Driving on runflats?
Old May 24, 2010 | 06:07 PM
sonso1's Avatar
sonso1
I was lazy on my drive home from work and ran over something which punctured my tires. It pretty much tore the tread.
Is it safe to drive to the tire shop in the morning to get a new tire?
Old May 24, 2010 | 07:12 PM
ZippyNH's Avatar
ZippyNH
That's is why they call them runflats...just keep the speed down, and drive sanely....
A runflat can be run, while flat for a limited amount of time....so you can get it fixed, or get to a safe location. If you were planning on reparing the tire, I would say drive as little as possible, and go slow..( to prevent heat buildup, which may render it un-repairable), but since you will be replacing it...no worries unless the belt/treads are comming off or there is a huge hole...
Old May 25, 2010 | 04:44 AM
sonso1's Avatar
sonso1
yeah. There's a pretty ugly gash on the treads which makes me worried about driving on them.
Old May 25, 2010 | 05:17 AM
ZippyNH's Avatar
ZippyNH
It got you home anyway....
If it is cut all the way across (all the way into the threads and belt, beyond the tread) or you heard/felt odd things...slapping sounds, etc, be careful...remember, I think the total miles they recomend on a flat runflat is 50 ish at 0 psi at non-highway speeds.
Old May 25, 2010 | 07:50 AM
ramjet77's Avatar
ramjet77
The Gen 1 Owner's Manual says you can drive 95 miles at 50mph max for a tire with 0 PSI.
Old May 25, 2010 | 12:07 PM
doc@tirerack's Avatar
doc@tirerack
We are a little more conservative and recommend no more than 50 miles at 50 mph max........
Old May 25, 2010 | 06:23 PM
sonso1's Avatar
sonso1
Here's a couple of pictures that shows the extent of the damage.
Sorry about the blurriness
So, it may be alright to drive?
Old May 26, 2010 | 07:55 AM
ramjet77's Avatar
ramjet77
It'll be OK to drive. I hit something that took out a quarter size chunk of the tread plus broke the inner plastic wheel well liner (never did see what I hit) and drove 40 miles to the nearest exit in the middle of Idaho with no problems. Actually drove the car around town while I was waiting the day for Tire Rack to drop ship a replacement run flat. No amount of tire slime will fix your wheel; this is a case for run flats, especially in the middle of nowhere.
Kimolaoha
Dec 5, 2020 09:32 PM
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
xpunisherx
Aug 10, 2015 10:50 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
