Suspension Quoted $550 to install springs... WTF
Old Jul 12, 2016 | 05:56 PM
Joespeed's Avatar
Joespeed
Someone please tell me this is not the going rate for an install like this ?
The shop said it included an alignment.. however, the car only has 1800 miles on it... wtf...
before I react ( kind of already did internally) is this the going rate for a springs-only install ?
Old Jul 12, 2016 | 08:43 PM
rkw's Avatar
rkw
Lowering the car? Yeah, you should do an alignment after the suspension settles in.
As for cost, here's some perspective:
https://www.northamericanmotoring.co...tall-cost.html
https://www.northamericanmotoring.co...r-install.html
Old Jul 12, 2016 | 10:42 PM
Joespeed's Avatar
Joespeed
thanks for the insight..
what is the typical timeframe for an alignment?
these came off of an F56 and are going onto an F55... I'd imagine a few weeks?
Old Jul 13, 2016 | 05:14 AM
Qik420's Avatar
Qik420
If they're used no need to let them settle, get the alignment done. Also, changing out springs is a breeze. Pick you up a spring compressor from harbor freight and do it yourself, then you just gotta pay the 90 or so dollars to get it aligned
Old Jul 13, 2016 | 06:41 AM
ZippyNH's Avatar
ZippyNH
... Shop is gonna charge you $200 or so per hour of shop time if you supply the parts...even if the "Shop rate"is lower....they need to make up for the lost mark-up on the parts you bought in to avoid loosing $$... cuse a different car could be on the lift, with the owner paying the mark-up on parts AND LABOR.
Sometimes a trusted shop that knows you will cut you a deal....but as a walk-in...they will feel they are doing you a favor.
So they are basically charging you 2 hrs and a alignment....$500.
In modding, parts are cheap...the labor and know-how is the $$$ part.
Old Jul 13, 2016 | 06:51 AM
goin2drt's Avatar
goin2drt
Doesn't seem bad to me. I paid more but I went to a high end race shop.
Old Jul 13, 2016 | 08:00 AM
toyopet's Avatar
toyopet
Spring compressors aren't needed for the F56 if you have access to an impact driver or air tools.
Old Jul 13, 2016 | 08:04 AM
Qik420's Avatar
Qik420
I can see that for disassembly, but you don't need one to re-assemble? I didn't know the new Cooper's had so much travel. No bueno.
Old Jul 13, 2016 | 08:44 AM
toyopet's Avatar
toyopet
If you have someone to help, you won't need spring compressors to reassemble.
Why is more suspension travel bad?
Old Jul 13, 2016 | 09:07 AM
Qik420's Avatar
Qik420
It's good if you're off roading I suppose
Old Jul 13, 2016 | 10:13 AM
toyopet's Avatar
toyopet
https://www.northamericanmotoring.co...ml#post4135993
Old Jul 13, 2016 | 10:33 AM
ljmattox's Avatar
ljmattox
I paid $480 and then $550 to have springs installed, then swapped back out 4 years later. R&R all four struts, and take them apart to change the spring, so it takes a while, 4.2 - 4.8 hours on the bills that I paid.
Old Jul 13, 2016 | 12:00 PM
rkw's Avatar
rkw
It is a good thing. It's only "so much travel" compared to the earlier generations. The 1st and 2nd gen had unusually low suspension travel compared to most cars (even high performance sports cars). That made suspension modding options very limited.
Old Jul 14, 2016 | 05:06 PM
Joespeed's Avatar
Joespeed
THANK YOU all for the input.. Im glad I asked to bring my expectations back to reality!
2nd question, with H&R Springs, do you think I'll have any issues running 15mm spacers in the rear? I have the 18" vanity wheels fwiw ...I want a nice clean rear end (lol) a little lower a little wider and to push the wheels out..
you know HR springs only drop 1.1" or so, so I dont see rubbing being an issue..
thanks in advance
Old Jul 15, 2016 | 07:18 AM
honderpilot's Avatar
honderpilot
I got quoted the same thing. It's due to the fact that these are basically bmws so we have to pay BMW prices... I'm gonna bite the bullet and pay that to get them removed. We installed them ourselves but 8 hours is not worth $600 to me.
Old Jul 15, 2016 | 08:37 AM
Hoopty's Avatar
Hoopty
Bump Stops
This may be helpful here.......
https://www.northamericanmotoring.co...ml#post4226195
Hoopty
Old Jul 15, 2016 | 11:03 PM
Joespeed's Avatar
Joespeed
Hoopty
thanks again Hoopty!
what about rear spacers tho ? any ideas guys ?
Old Jul 16, 2016 | 05:36 AM
goin2drt's Avatar
goin2drt
I wish I could help on the spacers. I don't use them but I did buy wheels with a bigger offset that pushed them out. They did rub at first with coilovers but I just kept adjusting them until they were right at the height they did not rub. Problem is I do not know exactly at what drop I ended at.
Old Jul 16, 2016 | 09:37 AM
Hoopty's Avatar
Hoopty
Here are a couple pics of my car with H&R springs, 215/40 18 Michelin PSS, and 15mm spacers on the rear. (you can see them in the picture) I hear it about once a month just barely rub/brush, no big deal.
Hoopty
Attached Thumbnails Quoted 0 to install springs... WTF-hoopty-1.jpg   Quoted 0 to install springs... WTF-hoopty-2.jpg
Old Jul 17, 2016 | 02:31 AM
MoJo4Twenty's Avatar
MoJo4Twenty
It gets pricey but I rather pay a little more for piece of mind. I got lucky and I know a shop owner who handles race cars and can squeeze me in. Hoopty I'm looking for tires for some 18x8 et 50 that I'm about to get soon. I wanted to run 225 instead of 215 do you think that would be an issue?
My stock 16 looks like this now. Might have to wait for the wheels before I decide on the tires (the offset 50 throws me off)
Old Jul 18, 2016 | 03:14 PM
minisf56's Avatar
minisf56
feel good. I just got quoted $1025 for install and alignment for coilovers!
Old Jul 19, 2016 | 05:16 AM
honderpilot
Why so expensive!? I got quoted ~$600 from MINI to do coilovers on mine.
Old Jul 19, 2016 | 09:07 AM
minisf56's Avatar
minisf56
it's the bay area labor rates.. mojo gave me some leads for other shops though!
Old Jul 19, 2016 | 09:50 AM
RB-MINI's Avatar
RB-MINI
What part of the Bay Area are you in... have you tried Bay Bridge Motors in Oakland or Mini Werks in San Carlos?
Old Jul 19, 2016 | 10:27 AM
minisf56's Avatar
minisf56
east bay! thanks for the recommendations RB!
