Show me your WHEELS!
Old Apr 14, 2009 | 10:30 PM
  #7351
dwf137's Avatar
dwf137
What's the width on those OZ's?
i'm runnin 215/45 on my konigs, and I think the tires are slightly too wide for them. Granted, they are dunlop SP Sportmaxx, so they're a bit wider than other 215's, but still.
and i love the drop in weight, my konigs were 14.5lbs.
Old Apr 15, 2009 | 05:20 AM
  #7352
dtsoccer6's Avatar
dtsoccer6
oh sorry, I wasn't sure what you meant. The width on the OZ's are 17x7.
I currently run 17x7 Team D 1.2s with 215/45/17 and have no issues at the stock height with rubbing or anything. I also suspect when I drop it, which is only 1.18inches all the way around, that I will be fine to continue running 215's, thats why I bought them. Where you running 225 dwf?
Old Apr 15, 2009 | 08:01 AM
  #7353
dwf137's Avatar
dwf137
na, i'm still on 215's, but i hear that the sp sportmaxx's run a bit wider then other 215 tires.
It still looks great, it's just that my tires are clearly wider then my 7" wide konigs...
the +40 offset makes everything line up perfectly. now i gotta get some mudflaps.
Old Apr 15, 2009 | 10:43 AM
  #7354
tgs91
Attn Konky,
Really dig the Schmidt Racelites that your running
Thinking of getting set for mine
When I google Schmidt Wheels all I get is a outfit out of Vegas called Tunershop that has not responded to email or voice messages. I went so far as to email their UK site.
Where did u get yours?
Old Apr 15, 2009 | 11:09 AM
  #7355
dtsoccer6's Avatar
dtsoccer6
Yeah, mud flaps are deff needed. I get dirt, rocks, and mud kick up all the time, my wheels are at 45 offset right now.
Old Apr 15, 2009 | 11:43 AM
  #7356
dwf137's Avatar
dwf137
yea, i washed yesterday, and had all sorts of road tar all over my doors.
gotta break out the claybar soon. I'll be down at the dealer getting my windows re-programmed monday, I may just have them install the flaps there, since I don't have a drill to work in tight spaces, and don't have jack stands to put the car on to remove the wheel to screw the mudflaps in....
Old Apr 15, 2009 | 11:49 AM
  #7357
whsky2's Avatar
whsky2
Here is an EB '02 with some SSR-GT1s. Unfortunately they are no longer available.
Old Apr 16, 2009 | 07:49 AM
  #7358
Konky's Avatar
Konky
Originally Posted by tgs91
Attn Konky,
I don't think they're in production anymore, but don't quote me on that.
I got mine from a company in Ireland, that had them listed on ebay Ireland, years ago. Only other place I saw them actually for sale in the states was NGP racing. you could always try searching them on google and sending a message to see if they have any in stock.
Old Apr 16, 2009 | 10:35 AM
  #7359
tgs91
Attn Konky,
I actually heard from the guy in Vegas and they have them in Stock. We swapped emails and he mentioned that I will need 10MM spacers. Not a big deal
I am talking to two local shops to do the install and one of them went on about if I am putting on new after market wheels with spacers that I better change out the control arms, etc, etc. BEFORE I put on the wheels due to the weight of the wheels....sounds kinda screwy as I understand the Mini stock wheels (which I got) are not that light to begin with.
I was planning to eventually change out control arms
Anybody out there run across this when changing out to new wheels?
Old Apr 16, 2009 | 10:47 AM
  #7360
KandyRedCoi's Avatar
KandyRedCoi
this page has no pics of wheels yet...loosing right now guys :(
Old Apr 16, 2009 | 10:50 AM
  #7361
jonnyyellow's Avatar
jonnyyellow
Hey, I'm not a specialist when it comes to suspension, but I'm pretty sure you do not NEED new control arms/stronger ones when putting aftermarket wheels on. I don't believe the wheels would be that heavy/have that much effect. Many of the wheel shops say random things, I say that but i am not hating on the shop that said that.
See what others have to say about this, but I'm pretty sure you would be fine without new CAs. However, with 10mm spacers you might need longer lug nuts. I'm not sure how big of spacers one would go with stock lug nuts.
