question on replacing only one run flat tire
Old Feb 4, 2010 | 08:42 AM
mrjudi's Avatar
mrjudi
I have a run flat tire, 18 inch continental that was punctured and it ruined just the one tire. Other tires are in almost new condition. Is it wise to replace just the one tire? I've always been told to buy tires in either pairs or complete sets. The tire dealer looked at the tire and said my MCS should have an allignment done. I'm not sure this is necessary. Any comments? Also, the used car dealer that I bought the car from showed me how to reset the danger tire symbol and it did not come back on after resetting. My thinking is that it is reset to represent the current condition of the tires and unless that condition changes the light does not come back on. So the run flat performed so well that I drove on it for way too long. mrjudi
Old Feb 4, 2010 | 08:52 AM
Achilless's Avatar
Achilless
Ditch the run-flats. Sell them. The change is unreal!
Old Feb 4, 2010 | 09:05 AM
daflake's Avatar
daflake
True, but not helpful in this case...
Depending on how worn the others are, you might be ok with just buying one tire especially if they have low miles. As for the alignment it is possible that you might need one. Did he ask you this because of wear on the current tires? You might try finding another place that you can trust a bit more with the information they are giving you. Maybe a local friend can recommend a place?
Old Feb 4, 2010 | 09:30 AM
mrjudi's Avatar
mrjudi
Thanks Daflake
The man told me about the alignment because of the wear on the single run flat with the problem. That tells me that it was just that one tire that is the problem and not the alignment. I think your advice is good to try and find someone with more knowledge regarding run flats. The tire dealer did not seem to know much about run flats and was undecided whether the tire was a run flat or not. He couldn't even find a continental run flat in that size, that tells me something. Perhaps I'll replace just the one tire and then check wear more often to see if alignment is a problem. Does that sound like the right approach?
Mrjudi
Old Feb 4, 2010 | 10:08 AM
911Fan's Avatar
911Fan
The same thing has happened to me. Since the other tires are in almost new condition, you can replace just the one tire. Make sure you replace the tire with the same exact make/model/size and type (ie, runflat).
A problem arises if the other tires (specifically the one on the opposite side of the same axle) are significantly worn.
I agree that when it does come time to replace all of your tires, ditch the runflats!
Old Feb 4, 2010 | 10:48 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
If those tires aren't directional, try to put the new one on the front left side. That tire always wears faster than the others, at least for me. I guess it's due to those curved highway ramps...
Old Feb 4, 2010 | 02:17 PM
mrjudi's Avatar
mrjudi
Thanks for the tip, but the tire industry (for reasons I don't fully understand) recommend your best tires on the rear of the car now.
To those who do not recommend run flats, is it the weight you object to or the tire life or the performance? And if you drive your car in the West where sometimes a service station or dealer is just not around the corner, what do you do when you have a flat...? I like performance as more than most but I'm trying to be practical as well. I'd have a different attitude if I was racing on a track on the weekends. mrjudi
Old Feb 4, 2010 | 02:41 PM
mrjudi's Avatar
mrjudi
test
Old Feb 4, 2010 | 02:43 PM
Capt_bj's Avatar
Capt_bj
try search for HUNDREDS of posts on this topic . . .
Old Feb 4, 2010 | 03:03 PM
Achilless's Avatar
Achilless
some reasons to switch:
Many of the squeaks on the car (if you have any, i did) had are quieter or altogether eliminated now.
Much of the torque steer is reduced, although this could be due to many different factors (including wider tire or different tread pattern or different tire composition).
The ride is ALOT more smooth and quiet, you dont feel every single bump.
As for me, i was always okay with my runflats but after everyone talking about them on this forum i decided to get rid of them. Like all our NAMers, i said WOW!
Old Feb 4, 2010 | 03:19 PM
911Fan's Avatar
911Fan
Runflats have a rigid sidewall which makes for a harsher ride.
Non-runflats have a significantly better ride, there are a lot more choices, and they're cheaper.
You can put together a toolkit with a compressor, tire repair plugs and/or "Slime" for about $30. Or you can just rely on your AAA membership.
You'll find tons of info about this topic when you do a search.
Old Feb 4, 2010 | 03:20 PM
OPC's Avatar
OPC
RATTUS Deserticus
Most people dislike the ride of the runflats as harsh. Everyone dislikes the cost of replacement at about $250 per tire--and replacement is strongly recommended if run without air for a significant number of miles as the sidewalls degrade.
I opted for a compact air compressor and slime kit. Some people like AAA. I also have a full size spare for roadtrips out of my metropolitan area.
Run-flats have improved in performance since their inception. Their stiff sidewalls do provide for a more responsive feel when in the twisties. That said, not many find that offsets the other shortcomings.
Old Feb 4, 2010 | 10:38 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
They recommend putting the newest tires on the rear because having good tread back there prevents the back end from stepping out on corners. Not a problem if you know how to handle it, but the regular joes out there do not.
About run flats, they make such a huge difference on the first gen cars because the suspensions on those cars was designed on standard tires, then fitted with run flats. The second gen cars were designed with run flats from the get go, so switching would have less of an effect. From the few 2nd gen MINIs I've driven, they seem just as smooth on low profile run flats as my car does on conventional 60 series tires.
Old Feb 5, 2010 | 09:59 PM
Rainman768's Avatar
Rainman768
Originally Posted by nabeshin
-snip-
I was a bit disappointed when I switched my 17" rims with run flats to 16" rims with Blizzaks. The ride was only slightly smoother.
jeffbeckhudd
Aug 29, 2015 09:11 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
