DIY Rotor Replacement
Old Feb 11, 2008 | 04:44 PM
greengobln's Avatar
greengobln
is there a DIY Rotor replacement thread? i searched to no avail and would appreciate any help.
thanks Guys
Old Feb 11, 2008 | 04:47 PM
hemiheaded18's Avatar
hemiheaded18
Don't know about a thread but I will say this. Break off those stupid flat rotor bolts and forget about them. All they do is rust in place and become a PITA. Other than that, it's no different than brakes on most any other car.
Old Feb 11, 2008 | 04:50 PM
Dr Obnxs's Avatar
Dr Obnxs
PRetty easy..
take of wheels.
Take off calipers.
Undo large TORX screw that holds rotors on (impact wrench if it's rusty....)
Remove rotors.
Put on new rotors.
Compress piston a bit (if there's a big difference in thickness).
Put caliper back on.
Put wheel back on.
You're done!
If the torx is really seated on there, loosen it before taking the calipers off by having someone stand on the brakes and use a long braker bar.
Oh, I forgot the first step... Jack up car!
Old Feb 11, 2008 | 04:58 PM
Eric_Rowland's Avatar
Eric_Rowland
And don't forget PB blaster or similar penetrating oil for those big @$$ torx (T50 IIRC) - much better to unscrew than to snap off.
Give each one a squirt as you take the wheel off, and by the time you're done with the last wheel, the first screw will have had time to soak a bit.
And if you don't throw them away per Hemi, a dab of antiseize will make the next time easier.
Old Feb 13, 2008 | 04:54 AM
greengobln's Avatar
greengobln
this is definitely the best forum i've been a part of. thanks for the quick info. i didn't want to get half way in and find out there is something different about imported cars than my old domestic.
thanks again
Old Jan 16, 2012 | 11:32 AM
greengobln's Avatar
greengobln
Removing the calipers took a breaker bar and a lot of PBLaster this time around. prepped with anti seize this time.
Old Jan 16, 2012 | 12:49 PM
JAB 67's Avatar
JAB 67
Also, if working on the rears, you need to understand that the caliper pistons need to be rotated as they are compressed.
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
Beau B
12
Aug 24, 2015 01:50 PM
fjork_duf
Aug 16, 2015 04:38 PM
