, just leased a 2012 laser blue hardtop, I'm looking to Do some wheel and suspension work but I'm new to all this, I've done some research here and found some really good threads but a lot of it I don't understand yet hence the (newb). So I was wondering if some of you wouldnt mind helping me out here. So here we go..
It's a lease so I can't do any permanent work like dremeling etc etc
I want to try and achieve an aggressive stance that can still be a daily driver.
I don't have a money tree in my backyard either so I'm trying to do this on a budget.
I really like the xxr 527 17x8.25 wheels and I found them on Discounttires.com with 205/40/17 tires for $790 shipped.
I also plan on getting coilovers, probably Megan's since they come with the front camber plates.
I've read that I will need adjustable rear control arm also.. Is this true? And what brand should I go with on a budget?
Will I need spacers and if so what size?
Will I need longer wheel bolts? If so what size?
How low could/should I go for a aggressive appearance but still reliable daily driver.
So that's about all I can think of right now and sorry if these are stupid questions, any help would be greatly appreciated thanks
Oh and this thread gave me the idea for the wheels I love how the front sits
http://www.motoringunderground.com/f...ad.php?t=22568
Old Apr 6, 2012 | 09:36 AM
Dperez87's Avatar
Dperez87
Anyone?
Old Apr 6, 2012 | 09:50 AM
FAMILYMANR53's Avatar
FAMILYMANR53
Well, with coilovers, wheels, tires alone if you do the work yorself your looking at almost 2k. For the stance your looking for you will probablly need adjustable camber plates and adjustable rear control arms which for the set your looking at another $400-$500 just for the parts. I have seen them on Ebay for as low as $160 a set.
First question is really what is your total budget that you are looking to spend? From what it sounds like you could be around 3k plus with everything that you want.
That would help people figure out what type of setup might be good for you.
Also, people will ask you what the offset is on the XXR wheels that you will are interested in.
Check out the 8" roll call thread as well for some information.
As far as the mini that is in the link you posted that is some serious negative camber! Plus i dont think the tire size you mentioned above will give you the stretch look (i could be wrong).
Old Apr 6, 2012 | 02:46 PM
Dperez87's Avatar
Dperez87
$2,000 is around what I wouldnt mind spending. I just purchased the wheels today for 800 so that leaves me with 1200 to spend, I know the Megan's go for about 900 and the come with front camber plates so I'm pretty sure I can get those rear control arms on eBay for 160-200 and I'm in budget. Me and my buddy will be installing them so I save on labor.The offset on the wheels are +25
I'm hoping for some sort of stretch.. I've read that anything lower is a really harsh ride.
Old Apr 6, 2012 | 09:22 PM
G0LDENDOMER's Avatar
G0LDENDOMER
here is my r53, dropped on megans with the 527's wearing 205/40s
Old Apr 7, 2012 | 06:23 AM
richardsperry's Avatar
richardsperry
Man are you screwed. 17x 8.5 with a offset of 25mm? Good luck with that.
The stock 17's are 7" wide with an offset of 48mm. You are trying to fit a wheel that is 1.5" wider and will stick out almost another 15/16's".So the wheel will stick out 15/16's" + another 3/4" (1/2 the width of the wheel increase)
Congratulations, you just screwed up the ride and handling of your leased car.
Oh, and spacers REDUCE the offset even more so that's not what you want...
Old Apr 7, 2012 | 06:57 AM
Creeve's Avatar
Creeve
Oh, and spaces REDUCE the offset even more so that's not what you want...
You know there are ways to warn the OP about possible problems and drawbacks (which I agree there are) without being so nasty.
Old Apr 7, 2012 | 08:43 AM
richardsperry
I don't think I was being nasty.
The OP says he's a newb. fine, He did research? That's where I start having a problem. What research would ever turn up a recommendation of a 17x8.5" wheel with a 25 offset?
The link shows a car with stupid wheels, tires and owner. Just because you can, doesn't always mean you should... Stanceworks rules!!!
All it takes is one hard corner, the tire comes off the bead, he slides across the line and takes out a small family. There really is a reason tire companies tell you what wheel width works with what tire size. Stretch and poke is stupid and dangerous.
Personal injury lawyers love clear cases of culpable negligence.
Then he mentions Megan coilovers? Since they come with camber plates... Complete and utter junk.
I'll check back in 6 months and see how that's working out for him.
Old Apr 7, 2012 | 10:18 AM
G0LDENDOMER
Seriously richard? I've been running megans for two years now without problems. If you don't like my wheels, then why bother commenting? OP asked to see the wheels on another car, and thats why i posted. I wasn't looking to be scolded on the negatives of running a stretch or poke.
I'm fully aware of all that can happen, and I'm fine with it. Theres a chance i could drown in my pool this afternoon, but im still gonna go swimming. Its not a racecar, so take your opinion and gtfo
Old Apr 7, 2012 | 10:31 AM
G0LDENDOMER
https://www.northamericanmotoring.co...ml#post3474681
OP, there is a link to my thread with more pictures. Richard, feel free to browse and flame at will. By the way, im wearing a red shirt today. Could you tell me how dangerous and stupid I look in red?
Old Apr 8, 2012 | 07:28 AM
Dperez87's Avatar
Dperez87
hey gold i appreciate the pictures and link, looks really good, did you need spacers at all? i should have the wheels in a few days, so i wanna order anything else i would need before hand.. and i should be order the coilovers in another week or two.
Old Apr 8, 2012 | 09:13 AM
Dperez87's Avatar
Dperez87
Also, was the lug conversion necessary?
Old Apr 8, 2012 | 09:44 AM
G0LDENDOMER
I dont have spacers at all. And the lugs are a yes and no answer. Your stock bolts wont fit, but you can buy replacement bolts with a smaller head. I opted for the conversion just because i wanted red lugs
Old Apr 8, 2012 | 10:07 AM
Dperez87's Avatar
Dperez87
ok cool, would you happen to know where i can find smaller head bolts in the right size? i checked a few places and they all seem to be the same sized head but different lengths
Old Apr 8, 2012 | 10:20 AM
G0LDENDOMER
Check ebay, but make sure you get the correct thread pitch, r56s are different
Old Apr 8, 2012 | 11:04 AM
llewellyn's Avatar
llewellyn
I'm interested to see how they fit with that stretch - according to the wheel offset calculator (see link below), that size (17x8.25) with a 25mm offset will poke 39mm, which works out to 1.53". You definitely shouldn't need any spacers, or they will poke that much more.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Apr 8, 2012 | 11:51 AM
G0LDENDOMER
They poke a pretty good amount
vulkandino
Oct 31, 2015 08:29 PM
GAT
Oct 4, 2015 07:27 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
