Brake Durability?
How long do the stock pads last for? My car is in the shop right now because the rear brakes are metal to metal. I only have 23,000 miles on them...and most of those miles are highway miles...
It really depends on how u drive. I would assume that MINI
would anticipate 35k-40k miles.
Do you often engine brake, or let the brakes do the job?
_________________
03MCS IB/Blk: 123, Aerokit, R90 17x7, TK5 16x7, 6CDMP3, and a few more.
_________________
Close to 25K miles here and my rear brakes still have lots of life left on 'em.
You may want to have service check your parking brake adjustment when they replace the rears. Maybe you're draging the parking brake and that's causing unusual wear. I think that adjustment is part of the normal 25K service, but it sounds like you've not had that yet.
its very unusual for the rears to wear before the fronts. My front pads + rotors were changed at 30k. I drive hard, so i expected that.. but mabye you had the emergencey brake up on accident and it was wearing the rears.. or the auto adjust mechanisim is broken... those could do it.
Either way, if your front pads are fine, something is definately wrong.
I will ask the service people when I pick up the car. This should be under warranty right? I would think it would be. I always put the parking brake down, but I guess it could be the adjustment thingy. The brakes would grind sometimes even when I wasn't on them, and the hand brake was down...hmmmm...
When I bought my MCS the dealer told me the brakes were covered under my extended warranty and they would replace pads and rotors and all needed items.
Earl
Earl
If the brake wear is unusual and not deemed "normal " I susspect they would replace under warranty. But if it is seen as normal wear and tear, your paying for them. I know my wife just had pads replaced on her car after 17K miles, and we paid.
How long do they last?
I still don't see an answer to the question. How long should the stock brake pads last. I've got 40,000 miles on my 03 mcs and I still have roughly 5mm's of pad materal on the front and about 8mm on the back. And believe me I do not baby my brakes. In fact I've been trying to wear the dam things down so I can replace them with something that has less dust.
So, what has been the ballpark figure on the life of the stock pads?
I changed my original pads at 70,000 miles. The fronts still had quite a bit of life left. The inner rear pad was within a few thousand of tripping the sensor. Chad (of Detroit Tuned) said it was up to me if I wanted to replace them or not. I chose to because the Dragon was right around the corner and I also wanted less dust.
So the answer to the question is....there is no stock answer!
In some cases, under certain circumstances, brake pads can "fossilize" and become harder than the disks, so that, when you brake you are wearing the disks rather than the pads. If your pads are lasting a long time without noticeable wear, you should have that checked. One hint of that happening is the noticeable decrease, or elimination of, brake dust on your wheels.
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
