Show me your WHEELS!
Old Jan 22, 2008 | 06:26 PM
  #4976
kenchan's Avatar
kenchan
minipete- good job on your R56!
that looks good. ride height, tires, color and all.
Old Jan 22, 2008 | 06:33 PM
  #4977
CANYONCARVER's Avatar
CANYONCARVER
Looks good.
The Rota Boost is a Advan RG-II replica. Sorry, just had to point that out, but it looks good, I like it. Is that a custom job or can you oder them like that? I almost bought the same wheels, but I founds some used Advans.
Originally Posted by minipete07
Thanks!! I tried doing that but it said the file was too big!.....The wheels are 17x7.5" Rota Boost, flat black with red, on Falken Fk452 215/45ZR17 tires. Also got 5mm H&R wheel spacers on all four corners!
Old Jan 22, 2008 | 08:10 PM
  #4978
kenchan's Avatar
kenchan
your wheels are advans, but were bought used. you never
know wat problems you bought from the original owner...just wanted
to point that out.
so wat if they are copies? they look good on his car.
Old Jan 23, 2008 | 05:54 AM
  #4979
DixonL2's Avatar
DixonL2
'08 look so far: crusty salty wheels with narrow snows and a coating of road grime...
'08 look for summer?
Old Jan 24, 2008 | 08:24 AM
  #4980
minipete07's Avatar
minipete07
Thanks! They are daily driver wheels so don't care if they are knock offs! wouldn't pay $500 a wheel for Advans to hit a pot hole and get mad... i bought them like that from 18racing.com....awsome service...
Old Jan 24, 2008 | 08:38 AM
  #4981
jblaw's Avatar
jblaw
Snow Wheels!
These are my Snows
Old Jan 24, 2008 | 08:46 AM
  #4982
kenchan's Avatar
kenchan
Originally Posted by jblaw
These are my Snows
dang, you chose one of the most time consuming wheels to clean as winter wheels.
Old Jan 24, 2008 | 10:18 AM
  #4983
DixonL2's Avatar
DixonL2
+1!! Get a good wheel brush... that's actually why I went to 16" OE 5-spokers from these:
But I miss the extra 1/2" in width, and the slightly wider track due to lower offset number on my old wheels. They were lighter too. I can feel it in responsiveness - it's slight, but it's there.
Old Jan 24, 2008 | 10:20 AM
  #4984
PGT's Avatar
PGT
no, I think mine might fit that bill better
Old Jan 24, 2008 | 10:32 AM
  #4985
jblaw's Avatar
jblaw
HA!
Not only that, but they are 17", which is not ideal for snow. You know what though, I live in NYC, I dont have to park my car on the street (thus no moving everyday) and the possibility of snow remains for 5 months out of the yr. Those are 5 months that I wanted to remain in STYLE.
Old Jan 25, 2008 | 01:51 PM
  #4986
MisterDangerPants's Avatar
MisterDangerPants
RH AQ
these were just delivered this afternoon and I'm making a bee line first thing tomorrow morning to my favorite local installer. they're RH AQ wheels (17x8.5; ET35) and I really like the OEM look. selling my Compomotive MO wheels as they served me quite well.
Old Jan 25, 2008 | 02:01 PM
  #4987
roofaS's Avatar
roofaS
oohhh yeah, love those wheels!
Old Jan 25, 2008 | 02:04 PM
  #4988
kenchan's Avatar
kenchan
those maxlites(?) maxilites(?) are cool wheels. at one time i almost
bought a set.
Old Jan 25, 2008 | 02:21 PM
  #4989
MisterDangerPants
thanks!
those maxlites(?) maxilites(?) are cool wheels. at one time i almost bought a set.
yes, they are the RH AQ Maxilite wheel. I have been debating these for quite some time and finally saw what they looked like on another MINI so I took the plunge.
Old Jan 25, 2008 | 03:09 PM
  #4990
mcs22004's Avatar
mcs22004
Originally Posted by MisterDangerPants
thanks!
I asked in the linked topic, but what tire size are you going to use? Are you going to need 20mm spacers?
How much do those wheels weigh?
Old Jan 25, 2008 | 03:17 PM
  #4991
Rally@StanceDesign's Avatar
Rally@StanceDesign
This will be pretty important. The car pictured used tires that were stretched a pretty good deal to avoid rubbing and it seems required with that low offset and wide width. You will want to look into 205 width tires....that's what i run on my 8.5"s and it should help you avoid the rub
Old Jan 25, 2008 | 03:26 PM
  #4992
mcs22004's Avatar
mcs22004
For me it's just curiosity because the wheels are probably way heavier than I would ever put on my car, but they do look great on the car--curvaceous spokes on a car with very rounded contours. I would probably rather drastically cut than run the wrong size tires for those wheels, though. But it must be horrendously close both inside and out.
Old Jan 25, 2008 | 03:27 PM
  #4993
MINIAC's Avatar
MINIAC
RH-Alurad AQ Maxilite are also available in 17x7 ET45.
Old Jan 25, 2008 | 03:36 PM
  #4994
MisterDangerPants
I asked in the linked topic, but what tire size are you going to use? Are you going to need 20mm spacers? How much do those wheels weigh?
I will be using 215/45/17, which is what I'm currently running on my 17x8/ET40 Compomotives. The wheels (17x8.5) come as ET55, and have a multi-fit system so you can customize the fitment in 10mm increments (I think). I have a 20mm adapter, which brings the offset to ET35. RH lists this size and offset for the MINI so I gather with my stock suspension, I won't get any rubbing. Or at least that's what I'm hoping. GMP Performance was also confident I wouldn't have any rubbing.
I have no idea how much they weigh.
Old Jan 25, 2008 | 03:43 PM
  #4995
ChiliWORKs's Avatar
ChiliWORKs
Can't wait to see how they look on your car too.
Old Jan 26, 2008 | 04:53 AM
  #4996
mcs22004's Avatar
mcs22004
The GMP site says the ship with a "special 20mm A adapter and mouting bolts" Can you post a pic of that? Also, could you throw one of the wheels on a scale?
Old Jan 26, 2008 | 05:05 AM
  #4997
MisterDangerPants
hmmm, well the wheels are currently being installed, so I can't get a photo, but go here to see a photo on the RH USA site of the adapter. you can also go here to see a schematic of the multi-fitment system. it looks like any other adapter (like say H&R) and GMP supplies all hardware to install the wheels.
as for weight, I don't have a scale (and the tires are currently being installed). I'm guessing the weight is similar as the S-Lites. they are not featherweights by any stretch of the imagination!
Old Jan 26, 2008 | 05:28 AM
  #4998
mcs22004's Avatar
mcs22004
You mentioned that you had spacers as well, but I gather that the supplied 20mm adapter is supposed to be all you need for spacing each wheel on the MINI. Is that correct?
Also, were the correct centering rings for the MINI included for use with the 20mm adapters as part of the order?
Old Jan 26, 2008 | 11:03 AM
  #4999
MisterDangerPants
don't think I mentioned having spacers. as I said, they come with an adapter because they are made to fit a variety of different vehicles. I have the 20mm adapter (the wheel is ET55 without the adapter), but I believe they come in several different sizes in 10mm increments. the centering rings were included along with all the necessary bolts for the wheels & adapters. speaking of which, GMP send the wrong size bolts for the adapters (12mm instead of 14mm), so I won't be able to install these until sometime next week.
Old Jan 26, 2008 | 12:49 PM
  #5000
mcs22004's Avatar
mcs22004
That must be a disappointment. How do the tires look on the wheels?
Is this setup intended for summer? All the width seems impractical right now even with the melt-off we have had.
