Suspension OHLINS installed on the R56 !!
Old Mar 21, 2014 | 02:03 PM
  #76
SoCalledFriend's Avatar
SoCalledFriend
Originally Posted by andyroo
And yeah I don't know if I'd call them overkill. They're just the best road&track compromise coilover out there, and you have to pay a little more for that quality.
- Andy
Understood.....I just don't need the "track" aspect of them.
Old Mar 21, 2014 | 02:13 PM
  #77
jkapinos's Avatar
jkapinos
Yes but if you like a good handling car, be it off ramps or twisty roads, then you'll love them.
Old Mar 21, 2014 | 04:57 PM
  #78
BlackKat13's Avatar
BlackKat13
Originally Posted by ra2fanatic
Dude, BlackKat13, swing by to the 626 and drive my MINI for a sec. You'll know if the Ohlins are for you or not after you've ridden in it....
Thanks for that offer ra2fanatic I just might take you up on that… Since we are neighbors, is there a shop that you can recommend to set these Ohlins up the right way?
Rims, tires and Big brakes are also on my list of upgrades at this same time…
Old Mar 21, 2014 | 05:40 PM
  #79
ra2fanatic's Avatar
ra2fanatic
Yeah this guy :D
Ivan Madrigal @ Strasse Sport in Covina. Swapped out my Ohlin coilover springs to Hyperco springs in less than a hour :D
Old Mar 21, 2014 | 06:52 PM
  #80
BlackKat13's Avatar
BlackKat13
Thanks again ra2fanatic…. I found Ivan on Facebook and will contact him when all the parts come in…. On my next round of upgrades we need to talk about that awesome turbo set-up you have on your Mini….
Old Mar 21, 2014 | 06:54 PM
  #81
ra2fanatic's Avatar
ra2fanatic
any time. shoot me a pm and I'll be down to meet up anytime next week. except Wednesday, I'll be at Disneyland :-P
Old Aug 5, 2014 | 05:36 PM
  #82
squawSkiBum's Avatar
squawSkiBum
Moderator
Installed Ohlins R&T on my R56S over the weekend. A couple of questions for you guys who have been running Ohlins for a while:
1) what do you find is the optimum damping setting for daily driver? I'm at -7 clicks (from full stiff) both front and rear at the moment, probably going to soften it a bit.
2) The spec sheet says about an 18mm drop from stock. I set everything up following the recommended settings, I see the drop in front but the rear is unchanged. What has your experience been with height adjustment?
3) what do you find is optimum setting for track? I'm looking forward to another day at Laguna Seca and trying out the new suspension.
thanks!
Old Aug 16, 2014 | 11:04 PM
  #83
squawSkiBum
Moderator
No responses so here is an update on my questions:
1) I ran for about a week at -10, felt better but a little bouncy at times. Today I turned it down to -15. So far for a daily driver it feels great!
2) Originally I set the rears up according to the recommended settings: starting from a 200mm spring length, preload 10mm to 190mm, leaving 26mm of threads showing on the height adjustment. That gave me only about 1/8 inch of drop. So today I turned down the lower spring stop 5 turns which equals 10mm of drop, but reduces the pre-load. That resulted in about 25mm (1") of drop. I think what's happening is the weight of the car is now compressing the spring by what used to be the pre-load amount, that plus the 10mm on the lower spring stop is getting me the total drop. Also now I have noticeable rear camber, getting the car aligned this week.
I need to live with it for a week or so after the alignment to see what further tweaks are needed.
3) looking at the calendar to figure out which track day to sign up for - Laguna Seca or Thunderhill? Decisions...
Old Aug 19, 2014 | 10:57 PM
  #84
mini_aaron's Avatar
mini_aaron
Go for MRLS~ and bring some onboard vids, so that I can compare with my Laguna Seca onboards I got last year with stock suspension.
I also ordered ohlins(with hyperco, vorshlag) can't wait..but need to wait.. it's on back order. :(
Old Aug 25, 2014 | 08:33 PM
  #85
squawSkiBum
Moderator
Got it aligned last week. -2 degrees camber front and rear and very slight toe in front and rear as recommended by Bruce at BR Racing for a compromise between mostly daily driver with occasional track days. With the Ohlins, Vorshlag camber plates, 22mm RSB, and the alignment, the handling is now ridiculous. Not a trace of understeer and I don't even have to think about slowing down for corners. With the Ohlins set to -15 the ride is much improved on nasty bumps that would rattle my teeth with the stock suspension, but has incredible feel on fast corners. Damn this car is fun!
