Help with brake change
Old Mar 8, 2010 | 10:24 AM
cutty34's Avatar
cutty34
Hello,
I'm new to the forum I have a 2003 Mini S model and I am hooked I really like the car and hope to have it a long time. But right now I'm having a slight problem. I want to change my brakes and rotors. I got the left rear rotor changed but I can't get the piston to go down so I can get my brake pads on so I can complete the job. I never had this problem on other cars . Can someone help me with this?
Old Mar 8, 2010 | 11:08 AM
Paleo's Avatar
Paleo
Did you remember to release the emergency brake? I did that once... Secondly are you using a brake tool to compress the piston that rotates? This is important for resetting the rear brakes. I bought a whole kit from Harbor Freight for $20.
Old Mar 8, 2010 | 12:11 PM
MLPearson79's Avatar
MLPearson79
Yep, you definitely need the brake tool for the rear brakes. You'll never get it down any other way.
Old Mar 8, 2010 | 02:29 PM
cutty34's Avatar
cutty34
Thanks I'll try the tool have to go and buy one
Old Mar 8, 2010 | 03:47 PM
Eric_Rowland's Avatar
Eric_Rowland
The piston needs to be turned as it is compressed. Others here have reported doing it without the tool, but it sounds like the tool makes it easier.
Old Mar 8, 2010 | 04:00 PM
ron-s mini's Avatar
ron-s mini
This thread maybe helpful:
https://www.northamericanmotoring.co...beginners.html
Old Mar 8, 2010 | 05:24 PM
BlimeyCabrio's Avatar
BlimeyCabrio
Tool definitely makes it easier, but I've done it without the tool - by using needle-nosed pliers in two of the piston holes to rotate it clockwise while pushing on it hard. You can eventually get it to retract using that technique.
Old Mar 9, 2010 | 09:17 AM
cutty34's Avatar
cutty34
Thanks you guys have a lot help thank you
HaveATank
Aug 24, 2015 10:26 AM
sprp85
Aug 22, 2015 06:16 AM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
FLYM1N1
Aug 16, 2015 01:17 PM
