Suspension Things I learned while installing TSW springs and Koni sports.
I just finished installing TSW springs, Koni sport shocks, and a 19mm Hotchkis rear bar.
The bar install is pretty easy, but I've got a lift and air tools. Just make sure that the hole in the bushing for grease is actually open. Otherwise the darn grease just doesn't want to go in there...lol
You have to drill out the rear spring hats, and washers from 10mm to 12mm because the shaft of the Koni is... well 2mm bigger...lol
Well what it like? I couldn't have believed it. It rides like an entirely different car. It's way more compliant over any sharp bump.
Virtually eliminated squat and dive, and torque steer! Far less body roll.
I wouldn't have thought it was possible by just changing shocks and springs.
Highly recommend it.
Congrats on your install. Where did you source the Koni Sports?
Did the Koni instructions tell you that you had to open up the hats?
Pictures?
Glad you like it. And how many miles are on your MINI?
Don
Pictures?
Don
I picked them up from the marketplace used.
The Koni instruction might as well be Egyptian hieroglyphics. (or maybe Ikea...) They are completely useless except for the torque requirement for the nuts. It was pretty obvious that the shaft was bigger. I just measured the shaft with a micrometer and made it fit. Other than that, they are just like stock. I only had to drill the hats for the rears. the fronts fit fine.
Pictures? no... I didn't bother.
My 2010 MCS has just over 9500 miles.
No bushing required. they are part of the rear shocks.
The car really is transformed. The ride it worlds better. No squat or dive. Compliant over bumps. I might add a bit more rebound damping and see how that works, but full soft was a very good starting point. Maybe a touch more rear bar too.
Yes. Paired with Koni's the car is great.
Oh and Way, sorry I didn't get back to you about the end links. Well, they do fit, just barely...Just about 1 thread exposed past the nut on the lower mount. I guess I just had it cocked a little bit the first time. But, the stock lower stud is 10mm longer than the top... If you want, I'll send it to you to check for yourself.
squawSkiBum
Oct 2, 2015 09:21 AM
minipopkart
Aug 13, 2015 05:22 AM
