Suspension MCS rear sway bar on an MC - any noticeable improvement?
Old Jul 17, 2005 | 07:03 AM
Our 50's Avatar
Our 50
Coordinator :: Dynamic MiNi Collective
I purchased a used MCS rear sway bar (17mm) to replace our 16mm MC one. I would like to hear from others who have done this to see if it is worth the effort. Thanks
Old Aug 2, 2005 | 05:48 PM
Tio Barry's Avatar
Tio Barry
I did just that a couple of months ago and my '03 MC is stable but it was more tossable and fun to drive in original state. Seems less likely to oversteer now which puzzles me.
Old Aug 2, 2005 | 07:54 PM
orthomini_jr's Avatar
orthomini_jr
Do you race it or is this just on the street. You may of picked up a slight push going in with the bigger bar.
Old Aug 2, 2005 | 08:07 PM
mataku's Avatar
mataku
I too have a used MCS rear sway that I was going to put on my MC. However, my spring install took too long and it seemed like such a pain to put it on that I haven't dealt with it yet. I attempted to remove it, but I didn't see how it was going to be possible, didn't read the how to fully.
I plan on putting it on sometime, I have heard that there is an improvement. However, if you have the money and don't mind getting out of stock (for autoX reasons) then you might as well go for an aftermarket bar.
Let me know how things go.
Old Aug 2, 2005 | 08:08 PM
kenchan's Avatar
kenchan
he's not driving backwards into the turn.
Old Aug 2, 2005 | 09:02 PM
orthomini_jr
weight transfer
Old Aug 2, 2005 | 09:18 PM
th3118's Avatar
th3118
Dan,
Let me know if you want a hand, I have installed a few rear bars, they're not hard to do.
Todd
Old Aug 2, 2005 | 09:50 PM
Dr Obnxs's Avatar
Dr Obnxs
Somethings got to be going on.
No way a stiffer rear bar decreases oversteer. Something else has to be at play. A stiffer rear bar put more weight on the outside front in cornering. Has to turn more.
Matt
Old Aug 2, 2005 | 10:16 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Matt
MCS rear sway bar in an MC is fine.
Stiffer rear bar usually results in less understeer (hence more oversteer).
Even just that 1 mm diameter difference is enough to help. If you have the sport suspension plus option in an MC you also get stiffer MCS like springs.
If you are looking for even more difference then a 19mm rear bar (with holes for adjustment) would be worth a look. But for autocrossing does send you out of H-stock class (MC).
Old Aug 3, 2005 | 06:28 AM
kenchan's Avatar
kenchan
Matt
Yeh...perhaps tire pressure.
Old Aug 3, 2005 | 09:00 AM
Tio Barry's Avatar
Tio Barry
Well I've tried all sorts of tire pressure combinations but still end up with very SAAB-like understeer - this is street only use. So I guess i'll go back to the 16mm and see if all goes back where it was.
Old Aug 3, 2005 | 01:18 PM
kenchan's Avatar
kenchan
or his right foot.
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
