Tire Advice sought
Old Jun 11, 2003 | 07:41 AM
ColoradoMark's Avatar
ColoradoMark
I've ordered a set of 17" OZ Superleggera's for my MCS. I'm looking for advice on tires. My hope-to-meet requirements:
Streetable, in the summer, mainly dry pavement here in Colorado.
Autocrossable, but don't really care if I'm Uber competitive with these tires
Trackable, at least to the point they won't blister or wear out after a session or two.
I was thinking of getting the Falken Azenis but I see they don't come in 215's; I'm afraid that 225's will rub.
Any thoughts?
TIA!
Mark (taking delivery Friday)
Old Jun 11, 2003 | 11:11 AM
FWD-MX5's Avatar
FWD-MX5
S03s or Kumho Ecsta MX in 215/45 17s. Call Alex to make sure.
Old Jun 11, 2003 | 11:15 AM
Phobol's Avatar
Phobol
I heard Pole Position 3 is very good.
Old Jun 11, 2003 | 04:18 PM
Mark's Avatar
Mark
North American Motoring :: Founder
Since this is tire-related I'm going to move this over to the Wheel and Tire Forum for additional discussion...Alex can also help with the options.
Mark
BTW - We run 215-45R16 Azeni's on the TEAM MCO car. As soon as I can afford to I'll use these as street tires as well. They are awesome and relatively inexpensive!
Old Jun 12, 2003 | 07:47 AM
Alex@tirerack's Avatar
Alex@tirerack
I would agree that 215/45/17 Kumho Mx or Bridgestone S-03 are natual choices. Goodyear eagle F1 GS D-3 will work as well, when it becomes available (end of July).
I do not handle the Falcon line, I am not able to comment there.
Alex
Old Jun 12, 2003 | 06:10 PM
ColoradoMark
Alex,
Would the BFG G-Force KD's work? 205/40-17 or?
Old Jun 12, 2003 | 11:43 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Bridgestone S-03 cost about $160 each and would be a good choice. Wears up to 20-22K miles.
Very solid wet traction, excellent on the track and well mannered on the street. It's available now if you need them right away.
Old Jun 13, 2003 | 12:27 PM
Alex@tirerack
205/40/17 is low in load capacity for the Mini, That tire size only bears 992 lbs at full inflation pressure. I know A very fast 225/45/17 Ks motorer, but he had to shave major fenderliner. S-03 is best plug and play application, kd's if your willing to modify.
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
Old Jun 14, 2003 | 02:39 PM
ColoradoMark
Thanks Alex and everyone else! I think I'll go with the MX's, Grassroots Motorsports had a test. They seemed close to the Azenis/KD's on autocross times, probably are more streetable and looks like they might be pretty good on the track. (Plus they're cheaper than the S03's & the BFG KD's.
Old May 10, 2004 | 04:34 PM
iDiaz's Avatar
iDiaz
Coordinator :: Motoring Underground Club Forum
Will 215/40-17 rub on a wheel with a 37mm offset, though?
Old May 11, 2004 | 05:50 AM
Alex@tirerack
Most likely no - maker sure to run 36 psi!
Alex
Waszak
Oct 21, 2017 05:55 PM
Gabe3
Tires, Wheels, & Brakes
16
Apr 16, 2016 07:55 AM
Tektura
18
Sep 13, 2015 10:00 AM
Ntety
Sep 2, 2015 08:39 PM
kevinlhr310
Aug 27, 2015 06:45 PM
