Suspension Using KWv2 on an EDC F56 without a cancelling kit?
Old May 19, 2023 | 06:20 PM
jbourne's Avatar
jbourne
Hi all - posted a similar question in the JCW forum but thought maybe this is the better place for it. I have an EDC F56 JCW, and I got a set of KWv2s without the cancellers. What would using them as is do? Just throw an error every time I switch Sport mode? Can I code out the EDC option from my VO, or is it more complex than that? A cancelling kit seems to be $400ish from KW, which is a little crazy.
Old May 23, 2023 | 09:58 AM
Some people said they unplug and they did not gate the code? Just make sure the suspension fits as NON EDC and EDC have a different PIN size on the strut. When putting NON EDC on EDC cars you may have to change the strut mounts as the sleeve is bigger. Its like m12 v m14 or M10 to m12.
https://www.northamericanmotoring.co...overs-ddc.html
Old May 23, 2023 | 03:34 PM
jbourne's Avatar
jbourne
My search-fu failed me. Thanks very much. This is exactly what I needed. Top mounts for the rear need to be replaced but that’s all, it seems like.
Old May 8, 2024 | 09:50 AM
blue al's Avatar
blue al
Almost Same question here but in reverse …can I fit my DDC compatible coilovers to the latest versions of the F56 ?
I have an F56 SD with the DDC or EDC 2015 MY ( built in 2014 )
I picked up some KW v3 for DDC cars Second hand in back in 2016/17 and never actually fitted them, ( as started another track r59 project)
110k miles later im still not sure if to fit or trade in the old car for a newer LCI or 2022/3/4 car.
ideal would be to pick up a cheap JCW in December or February and look to run the KW V3 as soon as my warranty expires, if I know it’s possible?
Old May 8, 2024 | 03:12 PM
jbourne's Avatar
jbourne
I don’t think KW DDC do anything other than have the right bolt for the different mounting plate and cancels any warnings in the computer for a missing adaptive suspension. I sincerely doubt that the KWs actually change dampening settings - the difference between the DDC and non DDC SKU is only a hundred bucks or so (retail) but I think if they actually changed dampening settings with a button, some severe redesign would have been needed.
Long answer but basically I think you’ll be fine. Just need to buy the correct top plates since the hole IS different.
Old May 12, 2024 | 11:06 PM
blue al's Avatar
blue al
so for top plate could get some adjustable camber-plates as long as they are ddc compatible. Or am I mixing terminology.
Old May 13, 2024 | 12:08 AM
jbourne's Avatar
jbourne
Yeah that should work IMHO. Basically “DDC compatible” in this context means they’ll take a 12 nut instead of 10 (I think; please double check here in the thread somewhere), nothing else.
That said, I was looking for camber plates, and I really think the F platform doesn’t have a lot of choices, not sure why.
Old Aug 16, 2024 | 11:00 PM
blue al's Avatar
blue al
just fitted these with my KW V3 (ex-edc) they are top notch quality wise ( made in Sweden) no ideas about any stateside distributors
https://carbonwurks.com/product/mini...er-top-mounts/
cargusjoh
Mar 29, 2022 09:21 PM
Ryephile
Dec 31, 2016 11:22 AM
sootyvrs
Suspension
Nov 12, 2016 09:29 AM
Eric Chen
Aug 12, 2015 12:04 PM
marcussoori
Oct 23, 2014 03:06 PM
