Front brake pads. How long do they last?
Old Mar 4, 2008 | 06:09 AM
JDPepper's Avatar
JDPepper
26K and I'm starting to notice a slightly lower pedal. How long to the OE brake pads tend to last? (I'm a late braker... )
Old Mar 4, 2008 | 07:12 AM
jakay11's Avatar
jakay11
I have 35K mi and about 1/2 of the original pad left...
But then again, I drive 100/day, most of which is on the highway, and almost never touch the brakes for 90 mi of that commute...
Look through the wheel spokes at the brake... if the backing plate is the same thickness or thicker than the brake material left, its time to change the pads.
HTH.
Old Mar 4, 2008 | 07:20 AM
ChrisW's Avatar
ChrisW
I got about 19k out of mine. But I autoX alot and drive the car very hard.
Old Mar 4, 2008 | 09:46 AM
Jahmills's Avatar
Jahmills
I got about 40,000 out my first set, and front & back went bad around the same time. I drive pretty hard, but have a bit of a downshifting habit that I need to break. I always try to see how little I can brake, and quite frankly would rather replace brakes than a clutch.
Old Mar 4, 2008 | 09:48 AM
thulchatt's Avatar
thulchatt
Changed to ceramics at 28K and had a lot of pad left.
Old Mar 4, 2008 | 10:44 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Rev-match FTW.
Jack
Old Mar 4, 2008 | 02:07 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Normal driving mine are lasting about 40,000 miles. Hard driving and your milage will go down. Lots of highway and it will go up.
But for me I changed Artoo's pads and rotors at 35,000 under the maintenance warranty and they were fine. I checked them last weekend at 75,000 and decided to wait until spring to change them again.
Rich
Old Mar 4, 2008 | 04:31 PM
D3m0N's Avatar
D3m0N
also pedal being soft shouldn't be pads I would guess fluid or mc
Old Mar 4, 2008 | 04:45 PM
NashvilleMiniStan's Avatar
NashvilleMiniStan
If you are low on brake fluid, you may want to change to ATE Super Blue Brake Fluid. 100% synthetic fluid is specifically designed to resist the high temperatures of racing brakes and clutch systems.
http://www.outmotoring.com/mini-coop...ake_fluid.html
Old Mar 6, 2008 | 07:08 AM
Wilade's Avatar
Wilade
So, what is the recommended replacement interval?
My '07 MCS is in the shop now for it's 1-year/15,000 mile check/oil change, etc. and they called to tell me they are replacing the "brakes" since it is so close to the recommended time anyway and since I live in another state.
Do the pads wear out that fast? I had not been having any trouble with the brakes, and do not drive [FONT='Times New Roman']aggressively.[/FONT]
Old Mar 6, 2008 | 08:21 AM
white rocket's Avatar
white rocket
Brakes are for stoppin' and transmissions are for goin'
Old Mar 7, 2008 | 05:35 PM
e30r56's Avatar
e30r56
I was told mine will wear out at ~20k in the front, 25-30k in the rear.
Old Mar 7, 2008 | 05:54 PM
bee1000n's Avatar
bee1000n
I'm over 62,000 miles with all the original brake parts still on my 04 MCS. Clearly I've spent most of those miles commuting on the highway, not carving canyons.
Old Mar 7, 2008 | 06:06 PM
Guest's Avatar
Guest
I never used mine, at about 10k miles I pulled them off with little to no wear and put on a set of Mintex 1144 pads. A trackday and 9k miles later, those were shot, so I now have a set of Mintex Xtreme pads, they're at about 50% with a trackday and 6-7k miles on them, so seems like they're working well :-)
Old Mar 9, 2008 | 03:41 PM
CHKMINI's Avatar
CHKMINI
I drive 110 miles round trip to work everyday, all highway driving. Just now replacing the pads at 80,000 miles
Old Mar 11, 2008 | 02:18 PM
xcountryfreak's Avatar
xcountryfreak
Ceramic recommended by BMW??
Replaced my MCS front pads at 70k but the rear went just out of warranty at about 45k.
Question. I looked on the Tirerack site today and they say the manufacturer recommends ceramic pads for the 03 MCS! Any truth to that? I haven't seen anything else that said ceramics were recommended. I replaced mine with regular semi metalic pads and they seem to work fine.
W0TM8
Dec 19, 2019 07:50 AM
squawSkiBum
Oct 2, 2015 09:21 AM
FLYM1N1
Aug 15, 2015 11:20 AM