Old Aug 25, 2014 | 08:35 PM
  #86
ra2fanatic's Avatar
ra2fanatic
I'm surprised you didn't want a bit more aggressive fronts than rears, that's how I'm normally set up. You want more grip up front than the rears in these cars...
Old Aug 25, 2014 | 08:41 PM
  #87
squawSkiBum
Moderator
For a dedicated track toy I would definitely have more front camber, but since 99% of my miles are street I didn't want the extra tire wear.
Old Aug 25, 2014 | 09:12 PM
  #88
ra2fanatic's Avatar
ra2fanatic
My MINI isn't a dedicated track toy either, but I normally aim for around -3 to -3.1 camber up front and -2.4 to -2.6 rears.
Old Aug 26, 2014 | 07:52 AM
  #89
squawSkiBum
Moderator
Everything I have read says more than 1.8 - 2 degrees camber starts to wear the inside edges of the tires excessively - what has your experience been? What tires do you run?
Old Aug 26, 2014 | 08:33 AM
  #90
whrisk's Avatar
whrisk
as long as your toe settings are as close to 0 degrees in the front as you can get it, your tire wear will be ok. i used to run -3.0 front and -2.5 rear, and had very minimal inside tire wear on my street tires.
Old Aug 26, 2014 | 08:39 AM
  #91
ra2fanatic's Avatar
ra2fanatic
Experience? Hmmm....well I have 17" wheels on G-Force Rivals for track and the CCW's on 18" Falken 453 tires. I'm not really a good example for an experience with tires because I run rather aggressive on the street and wear has never bothered me. I rotate and flip my tires to even out the wear over time though, but I can't say I've gone to the wear bars on any of the tires I've had since I end up selling my wheels waaaaaay before I even get to see how even or uneven the wear is.
Pretty similar to what you have.
Old Aug 26, 2014 | 08:36 PM
  #92
squawSkiBum
Moderator
LOL well I'll have to get used to the new setup and keep an eye on the tire wear. I'm almost done with the stock Continental runflats and will be replacing with Michelin PSS when the time comes.
Old Aug 27, 2014 | 01:40 PM
  #93
jkapinos's Avatar
jkapinos
Make sure you have a good alignment before running the pilot super sports. I ate up my first set, then did the alignment. Second set is lasting.
Old Aug 30, 2014 | 05:51 AM
  #94
Arthas's Avatar
Arthas
Yeah this guy :D
Great Brake!
Old Sep 9, 2014 | 09:41 PM
  #95
ra2fanatic's Avatar
ra2fanatic
^Thanks! They stop great too! :D
Old Sep 17, 2014 | 08:28 AM
  #96
nekky's Avatar
nekky
I'll jump in here just to say that I've seen ra2fanatics R56 in person and it's badass! I too will be running öhlins next year along with Vorshlag camber plates. Where's the best place to order? I'm in Canada.
Old Sep 17, 2014 | 10:51 AM
  #97
ra2fanatic's Avatar
ra2fanatic
When did you see my MINI???? Battle Tuning can probably take the order for you.
Old Sep 17, 2014 | 11:37 AM
  #98
rckrzy1's Avatar
rckrzy1
They make great stuff for Bikes too.
Old Sep 17, 2014 | 11:50 AM
  #99
squawSkiBum
Moderator
Nekky - For the Ohlins definitely shop around, there is huge variation in pricing. I ordered through coilover-store.com, they don't list applications for the R56 on their website but when I inquired via email they responded quickly with a very attractive price. They direct shipped from Ohlins. Apparently I got the last set in the USA at the time, the next batch doesn't arrive until October.
Vorshlag camber plates are the same pricing everywhere, so pick your favorite vendor to order or go direct to Vorshlag. They get built to order and shipped direct from Vorshlag. I ordered through outmotoring.com, great customer service, 5% NAM discounts, and free shipping to lower 48 for orders over $195.
I also ordered new "hats" for the rear along with Powerflex shock mount bushings from ECS Tuning. That makes the install really easy as you can put together the whole assembly on the workbench and then just swap. No dealing with a spring compressor to re-use the mount and bushing.
Old Sep 17, 2014 | 12:11 PM
  #100
kyoo's Avatar
kyoo
i think -2.5 f, -1.5 r, 0 toe front, tiny bit of negative toe in the rear would be a good street setup. as long as u don't go crazy with toe, you'll be fine with tire wear.
