Show me your WHEELS!
Old May 20, 2007 | 09:11 AM
  #3826
MINIdave's Avatar
MINIdave
The Blumeni wears 17" ASA's with Yokomama Parada Spec2's.......
Old May 20, 2007 | 04:10 PM
  #3827
Passat774's Avatar
Passat774
Originally Posted by Shawn G
Just got some Gram lights 57 Opimise put on. No center caps
nice tires,
Old May 20, 2007 | 04:58 PM
  #3828
Shawn G's Avatar
Shawn G
Thanks. I was very, very impressed with the Exalto's at the Dragon.
They stuck like glue.
Old May 20, 2007 | 06:21 PM
  #3829
cangelosijeff's Avatar
cangelosijeff
Old May 21, 2007 | 05:30 AM
  #3830
ZAKdog's Avatar
ZAKdog
me likey the EB caps!
Old May 21, 2007 | 09:37 AM
  #3831
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Originally Posted by rkw
I have 15x7 SSR Competitions, and on my '06 MCC the hub flanges are too tall by 1-2 mm for the metal SSR caps to fit. When mounting a wheel, the hub pushed the center cap out. Alex at TireRack said it fitted in earlier MINI and thought there might have been a hub change in '05. The plastic SSR center caps require less clearance and fit my car but look much less attractive. I'm using 3mm spacers to fit the metal SSR caps rather than use the plastic version.
Greatbear, I'm wondering if you might have a tight tolerance between the metal cap and the hub, and from thermal expansion they come in contact and the rubber O ring couldn't handle the heat.
I am going to check on this. I did not have the same problem with the earlier metal caps. Perhaps there is a slight difference in the inside diameter. If that's the case, I might try turning the inside diameter a bit to clear the hubs if there is enough extra metal, or use a slight spacer to compensate.
Old May 21, 2007 | 09:55 AM
  #3832
myzamboni's Avatar
myzamboni
Originally Posted by cangelosijeff
Nice
Old May 21, 2007 | 10:02 AM
  #3833
bee1000n's Avatar
bee1000n
Are those actual Porsche wheels? If so, are the spokes "spinning" the wrong way on the other side of the car? That always bothered me with the Turbo wheels.
Old May 21, 2007 | 10:15 AM
  #3834
cangelosijeff
yes and yes
Old May 21, 2007 | 10:24 AM
  #3835
Rally@StanceDesign's Avatar
Rally@StanceDesign
Doesnt look backwards to me....just looks pimp
Old May 21, 2007 | 10:59 AM
  #3836
cangelosijeff
thanks brother, can't wait to see what you've got in store!
Old May 21, 2007 | 01:56 PM
  #3837
ca$per's Avatar
ca$per
well it's about time that I join this thread ... here are my Axis Decade 18X8.
Old May 21, 2007 | 02:53 PM
  #3838
MINIdave's Avatar
MINIdave
Yep, they add just a touch of color, I like em too! Thanks!
Old May 21, 2007 | 03:08 PM
  #3839
goin440's Avatar
goin440
Old May 21, 2007 | 07:44 PM
  #3840
bee1000n's Avatar
bee1000n
yes and yes
My friend's '97 Prelude had similar 5-spoke wheels and Honda had the decency to make different wheels for each side of the car; no backwards spokes. Why Honda does it, but Porsche doesn't is beyond me.
I don't want to rain on your parade. They are still a cool, original, creative choice. I guess once you do a 5-lug conversion the sky's the limit on wheel options!
Old May 21, 2007 | 08:48 PM
  #3841
kenchan's Avatar
kenchan
^^ yah, i remember those wheels... had a 98 base. i quickly went
to SSR IntegralA2's.
Old May 21, 2007 | 08:59 PM
  #3842
pico's Avatar
pico
Any dark silver with Black R105s? I've just ordered this combo, but that DS with antracite looks great. Makes me wonder . . .
Old May 22, 2007 | 04:06 AM
  #3843
cangelosijeff
Lol no rain here, I knew they'd be like that, and like a buddy of mine said you can't look at both sides of the car at the same time anyways!
In terms of the conversion, you're actually pretty limited in terms of what you want to run b/c you need such a high offset. Most Audi/BMW/Mercedes wheels are out since they only have around a et40. Subtract the 25mm spacer and your down to around 15, which would be tough on a larger diameter wheel (17+). Porsche wheels tend to hover in the 50's and even 60's for some of the older stuff, so you still end up with a moderate safe and viable offset.
Old May 22, 2007 | 08:05 AM
  #3844
Justanthony's Avatar
Justanthony
Limited or not, nice choice!
Yeah, your buddy is right, and honestly, i think both directions look good anyways.
You've got a really nice setup. Your Cooper is clean!
(I think we have very similar taste.)
Old May 22, 2007 | 10:41 AM
  #3845
rocksurfer's Avatar
rocksurfer
how do you go about getting a 5 lug conversion for the mini
Old May 22, 2007 | 10:57 AM
  #3846
cangelosijeff
4X100--->5X130 adapters.
Old May 22, 2007 | 07:04 PM
  #3847
wscruiser's Avatar
wscruiser
Here is a picture of the wheels that I recently put on my MINI S.
They are Exel E-22 wheels.
Well, never mind, I can't get the pictures to post.
Old May 23, 2007 | 05:26 PM
  #3848
Sanderskog's Avatar
Sanderskog
Kosei K-1 powder coated Steel Gray Pearlescent finished with clear
17x7.5
BFG GForce KDW2 - 205/45-17
Old May 24, 2007 | 04:08 PM
  #3849
Passat774's Avatar
Passat774
16" Team Dynamics RVR II 205/55/16 Bridgestone Potenza Pole Position S-03
My current set at least for a few weeks:
Old May 24, 2007 | 04:52 PM
  #3850
Shawn G's Avatar
Shawn G
Sanderskog....that looks nice.
Shawn
