Buying new tires
Old Feb 17, 2009 | 05:57 PM
moruitelda's Avatar
moruitelda
Buying new tires
Hello everybody,
I'm looking at a set of 225/45-17 RE-01Rs, which I'm looking to stick on the factory 17" wheels on my completely stock 2002 R53. I understand it could be a tight fit, and that the 225s aren't recommended, but should I expect them to fit?
I'm getting an absolute killer deal on the tires ($100 per, barely used), and I know it's a close thing, but does anyone have any input on these specific tires, this size, what severity of rubbing I might expect, and whether that's something that should be acceptable, or if there's anything I can do to reduce it, what that might be.
Thanks in advance for your input!
Old Feb 17, 2009 | 06:30 PM
camminich's Avatar
camminich
They will fit, but they will also rub, plus they are pretty tall. Now, they won't rub all of the time, but when your wheels are fully cranked to lock, or certainly with any load on the rear, and you will be in rub town. Plus your odometer will be low by a good 4mph at 60.
Most people have used 40 or even 35 series when it comes to 225, plus they also go with a 1/2" wider rim. I know this is probably not the news you wanted to hear, and maybe someone else will have better info, but the few Coopers I have seen with that size of tire have not had happy owners.
Old Feb 17, 2009 | 06:33 PM
moruitelda's Avatar
moruitelda
Will spacers or any kind of aftermarket equipment help with the fit? Is it likely to rub on the suspension, or on the well, inside/outside, front/rear?
I don't particularly care about the odometer/speedometer, as I can control my speed well, but I would like to avoid significant rubbing. I also do autocross, which I why I picked these up, so whatever I do, I'd like to remain stock-legal.
Old Feb 17, 2009 | 06:51 PM
camminich's Avatar
camminich
On the rear you will have outside fender rubbing. Not too sure about the front, I think you get a little bit of both inside rubbing, and on the front lower suspension.
I don't think a spacer would work with the stock 17s like the S-Lites.
Old Feb 17, 2009 | 06:54 PM
moruitelda's Avatar
moruitelda
Any suggestions of an offset or offset/wheel combo I could look into at a reasonable cost? Or should I just bite the bullet and look for something else?
Old Feb 18, 2009 | 06:35 AM
Alex@tirerack's Avatar
Alex@tirerack
I also do autocross
I think you'll find a 25 inch tall tire yeilding a bit too tall gearing, JMO for autoX. With boku torque, you could work it out, but wouldn't be stock legal.
205/45/17 Re01R - works with your stock wheels
Alex
Old Feb 18, 2009 | 06:38 AM
moruitelda's Avatar
moruitelda
Thanks, Alex. I picked these up anyway (I can definitely sell them at a reasonable profit), and am thinking about 215/45-17 Kumho XS.
Thanks for the input, everybody. I would have been really annoyed if I got these mounted and balanced and wound up having problems.
Old Feb 18, 2009 | 08:54 AM
camminich's Avatar
camminich
I can vouche for the 215/45 R17, they do fit with no rubbing and on the stock s-lites .
Old Feb 18, 2009 | 09:15 AM
moruitelda's Avatar
moruitelda
Thanks! Now to find some WRX/M3 driver who wants these 225s. :D
woodstudio
Mar 15, 2020 08:28 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
L3Mix
Aug 26, 2015 07:00 PM
TOMSR53
Aug 26, 2015 10:18 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
