Tire size for MO 2-S (bbs lm replica)
Old May 20, 2010 | 06:42 AM
blankito's Avatar
blankito
Hey guys,
I just ordered a set of MO 2-S wheels, also known as the ALT 279 Wheel (bbs lm replica) and I was wondering of wich tire size should I use.
I got different information, some told me to put 205/45/17 while others 215/45/17
What's the right tire size?
Thanks!
The wheels:
17x7.5 F / 17x7.5 R
4x100
ET35 F / ET35 R
23lbs
Old May 20, 2010 | 07:47 AM
smlzilla's Avatar
smlzilla
u can go 205-45-17... ull have enough side.. and it's same tire size as stock.
Old May 20, 2010 | 07:48 AM
smlzilla's Avatar
smlzilla
post pics of the wheels I would like to see those wheels..
Old May 20, 2010 | 08:20 AM
blankito's Avatar
blankito
what's best then? What's the difference between both size?
Old May 20, 2010 | 08:27 AM
blankito's Avatar
blankito
not my car but here is a pic of a mini with real bbs lm
I'll post pics when I get the wheels installed
If you want to get more info about the replica, they are made by miro wheels.. you can get them at many places, I ordered mine through raderwerks, a audi/vw shop
Old May 20, 2010 | 08:41 AM
iwashmycar's Avatar
iwashmycar
im running stock 205/ 45s on 7.5 wide et38...so very very close to those specs
While the stock tires have no 'rim protector' if you want the look of that red mini above, go 215...theyll fit fine
here are the stock 205s on a 17x7.5 et 38
itll also really depend on your tires as they are all made differently...
Old May 20, 2010 | 08:50 AM
hsautocrosser's Avatar
hsautocrosser
"What's the difference between both size?"
The 215 is 5mm wider on each side of the wheel, and 4.5mm taller. 6.35mm = 1/4 inch. Pick the tire you want. See which size it comes in.
Old May 20, 2010 | 10:28 AM
blankito's Avatar
blankito
i'm going for Falken 912 and it is available in both size for the exact same price.. I dunno..!
Old May 20, 2010 | 10:45 AM
iwashmycar's Avatar
iwashmycar
215, unless you are or plan to be slammed on coilovers probably
Old May 20, 2010 | 11:16 AM
blankito's Avatar
blankito
I'll only be sitting on NM springs for the moment but coilovers might come later.
What does it change exactly? Less rubbing?
Thanks for the info btw!
Old May 20, 2010 | 12:06 PM
iwashmycar's Avatar
iwashmycar
eh with some coilovers tires tend to be the first to hit the spring perches at low settings.... springs wont really matter as much
Old May 21, 2010 | 01:23 AM
smlzilla's Avatar
smlzilla
ikno how the miro/alt 279 looks like I want to see the raderwerks lm reps look like.. and I kno how real lm looks.. I want to see the raderwerks version.. thnx
Old May 21, 2010 | 05:32 AM
blankito's Avatar
blankito
That's the exact same wheel. Raderwerks and ALT are selling the miro wheel under their name, that's all
You can change the sticker on the wheel yourself
Old May 21, 2010 | 05:33 AM
blankito's Avatar
blankito
So I guess if i'm sticking with springs for now, the wider the better?
Old May 21, 2010 | 05:34 AM
iwashmycar's Avatar
iwashmycar
id say yeah
Old May 21, 2010 | 07:52 AM
smlzilla's Avatar
smlzilla
ok thanks for the info blankito.. if u gonna go low with coilovers got with 205/40/17.. if u just gonna stick with springs just go 215-45-17.. it's just gonna be like the CR mini with the real lms
Old May 21, 2010 | 04:44 PM
Tym2Relax's Avatar
Tym2Relax
Nice looking wheels blankito. Please post your impressions and pics once you get them. Are you planning on installing without hub centric rings?
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
