Suspension Pilo Racing Custom Coilovers Coming Soon
Old Nov 20, 2005 | 09:57 AM
  #251
jlm's Avatar
jlm
if you are really hell-bent:
at the front of the car, measure from a fixed chassis point on each side (like the nut of the control arm bushing) to determine the front chassis centerline point. do the same at the rear. connect these points with a string line; that is the chassis centerline. then do your rear toe measurements equally from that centerline.
Old Nov 20, 2005 | 11:17 AM
  #252
Byron's Avatar
Byron
coilovers
Helix did a great job on the install of H Sport springs and H lower the control arms.Besides mathching the Hyper blue paint on my 05 S Cab.the ride is alot firmer.How much would coilovers help?Have already H sport rear sway bar and Stut bar.
Old Nov 20, 2005 | 11:28 AM
  #253
ingsoc's Avatar
ingsoc
ONE MORE THING I should add.... toe out eats up the inside part of your tires REALLY BADLY. Don't go toe out on the road unless you want to replace your tires twice as quickly .
Old Nov 20, 2005 | 01:20 PM
  #254
Byron's Avatar
Byron
toe in or out?
One degree out in the rear should improve handling and keep the rear tires running flat.
Old Nov 20, 2005 | 07:39 PM
  #255
MiniPilo's Avatar
MiniPilo
Don't have an exact date yet, but we are getting close to completion.
I was very impressed by the suspension this weekend as it survived a slight driving mistake on my part that allowed the Pilo Mini to become airborne. Though the car got some air, the landing was smmoth enough and more importantly, the car did not bottom out or even scrape the front fascia. I was happy that the car survived my mistake :-) Though thinking back, it was kind of fun :-D
Old Nov 21, 2005 | 05:34 AM
  #256
Thameth's Avatar
Thameth
We gotta hear this story!
Old Nov 21, 2005 | 10:42 AM
  #257
kenchan's Avatar
kenchan
how did the strut towers hold up? any mushroom action?
Old Nov 21, 2005 | 01:03 PM
  #258
J0kER's Avatar
J0kER
oooOHhhhh...sounded like fun
if everythin' survived
what spring rates were u runnin'????
*********& i too want to know more on the story**********
Old Nov 25, 2005 | 10:24 AM
  #259
Thameth's Avatar
Thameth
I'm dying here!
I can't wait to install these on my MINI, every drive I keep finding more faults in my current set up that can probably be fixed with these
Any update Pilo?
Old Nov 28, 2005 | 02:39 PM
  #260
MiniPilo's Avatar
MiniPilo
We are about 2-3 weeks away. They ship this week, and arrive in about 2-3 weeks.
I am writing up the directions for every thing, and it should be in your hands, just before the new year.
Old Nov 28, 2005 | 03:29 PM
  #261
Thameth's Avatar
Thameth
Damn... talk about terrible timing right at Xmas. I think you might lose some people because of that.
Old Nov 28, 2005 | 04:09 PM
  #262
MiniPilo's Avatar
MiniPilo
It was needed because we had to make small changes. Hopefully every one will still be able to participate.
Old Nov 28, 2005 | 07:04 PM
  #263
Thameth's Avatar
Thameth
The Spring changes? Or other stuff?
Old Nov 28, 2005 | 07:33 PM
  #264
MiniPilo's Avatar
MiniPilo
Spring Change, and longer bolts on the front camber plates to ease camber adjustment
Old Nov 28, 2005 | 08:51 PM
  #265
kurvhugr's Avatar
kurvhugr
Merry xmas to me!
Old Nov 29, 2005 | 02:21 PM
  #266
Thameth's Avatar
Thameth
Speaking of Camber adjustment, i don't think you ever got to answer that question. To adjust camber you just lift the front end and loosen those for allen bolts to adjust?? You don't have to loosen anything from the wheelwell right?
Had a friend asking me about this and wasn't 100% positive about the answer.
Old Nov 29, 2005 | 02:51 PM
  #267
MiniPilo's Avatar
MiniPilo
You will also need to loosen the 3 bolts on the top to lower the camber plate a bit. nothing needs to be adjusted from under the wheel well.
Old Nov 29, 2005 | 09:00 PM
  #268
Thameth's Avatar
Thameth
Ahh, Perfect thanx.
Old Dec 1, 2005 | 07:19 PM
  #269
Thameth's Avatar
Thameth
Well..... like i said TERRIBLE TIMING. If this was availible when it said it was going to be offered in Mid November i would have been the first to order and it would be going on my car now. But with it not being availible till Xmas time i'll need to drop out.
Shame because i REALLY want this kit but its not going to happen now.......
Old Jan 16, 2006 | 08:45 PM
  #270
FlynHawaiian's Avatar
FlynHawaiian
How does this setup feel? I really am curious in regards to this versus the h-sport/koni fsd setup. Will I still get the "back zap" going over a bump?
Old Jan 21, 2006 | 10:29 AM
  #271
kenchan's Avatar
kenchan
bump
Old Jan 23, 2006 | 05:13 PM
  #272
mattsmini's Avatar
mattsmini
my coilovers are in!!!
Okay guys, my name is matt and this is my first ever post on a forum. Im not new to th site though,i do alot of research here. Well to get back to business, I got my pilo coilovers installed today at World One Performance here in seattle.
After the install the car looked great, except for one thing. After the coilovers were installed Jonathan and I realized there is no way to adjust the rear damper. Therefore we thought maybe we could just lift the car and do it, nope not possible. So Jonathan being the great guy he is started to call around, but no luck. Megan Racing said the rears were already preset to 14. So now Im stuck with that force until I can find out further information on how to change it.:impatient
Anyway regardless of not being able to change the rear dampening force the coilovers are really great. I drove in and around the roads of downtown Seattle, and there was no more loud road noise caused by the stock suspension. I have the front on the softest setting, I like them.
Old Jan 23, 2006 | 06:50 PM
  #273
MiniPilo's Avatar
MiniPilo
I will be giving out the info on how to adjust the rears, but I need to retake my measurements, because I can not find my original spec sheet. I will get this as soon as I can. Sorry for the delay.
Old Jan 23, 2006 | 09:42 PM
  #274
Thameth's Avatar
Thameth
Here is the picture Pilo posted earlier of rear adjustment...
Old Jan 30, 2006 | 06:42 PM
  #275
SRTech's Avatar
SRTech
Installed Scooby03's coilovers last weekend. The quality of the coilovers seems excellent. Only time will tell how they last. Shipping needs to be improved since most of the mounting tabs were bent on both mine and Brad's and had to be straightened. Front camber is not adjustable from the top unless you expand the large hole in the top of the towers. Rear stiffness adjustments need a hole drilled accurately above the top of the coilover into the passenger compartment, accessible behind the access doors. The supplied allen key adjustment tool is not long enough to reach the adjustment, but a longer t-handled wrench can be cut and the short one can be punched out of the **** and the longer one tapped in. Lack of real instructions or templates lengthens the install time. Also, watch out for mushroomed strut towers. Brad's required a 12mm difference in strut length. Once installed, the results are excellent.[IMG]images/smilies/thumb-up.gif[/IMG]
Steve
