How to R56 Rear Brake pad replacement?
Old Sep 24, 2008 | 07:38 PM
OkieSnake's Avatar
OkieSnake
Ok, there is an excelent write up on how to replace brake pads on pre-R56 https://www.northamericanmotoring.co...ad+replacement
The fronts were easy, maybe even easier on the R56.
BUT, how about 2007+ R56 REAR PADS?
How do you retract the rear caliper piston? I used a piece of wood and a big "C" clamp but the caliper hardly budged. I was afraid I would damage somethiing if I kept tightening the clamp.
Old Sep 24, 2008 | 07:43 PM
Ryephile's Avatar
Ryephile
I'd imagine the rear calipers are similar to the R53 calipers, where you have to "thread" the piston in. I found that the pistons thread easily once you actuate the e-brake lever [on the caliper itself] a full cycle. This whole operation is easiest with the caliper totally out of the car, which is not a problem if you're changing to stainless braided lines. If you're not though, grab a pair of needle nose pliers, recess them within the dimples in the piston, and push-n-twist!
HTH,
Ryan
Old Sep 24, 2008 | 08:17 PM
OkieSnake's Avatar
OkieSnake
Anyone out there with an R56 that has done this?
Old Sep 25, 2008 | 06:31 AM
djam43's Avatar
djam43
The rear caliper pistons have to be rotated as they are being removed. This is because they incorperate the parking brake. You can purchase a set of piston removal tools for about $19 at Harbour Freight, and modify ir slightly to fit the dimples in the Mini piston. You might also have some luck with a set of needle nose pliers. I have never attempted to do my brakes but I have read about it.
Old Sep 25, 2008 | 08:18 AM
fignewton's Avatar
fignewton
Do your self a favor and go ahead and buy the right tools
http://www.ecstuning.com/stage/edpd/...=Brake%20Tools
Go here and buy this set (or similar if you have another source). I bought this when I had my Audi TT after spending a long time trying to compress/turn the rear caliper pistons on it. This is a good investment, as you will be able to use the tool for other applications too. It will well pay for itself in aggrevation/damage. I've already used it on the MCS to change to Carbotechs. It literally takes seconds to compress the rears once you have picked the right disk to match the piston notches.
"Right tool for the job" makes all the difference.
Fig
Old Sep 25, 2008 | 08:47 AM
4cefed4's Avatar
4cefed4
I got the Harbor Freight Disc Brake tool set when it went on sale for $10. Made doing the rears on my GTI (same screw-in set up) a breeze.
Old Sep 25, 2008 | 05:45 PM
OkieSnake's Avatar
OkieSnake
Thanks everyone. I ordered the Harbor Freight tool set.
Old Sep 25, 2008 | 11:05 PM
r56mini's Avatar
r56mini
I will have to remember this....
Old Sep 26, 2008 | 09:04 AM
stlmcs's Avatar
stlmcs
You can get the caliper tool you need at Autozone under their loaner tool program. Just put down a deposit, use it, and then bring it back. It is the same type as in the link above. I use it whenever I do rear brakes.
Old Oct 25, 2008 | 10:40 PM
STLMINI's Avatar
STLMINI
I was surprised today when I took out the rear brake pads of my R56 and saw an X shape on the piston. I was still able to use the tool from Harbor Freight today. I used the #5 disc. I also opened the bleed valve a little bit to release some pressure. I was planning to bleed the brake fluid anyway. Went very smoothly.
Old Oct 26, 2008 | 03:46 AM
corcoranwtnet's Avatar
corcoranwtnet
I don't understand your comment about the "x". Are you saying it is an identifying mark put there by the manufacturer, that it is an unusual wear pattern, a normal wear pattern, or ??
Old Oct 26, 2008 | 05:08 AM
MeloR56's Avatar
MeloR56
I believe he his referring to the indents in the caliper piston head that allow for a tool to turn and compress the piston...you can see it here if you look closely at the caliper piston>>
If you plan to replace the pads with other than OEM pads make sure the rear and front pads can accommodate the brake pad wear sensor (only one on right rear and one on the left front)
To remove calipers you will need a socket and open ended wrench as seen here>>
Here is a bit of a write up I did on the subject... just scroll past the turbo schield part to get to the pad replacement>>>
https://www.northamericanmotoring.co...d.php?t=148677
Michael
Old Oct 26, 2008 | 10:03 AM
STLMINI's Avatar
STLMINI
that's exactly what i was referring too. thanks. i was trying to figure out how to show it without taking my brakes apart again.
Old Oct 26, 2008 | 12:05 PM
corcoranwtnet
Thanks...I can clearly see the grooves forming the "X".
Old Oct 26, 2008 | 01:11 PM
r56mini's Avatar
r56mini
That's a clean car. Are you Bentley? You are in the process of completing the service manual, aren't you? Why would you take the car apart when it's new like that if you weren't Mr.Bentley?
Old Oct 27, 2008 | 06:52 AM
OkieSnake's Avatar
OkieSnake
MeloR56,
Great How-To! Thanks.
Old Jun 26, 2010 | 04:06 PM
daffodildeb's Avatar
daffodildeb
Great discussion. I'm Ken, Deb's mechanic (aka spouse). I just used your discussion to help me install a set of rear pads, and thought I would add a few comments:
I found that a large C-clamp does work quite well, but nix the block of wood, which prevents rotation of the piston as it retracts. After cleaning the piston and boot area, place the swivel foot of the clamp directly on the face of the piston, with the "anvil" part of the clamp on the back of the housing. I had to use a cheater pipe on the clamp handle at first, but it was easier to turn once started.
I opened the bleed screw and was draining the fluid into an old brake fluid container. But I drained so much from the reservoir that I got air into the lines. Oh well, I was going to flush the brake fluid anyway.
I found the brake wear sensor wire quite stubborn to remove as the plastic terminal is very brittle and held tightly. Once both caliper mounting screws are removed, I found that by twisting the caliper from side to side to move the piston back slightly and pushing the caliper housing in toward the disk, the sensor terminal is not being held so tightly. I used a long nose vice grip to hold the sensor as its narrow jaws were about parallel when clamped on and gave me a good grip.
The other end of the wire is up under the car. I removed the plastic panel below it, and then had to cut a tie-wrap to remove the plug assembly. After installing the new wire put another tie-wrap on it and replace the panel.
Attached Thumbnails How to R56 Rear Brake pad replacement?-c-clamp-to-compress-and-rotate-piston.jpg   How to R56 Rear Brake pad replacement?-piston-compressed.jpg   How to R56 Rear Brake pad replacement?-sensor-wire-connector.jpg
squawSkiBum
Oct 2, 2015 09:21 AM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