Old Apr 16, 2009 | 03:19 PM
  #7362
Mini Fireman's Avatar
Mini Fireman
Most of this conversation should take place in PM, but I'll offer a few quick answers.
No, you do not NEED new control arms to run aftermarket wheels. There are plenty of MINI owners that are stretching the limits of wheel fit that have only changed wheels/tires.
Some of the things you WILL need to consider are wheel offset, whether you will need to use spacers to fit over brake kits/clear suspension/adjust wheel offset, bolt pattern & size (12mm for the R50/52/53 or 14mm for the R55/56/late R53 & 4x100 pattern), & whether they are hubcentric (MINI has 56.1mm hubs) or can be adapted with hubcentric rings. After you have all that figured out you'll need to determine what will fit in your wheel well with or without modification (trimming wheel arches, removing fender liners, camber additions, stretched tires, etc...). The farther you stray from OEM specs the more closely you'll have to consider all of these factors.
I'd recommend you start by looking to see if the setup you want has been run before and what it took to run it successfully. If you have a set of the wheels to test fit that makes it much easier too. Prior planning and research can save you lots of expense, time and trouble.
BTW, if you don't have the stones for this kind of modification than stick to stock sizing and enjoy your MINI as is.
Old Apr 16, 2009 | 04:12 PM
  #7363
CrazyIvan's Avatar
CrazyIvan
Picture with the new rims.... I know they've been done before but
17" ASA AR1s
Old Apr 16, 2009 | 04:16 PM
  #7364
07BPB's Avatar
07BPB
Originally Posted by jc8899311
works meister 16x7
Very sexy! Did they come orange or did you get that done?
Old Apr 16, 2009 | 04:21 PM
  #7365
tgs91
Thanks Mini Fireman
The guy I am talking to at TunerShop sent me a subsequent email that yes I need 10mm spacers and lug bolts for these particular wheels. Seems like he has worked with Mini's before as he noted that these spacers are needed specifically upfront but makes sense to do all 4 and the spacers will get the wheels flush with the fenders which is what I want
Think the guy at NTB was blowing wind with talking about control arms and the rest of the suspension needing to upgrade first. He maybe cheaper than the local shop but local shop seems to be more capable. For $10 more per tire seems a good choice
Thanks for all the help guys, will post pic's when done
Old Apr 16, 2009 | 07:05 PM
  #7366
jerjer's Avatar
jerjer
i believe it's a custom color order from Work wheels
Old Apr 16, 2009 | 09:07 PM
  #7367
200-OK's Avatar
200-OK
Bridgestone RE-01's mounted on black Motegi SP10's
Just put the new wheels and tires on today (finally, no snow!):
These are Bridgestone RE-01's mounted on black Motegi SP10's. Sorry for the poor quality; shot on my mobile phone.
Old Apr 17, 2009 | 12:09 PM
  #7368
navicaph's Avatar
navicaph
Just put them on this morning
Old Apr 17, 2009 | 12:59 PM
  #7369
DixonL2's Avatar
DixonL2
^^^ very nice! Looks like a good R/C toy car!
On second thought, I guess it is... only in 1:1 scale
Old Apr 17, 2009 | 01:43 PM
  #7370
Oxybluecoop's Avatar
Oxybluecoop
Wow that looks good I might have to pick up a set of those.
Old Apr 17, 2009 | 02:12 PM
  #7371
tgs91
sa-weet!
Old Apr 17, 2009 | 03:13 PM
  #7372
inimini2007's Avatar
inimini2007
Konig Bump
Konig Bump, 17x7 w/RunFlats
Old Apr 17, 2009 | 04:37 PM
  #7373
miniman101's Avatar
miniman101
The Motegis look great 200 Ok!
Old Apr 18, 2009 | 08:06 PM
  #7374
fazelk's Avatar
fazelk
Breyton GTS-R w/ Goodyear Eagle F1 Asymmetric 215/35R/18
Old Apr 21, 2009 | 01:43 AM
  #7375
jc8899311's Avatar
jc8899311
yea is custom paint,im thinkin of paintin my mirror cap orange aswell
