Changing Hub
Old Jan 9, 2009 | 04:44 AM
bmackinlay4353's Avatar
bmackinlay4353
Changing Hub
Anyone give me some advice on how to replace a hub that I stripped a lug hole on? I have a 08 MCS Cabrio. Bill
Old Jan 9, 2009 | 04:47 AM
Coen_de_K's Avatar
Coen_de_K
make sure you get the right hub.. I think they are R56's hubs...
I had put some spacers on a 2008Cabrio but it had R56 lugs needed...
make sure you got the right one!
luck
Coen
Old Jan 9, 2009 | 04:59 AM
Capt_bj's Avatar
Capt_bj
Hub replacement
That's still a GEN1 right? Check the GEN1 forum, it has been discussed many times. I doubt much has changed from the prodecure given in the Haynes which is pretty straight forward. ... you don't mention if this is front or rear but:
- remove driveshaft retaining nut (if front)
- remove brake including rotor
- remove wheel speed sensor
- remove 4 bolts holding the hub
reassemble is the reverse ....
driveshaft/hub retaining nuts 134 ft lb
hub to hub carrier 41 ft lb
speed sensor bolt 7 ft lbs
chapter 10 in the Haynes
Old Jan 9, 2009 | 05:38 PM
bmackinlay4353
CaptBj, Do you know what size the retaining nut is?Bill
Old Jan 9, 2009 | 05:44 PM
Yo'sDad's Avatar
Yo'sDad
The front axle nut on my 06 mcs is 1 1/4 inches and the four bolts holding the hub in place are 1/2 heads. It is not necessary to remove the speed sensor, just lift it out carefully.
Seems a shame to have to replace an expensive hub just to fix a stripped thread. How did the strip happen?
YD
Old Jan 9, 2009 | 06:29 PM
bmackinlay4353
YD
YD,isn't the nut a Metric size and not SAE? I was changing out the black lugs for the chrome type,I put 15 on perfectly, but 16th I cross threaded, I was using a impact wrench, and failed to put the last nut in with my fingers , just put it in the socket and you know the rest!! I did get good deal from Classic BMW/Mini on the new Hub, because I was a member of this forum.List $197.27 my price $157.82!!Bill
Old Jan 10, 2009 | 07:23 AM
Yo'sDad's Avatar
Yo'sDad
It may be a metric size but there are a ton of sizes that are cross compatible in size. 10mm is one of the ones where you just must have a 10mm. It a socket fits nice and snug, it will work no matter if it is metric or not.
If it is not 1/2 then it will be 12mm or 13mm, but if my 1/2 fit, then 13 would most likely be too large. I just happened to have a 1/2 inch lying right beside me when and tried it and it was a really good fit, so I used it.
I was checking mine for a bad bearing and decided to pull both fronts to feel them turn in my hand. I'm getting pretty old now-a-days so I'm not as spry as I used to be, but I pulled the hub and played with it off the car and put it back on and had the jack back down in 65 min. A younger dude and in a hurry could do it a lot faster I'm sure.
YD
Old Jan 13, 2009 | 05:59 PM
Q-4000's Avatar
Q-4000
08 is a 2nd gen! 02-06 1st gen 07-current 2nd gen
Old Jan 13, 2009 | 07:30 PM
ibyte's Avatar
ibyte
cabrios are still 1st gen i think
Old Jan 14, 2009 | 04:02 AM
Capt_bj's Avatar
Capt_bj
yep
barnoun
Sep 17, 2018 05:04 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
TOMSR53
Aug 26, 2015 10:18 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
