Repairing a bent wheel
Old Feb 23, 2011 | 12:21 PM
ThumperMCS's Avatar
ThumperMCS
So I've had a set of wheels waiting to be put on for almost a year now, along with fresh tires as well.
Just been waiting till I burn through my current tires on my stock rims, to make the switch. Now that my tires are on their last legs, one of them won't hold air...so it is time to put the new wheels/tires on.
Problem being, one of the wheels is bent.
I got the wheels (18" Exel TZ-10) from a friend of mine who never put them on, who in turn got them from one of his friends who never used them either. However, unknown to either of us, one of the lips on the wheels is actually bent slightly as seen below:
So I had just planned on buying a new one to replace it (they are pretty cheap). But WheelMax.com is the only place I know of to get one, and I do not know what their deal is, but their online order system does not work and I cannot ever get a hold of anyone there...so I'm thinking they're out of business or something. So seeing as I need them on NOW...I need to get it fixed.
Is this something that is fixable...for a reasonable price? If so, how much do you think? I also need to get the bolt holes bored out to 14mm, cuz they are drilled for the pre-2007's 12mm.
Old Feb 23, 2011 | 02:33 PM
Project_2501's Avatar
Project_2501
Yes to both being easily fixed and for only a little scratch. :thumbup: Shouldn't be more then $40-50.
Old Feb 23, 2011 | 03:01 PM
ThumperMCS's Avatar
ThumperMCS
What type of place do I take it?
Old Feb 23, 2011 | 04:44 PM
slinger688's Avatar
slinger688
Thumper,
Alex@Tireack.com gave me a couple of names of wheel repair places that are "good". I do not have the names now but I hope he can provide them to you. Drop him an email or call him at ext 294.
Old Feb 24, 2011 | 07:44 AM
Alex@tirerack's Avatar
Alex@tirerack
Wheel Collision center In Bath PA. - They do excelent work!
Old Feb 24, 2011 | 07:56 AM
Project_2501
1) www.google.com
2) search: wheel repair <your zip code>
3) contact results for personal opinion of their competence
Old Feb 24, 2011 | 08:06 AM
davisflyer's Avatar
davisflyer
I just had a wheel repaired on my other car and it cost $100. About the same as a new wheel, butt they don't make it anymore. Also, my bend was on the inside lip. With the location of your bend, it will probably require refinishing as they heat the aluminum with a torch to re-bend back in shape.
Old Feb 24, 2011 | 08:41 AM
BadMINI S's Avatar
BadMINI S
Its not just an obsession
You shouldn't need to bore the wheels, they just require thinner tuner lug bolts. Just given you then heads up. I had them on my R53 and I'm putting them on my R56.
Old Feb 24, 2011 | 05:15 PM
ThumperMCS's Avatar
ThumperMCS
you either have to drill them or use a 14mm->12mm stud conversion kit.
I don't want to run the stud kit, so I'm drilling.
Old Mar 1, 2011 | 12:29 AM
truckboy's Avatar
truckboy
I think you will have to carry your wheel to wheel mechanic, they will put your wheel on a machine and can be straitened.
Yamaha Motorcycles | BMW Motorcycles
Getrieben
Sep 12, 2024 07:03 AM
woodstudio
Mar 15, 2020 08:28 AM
Steeroidz
Aug 29, 2018 07:41 AM
mini4mo
Aug 25, 2015 08:00 AM
sabjcw
Aug 14, 2015 07:40 AM
