Suspension Which Coilovers?
Old Mar 16, 2006 | 09:07 AM
  #101
gowest's Avatar
gowest
Originally Posted by jfunkmd
BTW Koni builds the KW dampers, just as Bilstein builds the H&R dampers.
I'm on my second set of KW's, V1's on for a few months, then after a lot of talk with KW, I ordered a set of their Competition 2 Ways. I had heard this same Koni rumor and asked their tech guy. SOME KW's are made by Koni but at that time none of the MINI fitments were.
Only negative about V1's and V2's is the rear spring rates could be higher, for rotation. You could order another pair of rear springs, one rate higher, for the V2's and be OK, since it's adjustable but cheaper would be to just to get the most effective rear sway bar for your needs.
With my MUCH lowered car (apx. 2") and pulling a trailer, with a car full of stuff, I find the higher rear rates useful, in keeping the tires from rubbing.
Old Mar 16, 2006 | 11:58 AM
  #102
AZMCS's Avatar
AZMCS
Good to know!
Old Mar 16, 2006 | 06:38 PM
  #103
skuzy's Avatar
skuzy
how are u ejoying the hr coilovers?
do u think the ride is too harsh/soft after experiencing them personally?
Old Mar 17, 2006 | 08:59 PM
  #104
AZMCS's Avatar
AZMCS
I really really like the ride. Much less body roll than stock. Firmer, but not harsh like it was with the H-Sport springs and stock struts.
Will be able to tell you all more after the AutoX next weekend.
Old Mar 18, 2006 | 07:35 PM
  #105
///ACS330Ci's Avatar
///ACS330Ci
What autox???
Old Mar 19, 2006 | 06:28 AM
  #106
AZMCS's Avatar
AZMCS
Dude, you gotta keep up. You never have that problem on a DMC event
http://www.azbrscca.org/
Old Mar 19, 2006 | 10:29 AM
  #107
///ACS330Ci
Or maybe you should start posting some of this over there
So, when are you gonna stop by and get these parts out of my kitchen?
Old Mar 19, 2006 | 11:45 AM
  #108
AZMCS's Avatar
AZMCS
Dude, between vwvortex, golfmkv, and NAM I can barely keep up with work
DMC website is just too hit or miss sometimes to keep up with.
Old Mar 21, 2006 | 07:50 PM
  #109
AZMCS's Avatar
AZMCS
Just to update:
I am having no problmes iwht my H&R's the whole system has settle dnow and am getting my alignment done tomorrow before this weekends autoX. After this I will let you all know how it is running.
The ride is much better than stock and much better than stock struts with H-Sport springs. Less harsh, just as good body roll control and fully height adjustable. I now have the front up near the top of the range and it is still lower than stock by a good 1-1.5 inches. This is with RDR camber plates, so with stock spring perches I would say the minimum front drop is gonna be 1.5 inches.
Old Mar 21, 2006 | 10:34 PM
  #110
crazyaboutmini's Avatar
crazyaboutmini
MTH coils?
has anyone taken a look of the MTH coils that are on thier site?
Old Mar 23, 2006 | 07:31 AM
  #111
AZMCS's Avatar
AZMCS
AutoX cancelled!!!
Gonna have to do a mtn drive instead to give you guys some post-alignment feedback!
Old Mar 23, 2006 | 11:50 AM
  #112
flyboy2160's Avatar
flyboy2160
jfunk,
did you get club sport h&r or the regular h&r?
thanks
Old Mar 23, 2006 | 12:24 PM
  #113
AZMCS's Avatar
AZMCS
Originally Posted by flyboy2160
jfunk,
thanks
Regular, the sport clubs are way stiff.
Old Mar 24, 2006 | 05:25 PM
  #114
agile_moments's Avatar
agile_moments
jfunk- where did you get your H&R's from? World One? I don't see them listed on their site? If they're still available there, I don't know if I saw it, but how much did you pay for them (if you're comfortable saying)? I'm kind of deciding between the H&Rs and Tein SS coilovers, but I can't find too much about the latter. Did you uncover anything in your search for the right coils about the Tein system? Any help would be grately appreciated!
Andrew
Old Mar 25, 2006 | 12:00 AM
  #115
AZMCS's Avatar
AZMCS
Andrew
Sent you a PM.
Old Apr 19, 2006 | 11:02 PM
  #116
matma92ser's Avatar
matma92ser
Do you know what the spring rates are for the sport and the regular? Are there any other differences between these two coilovers besides the spring rate?
Old Apr 20, 2006 | 09:10 AM
  #117
AZMCS's Avatar
AZMCS
They don't publish spring rates, but they are much much stiffer. As a result the dampers are valved differently too, but they are still not adjustable dampening.
FYI I am still very very pleased with my H&Rs. The ride is great, not overly stiff, and the car is completely flat on the autoX course!
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
