Suspension Anyone modified to adjust rear from INSIDE
Old Feb 19, 2007 | 06:50 PM
COR BLMY's Avatar
COR BLMY
Hello,
Has anyone done any drilling to be able to adjust their adjustable shocks / coilovers in the rear from the INSIDE ???
Any info or insight would be really apreciated
New coilovers on the way and they are adjustable from the top and have extensions.
Old Feb 19, 2007 | 08:07 PM
1nf3rn0's Avatar
1nf3rn0
I was with steve and brad when we tried this. It is a big problem because the top of the strut moves alot depending on ride heighth and other factors. In order for it to work, you would have to drill a huge hole. This isn;t even an option for me because of the HK amp in my passenger side compartment.
Another option is a remote system, but th logistics of making one are way out of my realm of understanding....
Originally Posted by COR BLMY
Hello,
Old Feb 19, 2007 | 08:48 PM
JustGo4It_'s Avatar
JustGo4It_
Are you doing AutoX, track or street driving?
Old Feb 19, 2007 | 10:35 PM
COR BLMY's Avatar
COR BLMY
YES
That is why I want to adjust more easily
Old Feb 19, 2007 | 10:39 PM
COR BLMY's Avatar
COR BLMY
Thanks.
I could move the amp and I have an idea for the hole in the panel (something similar to the "disc" shift boot design)
Old Feb 19, 2007 | 10:40 PM
1nf3rn0's Avatar
1nf3rn0
Good luck. And if you get it to work out, let me know
Thanks.
Old Feb 19, 2007 | 10:44 PM
COR BLMY's Avatar
COR BLMY
I also have an idea for a FLEXABLE adjustor !
Old Feb 20, 2007 | 05:40 AM
JustGo4It_'s Avatar
JustGo4It_
I wish you luck. For AutoX most of the rest of us just set the rears on full stiff and forget about them. I haven't seen you at the local AutoX. Next event is this Sunday at Golden Gate Fields. What class do you run?
http://www.sfrscca.org/solo2/Results...nd03_info.html
Old Feb 20, 2007 | 12:28 PM
meb's Avatar
meb
Yup, I did it. Search the Megans threads...I had photos of all this at one time. A bit of a pain in the backside. Take your time!
Old Feb 20, 2007 | 01:30 PM
COR BLMY's Avatar
COR BLMY
Thanks for the reply
I will be searching
Old Feb 20, 2007 | 03:03 PM
onasled's Avatar
onasled
To me if you are making a hole, then make it a BIG hole. It's a sealed area so making a 2" hole is no big deal. It's a renforced area so it won't be weaker. Here are some picks.
Old Feb 20, 2007 | 10:21 PM
COR BLMY's Avatar
COR BLMY
ONASLED
Thank you VERY helpful !
Old Feb 25, 2007 | 11:35 PM
COR BLMY's Avatar
COR BLMY
DONE !
Photos and a write up soon
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ebowling
90
Aug 4, 2019 09:15 AM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
