Wheel experts
Old Dec 1, 2008 | 02:52 PM
SmokeM's Avatar
SmokeM
Wheel experts
what is the measurement called that determines if your brake caliper will fit within the rim?
I know what offset is.
I know what backspacing is but this is the distance from the hub face to the inner lip of the rim. But how does this number tell me if my brake caliper will fit? I think the depth from the hub face to the backside of a spoke is the distance I need. Am I missing something?
Old Dec 1, 2008 | 04:01 PM
Warped1966's Avatar
Warped1966
I don't think that there is a definition of that. What you need to know is the outside diameter (OD) of your rotor, measured through the center, to the top of your caliper. You would then need to know the inside diameter (ID) of the wheel that interests you.
Generally speaking, if you have a R56 with the sport package, (or was it sport suspension?) you have to use rims that are at least 16". That is the same brake kit as the R50/53 JCW brakes. If you have a R50/53 with the JCW brakes, the same applies. I hope this helps!
Old Dec 1, 2008 | 04:17 PM
bahawton's Avatar
bahawton
Wilwood calls it "Inside Wheel Profile"- Check out page 3 in the PDF below:
http://www.wilwood.com/PDF/ds492.pdf
-Brett
Old Dec 2, 2008 | 06:29 PM
SmokeM's Avatar
SmokeM
Sure this is one dimension that must be taken into consideration BUT the critical dimension for me is the measurement of the pocket behind the spokes. Too shallow then the caliper face hits the back of the rim's spokes (or face). My JCW already came with 17"s so I know that a 17" rim should fit.
I can't believe we can put a man on the moon but we don't have a standard measurement that will help me determine if my caliper will fit the rim.
Old Dec 3, 2008 | 11:41 AM
toddtce's Avatar
toddtce
I call it "caliper overhang". The amount of caliper body protruding above the flush surface of the rotor hat face.
Shown here being roughly .950" or 24mm at a given radius.
Old Dec 3, 2008 | 02:59 PM
Alex@tirerack's Avatar
Alex@tirerack
Tirerack calls it X factor - same measurment!
Alex
Old Dec 3, 2008 | 06:49 PM
SmokeM's Avatar
SmokeM
Alex
This is posted for every wheel on the website?
Old Dec 4, 2008 | 09:23 AM
Alex@tirerack
No its not. Call/ email me if you have a question on a specific wheel. We can check clearances for you - we have alot of kits on file for this process.
Alex
barnoun
Sep 17, 2018 05:04 PM
thebordella
Aug 31, 2015 01:37 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
Aug 25, 2015 01:32 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
