Suspension Lowered last week, blown CV Boot discovered today!
Old Mar 25, 2018 | 11:11 AM
Mazarin's Avatar
Mazarin
Has anyone else come across something like this?
I got the NM springs put on last week and waited a week for them to settle to get the alignment done today. Now it's spit grease all over the arm and the CV boot on the driver's side is wrecked. Passenger side is fine though...
Has anyone else had this happen? If so, is the boot replacement enough or do I need to do the whole axle? And if I do, will it happen again?
Thanks for any help!
Old Mar 25, 2018 | 12:16 PM
TVPostSound's Avatar
TVPostSound
Most likely installation damage. Many remove the steering knuckle along with the strut, that can cause a tear.
Boot should be enough, you haven't run that long for the joint to run dry.
Old Mar 25, 2018 | 03:25 PM
Mazarin's Avatar
Mazarin
Thank you, I may have a word with the installer then. The same shop also did my alignment and while the wheels are good, my steering wheel is tilted to the left a bit :/
Old Mar 25, 2018 | 03:40 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Yeah, it could be purely coincidental or installer error. Id be shocked if you got the installer to admit he did anything though
Old Mar 26, 2018 | 09:13 AM
Mazarin's Avatar
Mazarin
Yeah, I don't think so either, but we'll see. I'm waiting from NM to get back to me today as well, just to get some more confirmation on the setup. Thanks!
Old Mar 26, 2018 | 12:32 PM
vetsvette's Avatar
vetsvette
Moderator
Almost two years with NM springs. No problems so far. (fingers crossed)
Old Mar 26, 2018 | 01:36 PM
Mazarin's Avatar
Mazarin
So they claimed ignorance like I thought they would, and they won't just replace the boot saying it's essentially too much work, and repair itself fails a lot, requiring a replacement axle assembly anyway.
This sounds like BS to me, so I'm looking for more help. I was resigned to just get another assembly and have them replace it, but apparently F56 axles are made of gold and just as rare as I can't find many sites that have them, and the ones that do want $500 for them! HELP!
Old Mar 26, 2018 | 05:20 PM
TVPostSound
https://www.newtis.info/tisv2/a/en/f...aft/1VnYqAkbdA
Old Mar 26, 2018 | 05:31 PM
TVPostSound
Are you still under warranty??
Old Mar 27, 2018 | 08:46 AM
Mazarin's Avatar
Mazarin
I am! I called and they said that part is covered for 50k/mi. I'm going in Wednesday. I might have lucked out
Old Mar 27, 2018 | 08:48 AM
vetsvette's Avatar
vetsvette
Moderator
Got my fingers crossed for ya.
Old Mar 27, 2018 | 12:21 PM
TVPostSound
Keep this in mind, if they blame lowering.
You only lowered it 1 inch, those boots flex way more than that during turns.
Lowering might eventually cause the joint to wear faster, but the boot, no.
Old Mar 28, 2018 | 11:26 PM
Clutch Wotan's Avatar
Clutch Wotan
Thx for the info !
The left drive shaft i have changed 4 times, you don't get single joints you have to buy the expensive assembly. whereby it only concern the joint and boot a the engine side.
Autobild a weekly car magazine (#1) did mention this as well, according to them MINI has improved quality, whatever that means ( 11mm longer )
I have taken the article to my MINI dealer and ask for a refund of 4 driveshaft assemblies aka 3200 Euro
ww.autobild.de/artikel/mini-f56-gebrauchtwagen-test-13304601.html
Old Mar 29, 2018 | 01:20 AM
Clutch Wotan
quality problems beside #1 Crankshaft brg
another problem i didn't have yet - leaking oil cooler
Old Mar 29, 2018 | 10:23 AM
vetsvette's Avatar
vetsvette
Moderator
Aahhh. Much clearer now.
Old Mar 31, 2018 | 01:36 PM
Mazarin's Avatar
Mazarin
They fixed it! And they kept telling me how much they loved the way it looks...
Old Mar 31, 2018 | 02:38 PM
StephenM's Avatar
StephenM
Great outcome!
Old Mar 31, 2018 | 04:28 PM
TVPostSound
Old Apr 2, 2018 | 10:12 AM
Clutch Wotan
How do you know that the joint didn't got hurt, on my 1st out of 4 experiences it was also only the boot, if the grease comes out the chance that the bearing gets hurt is big. I also replaced it first and than 3 further weeks to hear the joint.
Again its not the boot its the complete assembly, take the driveshaft of the passenger side which is 7mm longer and mount your joints, than you can even use the adjustable chamber bushings from Powerflex, or buy a 11mm longer driveshaft. For serious players change the tripods engine side against traditional 8-Ball bearing, for higher torque over 400nm this is helpful.
Old Apr 2, 2018 | 10:59 AM
TVPostSound
The OP most likely received a new, complete axle.
Dealer techs in the US don't "rebuild" things, they replace complete components.
Old Apr 2, 2018 | 11:31 AM
Clutch Wotan
No true you get single joints, for BMW and MINI but the F56 is simply a sweet cherry on the top where they sell you complete assemblies to make money out of their own faulty design. If MINI can do anything than this, don't know any manufacturer who sells for fake scoops even a fake carbon version, Iam sure the side panel and its lines around the indicator are just a mould to install side scuttles, of course only through certified personal.
Old Apr 2, 2018 | 11:44 AM
TVPostSound
Even in warranty:
I had a noise in the front end, they replaced COMPLETE ARMS, rather than pressing out the bushings, and installing.
Old Apr 2, 2018 | 12:01 PM
Clutch Wotan
what is rebuild on a GENUINE joint :-) or are MINI workshops not in a position to swap them. Noises and vibrations also can result from the driveshaft.
http://www.gknservice.com/fileadmin/..._SPIDAN_DE.pdf
Old Apr 2, 2018 | 12:06 PM
TVPostSound
Let me rephrase.
They would rather replace the complete axle assembly, than replace a joint and boot.
The word rebuild is used loosely by me.
zanary
R57 :: Cabrio Talk (2009+)
Mar 6, 2009 09:26 PM
extremevalues
May 28, 2008 04:37 PM
mini-mine
Dec 15, 2006 10:56 AM
davavd
Oct 12, 2006 12:46 PM
dragonflyer
Feb 23, 2005 02:01 PM
