Suspension F56 Suspension options
Old Feb 4, 2015 | 09:53 PM
  #26
troyegly's Avatar
troyegly
Completely agree on wheels / stance ! I could go to the other side too. Been driving 15 justa for a week and very impressed
Old Feb 5, 2015 | 07:50 AM
  #27
DAVIDLEERAD's Avatar
DAVIDLEERAD
Has anyone tried or know anything about BC Racing coilovers (BR series)?
Thanks!
Old Feb 5, 2015 | 08:57 AM
  #28
VicSkimmr's Avatar
VicSkimmr
Originally Posted by Helix13mini
This shot and the previous Justa of Jason's (I think) could turn me around to the F56 shape. It's amazing what nice wheels and a good stance can do for a car.
Right? It's shocking what a bit of lowering and a new set of wheels can do.
Thanks!
That's what I'm using, they're great value for the price. The spring rates they use are fairly soft so it's still a comfortable ride at most heights. They're probably not great if you want to get really aggressive with wheel fitment but definitely good for any reasonable setup.
Old Feb 5, 2015 | 09:08 AM
  #29
DAVIDLEERAD
Thanks for info! Would you say at least an inch drop? I'm not looking to slam it, just a little more lower than the NM springs. Any pictures of your car with these installed?
Old Feb 5, 2015 | 09:11 AM
  #30
VicSkimmr's Avatar
VicSkimmr
Originally Posted by randomquickness
Are there any camber plates in the works? I checked with ST on their ST-XTA coilovers and they do not include adjustable top mounts unfortunately.
BC said it isn't possible due to spacing issues and I believe them. Take a look at where it mounts, I'm not sure how one could be designed to fit in there.
Old Feb 5, 2015 | 09:13 AM
  #31
VicSkimmr's Avatar
VicSkimmr
Most of the pics I've posted have been post coilover install. This is way lower than 1" and it still rides very comfortably with plenty of clearance underneath. It didn't even rub on speedbumps at that height. My next setup will push it way closer to it's max so we'll see how it rides then.
[url=https://flic.kr/p/pBm3D4]
Old Feb 5, 2015 | 10:49 AM
  #32
DAVIDLEERAD
I apologize for not recognizing earlier that some of your pics were featuring the BC's...thank you!
That's exactly the amount I'm looking for! Looks great and i love your overall set up!
So, just to be clear....these BC's are the "BR" series right?
Also, where did you purchase them and for how much?
Cheers!
Old Feb 6, 2015 | 05:55 AM
  #33
VicSkimmr's Avatar
VicSkimmr
Yeah, the BR series (cheapest set). I got them from DWS Parts but at the time they were the only ones offering them. They were $995
Old Feb 6, 2015 | 11:22 AM
  #34
randomquickness's Avatar
randomquickness
Where there's a will there's a way...
Old Feb 9, 2015 | 01:41 PM
  #35
VicSkimmr's Avatar
VicSkimmr
I hope so! I'd give anything to be able to adjust camber in the front. I'm close to breaking down and getting the powerflex bushing to at least give me a little bit.
Old Feb 15, 2015 | 05:58 PM
  #36
SoCalledFriend's Avatar
SoCalledFriend
What's the part number on these? I've scoured the internet and cannot find any BC Racing Coilovers that will fit the F56.
Old Feb 15, 2015 | 06:29 PM
  #37
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Just put a set of KW V2's on an F56 Friday. I'll be posting pics on our Facebook page later this week. Not only did it look so much better, but handling was back to a sports car.
Old Feb 17, 2015 | 05:25 AM
  #38
VicSkimmr's Avatar
VicSkimmr
The only thing my invoice says is T-05. If that's not right I'm sure you could contact DWS and they'd give you any info you need.
Old Mar 17, 2015 | 06:46 PM
  #39
DAVIDLEERAD
How are you liking the KWs?
How low did you go?
Thanks!
Old May 24, 2015 | 11:35 AM
  #40
marshun's Avatar
marshun
Just installed H&R springs. A little disappointed with the ride, pretty bouncy. I have DDC, I wonder how the standard struts fair with lowering springs.
Old May 24, 2015 | 08:24 PM
  #41
marshun's Avatar
marshun
Update....Ride is a little better with the air pressure topped off. It turns out the installer rotated the tires and had the lower pressure tires from the rear on the front.
Old Jun 3, 2015 | 09:13 AM
  #42
Ryephile's Avatar
Ryephile
^^Chances are the biggest change is the bumpstops have not been squished to hell, allowing for more compliance on smaller bumps. Big bumps will still hurt, as lowering springs reduce compression travel by however much they lowered the ride height.
Old Jun 18, 2015 | 10:13 PM
  #43
choochike's Avatar
choochike
Anyone know if there are differences between the f56 and f55? Would I be ok getting coilovers for the f56 to put on my f55?
Old Jun 19, 2015 | 01:22 AM
  #44
jamesdean's Avatar
jamesdean
The same
Old Jun 19, 2015 | 01:31 AM
  #45
jamesdean's Avatar
jamesdean
NM springs and 22mm sway.
EB f56 is all oem
Old Jun 26, 2015 | 06:01 AM
  #46
mct's Avatar
mct
You didn't have any issues lowering your car with springs even though you have the dynamic dampers?
Old Jun 26, 2015 | 06:19 AM
  #47
marshun's Avatar
marshun
No problems with the DDC, however I have switched out the H&R springs for NM and the ride is much better.
Old Jun 26, 2015 | 06:29 AM
  #48
mct's Avatar
mct
Interesting - how low did you drop the car?
What is odd is I have read several posts here that say you can't lower a car with springs if it has dynamic dampers... So your post gives me hope
Old Jun 26, 2015 | 07:45 AM
  #49
marshun's Avatar
marshun
The springs lowered it about 1.25 inches. I have read a couple people state you cant lower a car on DDC. Not sure if this based on fact or word of mouth. I only have about 1500 miles on the springs, so I guess time will tell.
Old Jun 26, 2015 | 07:47 AM
  #50
mct's Avatar
mct
Thanks for the feedback. Keep me posted. Would love to see some photos of before and after the drop
