Suspension Anyone with H&R Sway Bar? [No lubrication needed]
Old Dec 14, 2005 | 05:35 PM
Maaij's Avatar
Maaij
Hi
My H&R rear sway bar is in. Will get it fitted next week.
I still have some questions:
From H&R:
H&R’s exclusive composite bushings (Urethane / Teflon) eliminate squeaks and never require lubrication. That means no mess, no maintenance—just bolt on H&R stabilizer bars and go!
I read some ppl with other brands have problems (squeaks) with the sway bar because off not enough/wrong grease. So the H&R sway bar seems to be a good choice. No worries about lubrications/squeaks. Sounds really nice
Anyone with H&R sway bars? Does it really dont need lubrication? Any sqeeking after a few miles? Does it really works what they claims? Or should I use grease to be at the safe side?
Old Dec 14, 2005 | 06:46 PM
kenchan's Avatar
kenchan
I would still put lube on the outside and bottom of the bushings.
Old Dec 14, 2005 | 06:50 PM
xtremepsionic's Avatar
xtremepsionic
Yep, got the 18mm 2 hole H&R on my Cooper (SS).
No grease, no squeak. Its been EXTREMELY cold 0F, -20C, no squeak. I had upgraded sway bars with polyurethane bushings in a Volvo 850 before, LOTS of grease, and they started squeaking when its really cold out after about 6 months.
So far, I must say the H&R works, I just love aftermarket mods where you install and forget about them I never even gave this "squeak" a thought til your thread came up
Old Dec 14, 2005 | 06:51 PM
jlm's Avatar
jlm
I've had 'em for 20k miles; no squeakum
Old Dec 14, 2005 | 07:58 PM
k-huevo's Avatar
k-huevo
18,000 miles with the H&R, no lube and no squeak on my car.
Old Dec 14, 2005 | 08:05 PM
weezer2282's Avatar
weezer2282
I wonder if its possible to use the bushings with other sway bars.
Old Dec 14, 2005 | 10:28 PM
kenchan's Avatar
kenchan
like which one?
Old Dec 14, 2005 | 11:55 PM
Maaij's Avatar
Maaij
Thanks for the reply's
Looks like it really works well as H&R claims
So you guys dont have used any grease on it?
Old Dec 15, 2005 | 04:11 AM
weezer2282's Avatar
weezer2282
Originally Posted by kenchan
like which one?
like hsport, alta, etc.
Old Dec 15, 2005 | 07:15 AM
kenchan's Avatar
kenchan
be ****. even though you don't grease the inside, i'd still grease the
outside and bottom with white lithium grease.
my Atla started moaning earlier this year (first time a swaybar ever
made noise on me on any of my cars) and upon inspection, I found
there was plenty of grease on the inside and outside of the
bushings....but no grease on the bottom since I never actually
applied grease there.
guess wat, i put a dab of grease on the bottom and no more
noise. lessons learned. i will apply grease to the inside,
outside, and bottom of bushings for all future installs.
Old Dec 15, 2005 | 07:16 AM
kenchan's Avatar
kenchan
if the diameter is the same, sure. but also make
sure you get the correct brackets too.
Old Dec 15, 2005 | 07:30 AM
Maaij's Avatar
Maaij
I will follow your advice and put grease everywhere
Old Dec 15, 2005 | 08:00 AM
Maaij's Avatar
Maaij
kenchan:
One more question
I read you are a big fan of white lithium grease Is this in aerosol form?
Old Dec 15, 2005 | 08:34 AM
kenchan's Avatar
kenchan
One more question
Maaj- don't use it 'everywhere' it'll be a huge mess to clean up.
I have a problem of fixation... jk
i am open to newer lubes but white lithium is available everywhere
and worked the best so far. I use the one sold in a tube.
(but i do have the aerosol one too for quick fixes).
i also have fixation with de-greasers... I use RC car motor spray.
Old Dec 15, 2005 | 10:07 AM
Maaij's Avatar
Maaij
hey kenchan:
A stupid duh question
Is this right? Do I have to put grease here
Do you recommed to do the inside as well?
Old Dec 15, 2005 | 10:29 AM
kenchan's Avatar
kenchan
yep, your outside and bottom is what I was referring to.
Since H&R comments they don't require lubing on the inside, i would
just leave it as is with no lube to preserve watever their coating is.
hey kenchan:
Old Dec 15, 2005 | 10:54 AM
Maaij's Avatar
Maaij
Ok thanks for your help Ken
Old Dec 15, 2005 | 11:01 AM
kenchan's Avatar
kenchan
yah, keep us posted on the install and how you like it.
Old Dec 15, 2005 | 11:19 AM
Maaij's Avatar
Maaij
Sure, I will
I wont fit it myself but I am there to see how they will do it
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
